Old Sep 19, 2011, 07:25 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by francesco67 View Post
Could someone link me where I could buy a new one (of course without buying the whole motorization kit!).
Hi Francesco,
have you tried to contact MPX dealers in Italy?:
http://www.multiplex-rc.de/distribut...ad605f75e41725
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
francesco67 is offline
Find More Posts by francesco67
Florence, Italy
Joined Feb 2010
Originally Posted by hobie14 View Post
Send the guy on the post below a PM (private message) ..... Jurgen knows more about MPX than anyone alive !!!!! .....
http://www.rcgroups.com/forums/showp...2&postcount=65
That what I did Hobie...really I had already noticed and apreciated the quality of Jurgen's post.
Francesco
francesco67 is offline Find More Posts by francesco67
Old Sep 19, 2011, 07:30 AM
Florence, Italy
Joined Feb 2010
Originally Posted by Jurgen Heilig View Post
Hi Francesco,
Jürgen
Yes, I called the shop in Florence. They don't have the xeno prop, but a MPX foldable 9x6 one (I believe it is for the easy glider), and the girl did not know if it would fix on Xeno.
So I will go to the shop with the broken propeller and check if it's ok.
Thanks again...I believe from your answer that nobody else on this thread broke the propeller!
Actually, it was not easy, but I could!
Old Sep 19, 2011, 07:36 AM
Joined Sep 2000
Yes, I called the shop in Florence. They don't have the xeno prop, but a MPX foldable 9x6 one ...
Alternatively you should be able to use Aeronaut Cam Carbon 9x6" blades, if those are easier for you to get.
Jürgen
Old Sep 19, 2011, 07:45 AM
Florence, Italy
Joined Feb 2010
Jürgen
Great! If I cannot find the MPX original spare part, I will get the Aeronaut Cam Carbon (they are easily available in Italy)...
Danke!!
Old Sep 20, 2011, 04:13 PM
Florence, Italy
Joined Feb 2010
Jürgen
Also Graupner 9x6 blades fits perfectly!
Old Oct 02, 2011, 04:43 AM
Florence, Italy
Joined Feb 2010
Here I am again...
I burnt the original speed controller of xeno (polarity inversion...), so I am thinking to replace it with an Hobbyking regulator, much cheaper (the original one costs more than 60 €).
I am speaking of the 30 A esc contained in the tuning power set (http://www.horizonhobby.com/Products...odID=MPU332655).
I would like to replace it with an HK 30A, something like this: http://www.hobbyking.com/hobbyking/s...ontroller.html
Is it possible?
Old Oct 02, 2011, 06:46 AM
hobie14 is offline
Find More Posts by hobie14
hobie14's Avatar
Western Europe 52.7° N 8.9° W
Joined Jul 2007
Here I am again...
Is it possible?
I'm using the following 30A and it's working fine ........
(although I see it's on back order right now)
program with this card and set 'brake on' and 'soft start' .......
http://www.hobbyking.com/hobbyking/s...ming_Card.html
hobie14 is offline Find More Posts by hobie14
Old Oct 02, 2011, 08:56 AM
Florence, Italy
Joined Feb 2010
Thanks for the good tips!
Old Nov 04, 2011, 04:21 AM
Soulslotter is offline
Find More Posts by Soulslotter
Joined Jul 2011
Hello,
I just ordered the new Xeno Uni Kit, because I have a 30A ESC laying around. So, the only thing I need is a motor for the included 8x5 or an 9x6 prop I also have.
I also have an Graupner 300z 7,4 motor here, but I think it is too weak. Or may this motor be OK? What motor may work from hobbyking? This e.g.:
http://www.hobbyking.com/hobbyking/s...idProduct=7992
or
http://www.hobbyking.com/hobbyking/s...dProduct=19036
Bodo
Soulslotter is offline Find More Posts by Soulslotter
Old Nov 07, 2011, 02:40 PM
saxon0010 is offline
Find More Posts by saxon0010
saxon0010's Avatar
United Kingdom, London
Joined Feb 2009
Hi!
