Old Apr 10, 2012, 05:14 PM
wallaguest1 is offline
Find More Posts by wallaguest1
wallaguest1's Avatar
Joined Nov 2006
hi,
where to get motor mounts for the xeno please?
wallaguest1 is offline Find More Posts by wallaguest1
Old Apr 11, 2012, 08:35 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by wallaguest1 View Post
hi,
Usually from the same place you get the XENO.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Apr 11, 2012, 11:35 AM
Joined Nov 2006
i mean one for use standard motors, and keep it foldable
Old Apr 11, 2012, 04:00 PM
federl is offline
Find More Posts by federl
federl's Avatar
Austria, Stmk., Sankt Radegund bei Graz
Joined Aug 2011
just pic up the standart drive at any dealer like this:
http://www.t9hobbysport.com/item.asp?prodid=748
federl is offline Find More Posts by federl
Old Apr 11, 2012, 06:08 PM
RCITGuy is offline
Find More Posts by RCITGuy
RCITGuy's Avatar
United Kingdom, Croydon
Joined Feb 2010
Originally Posted by TriStar_drvr View Post
Does anyone have the canopy from the glider version? I crashed my Xeno today and broke the canopy. If you're willing to sell it, please reply to this post, PM me, or E-mail me at bnspencer@verizon.net
Brad
Hiya mate
Do you still need the flat canopy for your Xeno?
I have one and will never use it, so your welcome to it if you want, just PM me your address and you can have it for free, so long as the postage doesnt kill me.
I havent flown my Xeno in ages, since my first efforts and all the hassles with launching it, as I'm not brave enough to throw it with the power on, but I use the standard tuning power set and mine goes totally vertical, no problem, and I fly it on a 1000mAh 3S, but have an extra 25g lead in the nose to balance it.
For those asking about the lights, I only put a switch on them as it more a "Lets try this" kind of idea, and in the dark, they do light up really well, even when flying away from me you can see them, but the red is not as bright as the green...
I going to try my Xeno again I think, at a local park that has shallow hills, so I can at least throw it, no power, and I can get the power on before it hits the ground.
I find that a huge problem, in throwing it with power off, then getting onto the throttle before its already landed 20ft away
RCITGuy is offline Find More Posts by RCITGuy
Old Apr 11, 2012, 06:49 PM
Joined Nov 2006
i want use hk motors...
Old Apr 11, 2012, 11:07 PM
federl is offline
federl's Avatar
Joined Aug 2011
spare parts i.e.:
http://www.vogel-modellsport.de/RC-F...0_466_477.html
http://www3.towerhobbies.com/cgi-bin...I=MPUA2139&P=X
Old Apr 11, 2012, 11:35 PM
Joined Sep 2000
Then you have to pick a HK motor which is suitable for the "power-pod".
Jürgen
Old Apr 12, 2012, 09:08 AM
hugofly is offline
Find More Posts by hugofly
Wallington, New Jersey, USA
Joined Apr 2010
Hey, that's part of the fun! :-) I've launched mine into the ground several times. You just have to be really quick applying throttle, it's mostly practice.
Also, I programmed a mix to a switch to give a little bit of up elevator. So when I toss it, it doesn't nose down. Right after I apply power, I flip the switch to neutralize the ailerons and off I go.
hugofly is offline Find More Posts by hugofly
Old Apr 23, 2012, 04:51 PM
littlephoenix is offline
Find More Posts by littlephoenix
littlephoenix's Avatar
Joined Aug 2007
wondering why anyone is not sticking a mega 16/15/3 on this bad boy with a 4S 2200 setup, 5x5 prop,,,hmmm
littlephoenix is offline Find More Posts by littlephoenix
Old Apr 23, 2012, 10:58 PM
Joined Sep 2000
Because
a) the motor would not survive long on 4s and 5x5" prop,
b) because a bigger prop is more efficient and
c) the XENO is not designed for high speed.
Jürgen
Old Apr 26, 2012, 05:12 AM
francesco67 is offline
Find More Posts by francesco67
Florence, Italy
Joined Feb 2010
Originally Posted by Jurgen Heilig View Post
This is motor is much better suited for the original folding prop - provided the motorshaft can be pushed from one sid eto the other.
Jürgen
Yesterday I tried the motor with 9x6 folding prop (again the link: http://www.hobbyking.com/hobbyking/s...dProduct=19036) very very well!
I did not make any measure on it, but I can say:
- it seems to permorme as well as the himax motor for tuning motorization: the xeno climbs up vertically
- it does not nearly heat up at all
The motor is very easy to adapt to the xeno (as Juergen says, it is necessary to push the shaft from one side to the other but it's an easy job) and has a great price!
francesco67 is offline Find More Posts by francesco67
Old Apr 27, 2012, 03:02 PM
varvar is offline
Find More Posts by varvar
Finland
Joined Apr 2011
I don't need new wings. But "I'm gonna make him an offer he can't refuse"
Would you like to have the cheapest Xeno? I bought the wings for about 19 euro. 1300 kv outrunner from Hobbyking - 6.5USD. Servos - 2x3USD. And some small parts.
Wings:
Description:
Size is close to my favorite wings
Description:
283 g with carbon
Description:
Why do I need huge servos?
Description:
I have to cut here
Description:
Connected wings - bottom
Description:
and top
Description:
Little bit decoration for the bottom
Description:
After covering by adhesive tape - 325g
Description:
Top
Description:
bottom
Description:
let's install servo by little bit different way
Description:
We need some tools
Description:
the deep hole
Description:
top view
Description:
some decoration
Description:
Servo is connected
Description:
Let's decorate
Description:
Description:
did I forget something?
Description:
ok, now it is better
Description:
And something inside
Description:
varvar is offline Find More Posts by varvar
Old Apr 28, 2012, 07:24 AM
Joined Sep 2000
Because the flight controls are rather big and bigger servos usually consume less current and have more robust gears.
Jürgen
Old May 06, 2012, 07:53 PM
mickydee is online now
Find More Posts by mickydee
Hemet, California, United States
Joined Aug 2001
Hi guys,
For those using the tuning power set up, how are these systems holding up over time? Are the C F drive shafts lasting along time?
Thanks, Mickydee
mickydee is online now Find More Posts by mickydee
New Product Multiplex Xeno checkup Flying Wings 129 Apr 10, 2010 08:47 AM
Yippee! New Multiplex Models 2009: MERLIN and XENO Doubletap Slope 12 Feb 26, 2010 10:31 PM
Discussion XENO, New to Multiplex??? sparkie624 Hitec/Multiplex USA 4 May 27, 2009 06:16 PM
Discussion Multiplex Xeno as FPV JakAck FPV Talk 7 Mar 09, 2009 06:40 PM
New Product Multiplex Xeno soundcheque Flying Wings 2 Mar 03, 2009 09:25 PM
