Jürgen
Latest blog entry: 12th. German- / 1st. European Indoor...
![]() Adding weight to the nose could be counter-productive. With the CG further forward, your elevons need to be raised more for compensation. Increasing speed by turning the motor on, will cause the model to climb even more then. Climbing under motor power is normal. Motor screws coming lose is not normal. Were they properly tightened? Jürgen
Marlborough
Joined Mar 2009
Thanks Jurgen. The motor screws were tight, or at least I thought they were. I have retightened them now. I was thinking that the vibration caused when the prop opens up against the force of the rubber band might have contributed, but I guess if no one else has had an issue then I couldn't have tightened them enough. Regarding the climbing, I will try to trim it out on my next flight unless you guys have a better idea? As I say, I'm very new to this!
Alexandra
Joined Jul 2007
Ever think people might just want an opinion on a plane. All the facts and figures wont replace gut instinct.
I have flown a stack of planes that I could quote a myriad of numbers for that just were not fun to fly. On the other hand I have flown a heap of models that also have a stack of numbers, figures and facts that were fun to fly. When I read a review it is unlikley that I will have access to the same power setup as the reviewer of the model and as battery quality has a huge impact on performance anyway I think while it's nice to have the data there it's not why I am reading the review. I am reading to find out what the revewer thought of the model. Building quality and tips, flight characteristics etc. Breitling: Pitching under throttle is an unavoidable issue with the Xeno. In other models you have the ability to adjust the thrust angle up down and left right to trim this to make the model more enjoyable and better to fly. Due to the setup (power from the motor is sent down a shaft to the prop) on the Xeno this is not possible. The funjet is a classic example of the ability to being able trim the thrust pitch. I doubt that you didn't tighten the screws up tight enough, more like vibration and or a lack of a dab of thread lock. |
For reviews, the models usually are equipped with the recommeded gear. If you replace it with similar items, you can still expect similar results. Jürgen
Jurgen, I enjoy reading your post and reviews. Keep up the good work. Gene |
Alexandra
Joined Jul 2007
Yeah that works really good too. With something like the xeno the tiny bit of lost efficiency due to the increased drag is not an issue.
2500gene, Jurgen : Your both right, as normal the truth is in the middle. Personal taste, I like to read a review that says it climbs like a bat out of hell, and it's even better if the reviewer then adds some real world stats. What I haven't seen yet that would be good is comparable bar graphs on performance.Jurgen do you record battery temp before during and at the end of your "stats" runs ? As we all know battery temp has a huge impact on performance and it would be good to know what your temperatures were given your battery c rating and current draw. |
However you describe it I've always thought the climb rate of the Xeno is excellent and a real benefit of the design ...... climb fast and high ...... turn off the power and slope soaring is a lot of fun .....
![]() http://yfrog.com/0vimg0378vij |
Jürgen
| Thread Tools | |
| New Product Multiplex Xeno | checkup | Flying Wings | 129 | Apr 10, 2010 08:47 AM |
| Yippee! New Multiplex Models 2009: MERLIN and XENO | Doubletap | Slope | 12 | Feb 26, 2010 10:31 PM |
| Discussion XENO, New to Multiplex??? | sparkie624 | Hitec/Multiplex USA | 4 | May 27, 2009 06:16 PM |
| Discussion Multiplex Xeno as FPV | JakAck | Video Piloting (FPV/RPV) | 7 | Mar 09, 2009 06:40 PM |
| New Product Multiplex Xeno | soundcheque | Flying Wings | 2 | Mar 03, 2009 09:25 PM |