I use this motor, with 30A ESC and 8x6 folding prop:
http://www.hobbyking.com/hobbyking/s...dProduct=14737
It's work fine..
A képet az RcPilot.hu tárolja.
Steve
saxon0010 is offline Find More Posts by saxon0010
Old Nov 22, 2011, 04:45 AM
RJJ is offline
RJJ
Find More Posts by RJJ
RJJ
Joined Oct 2011
Xeno I built. Tired of waiting on the himax motor from the tuning kit so installed a turnigy 3530-1460kv on 9.5*5 & 9*5 aeronaut cam carbon props. Had to cut the x mount down and ca'd it in place & all the edges and use longer screws plus had to cut the shaft so the spinner was flush like standard.
Had a fusion motor 2829/13 - 930kv in there 1st as I brought my xeno with the power pod but only received a 3mm collet, so for 1st flight my friend really had to give it a good throw as not enough power in the motor for me to launch. No vertical on this setup and made slow circles to gain height.
Not flown with the turnigy yet but static power it really feels like a different plane. Just holding the wing and powering up to 1/2 throttle it wants to get off now out of your hand. My aim is to get height very quickly and than glide/thermal around. Also it's nice to have a lot of grunt just to match the looks, there's always throttle control
RJJ is offline Find More Posts by RJJ
Old Nov 28, 2011, 01:10 AM
TriStar_drvr is offline
Find More Posts by TriStar_drvr
TriStar_drvr's Avatar
Victorville, CA
Joined Oct 2009
Does anyone have the canopy from the glider version? I crashed my Xeno today and broke the canopy. If you're willing to sell it, please reply to this post, PM me, or E-mail me at bnspencer@verizon.net
Brad
TriStar_drvr is offline Find More Posts by TriStar_drvr
Old Nov 28, 2011, 06:57 PM
billyd60 is online now
Find More Posts by billyd60
Gravity is patient............
Joined Mar 2006
Just ordered a Xeno today from tower hobbies as an early christmas present. I found the plane because I use Aerofly 5.7 sim software and it's a blast flying the Xeno in that sim. Highly recommend that sim if you have the coin (it's expensive) it's the best I've seen and I've seen most of them.
Couple of questions
Why not just make some wire standoffs to protect the servos? Or does anyone make a servo cover that might fit? Seems a more logical approach than modding the top of the wing for top mounted servos.
Why not handlaunch sidearm off one wing tip?
What's the typical setup? I am not using the mpx power set, I'll be supplying my own. I've skimmed the thread and I've seen 3s lipo, 30amp esc and 1400kv motor. Is that about right? I assume the 9x6 prop is what most use. Is there a premium setup that anyone wants to recommend?
Is enlarging the stabilizers important? Does anyone sell larger ones aftermarket or is that strictly a user mod?
billyd60 is online now Find More Posts by billyd60
Old Nov 30, 2011, 09:31 AM
Joined Mar 2006
The multiplex tuner option needs to come down in price. Not to mention it's backordered everywhere anyway.
You can buy the kit with the electric conversion for $69 from towerhobbies. ($10 more than the std kit)
You can buy the himax 2816-1220 motor from ALLERC for $59. You can buy a 25 amp CC speed controller for $57 from ALLERC too and get free shipping.
That makes the tuner kit effectively cost 10+59+57 or $126 instead of the $169 towerhobbies wants for it and get a better quality speed controller.
New Product Multiplex Xeno checkup Flying Wings 129 Apr 10, 2010 08:47 AM
Yippee! New Multiplex Models 2009: MERLIN and XENO Doubletap Slope 12 Feb 26, 2010 10:31 PM
Discussion XENO, New to Multiplex??? sparkie624 Hitec/Multiplex USA 4 May 27, 2009 06:16 PM
Discussion Multiplex Xeno as FPV JakAck FPV Talk 7 Mar 09, 2009 06:40 PM
New Product Multiplex Xeno soundcheque Flying Wings 2 Mar 03, 2009 09:25 PM
