Old Jul 07, 2010, 04:10 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by frogbmth View Post
... rated to 100A. ...
Where did you get the 100A rating from? I can't find this information.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jul 07, 2010, 04:41 PM
frogbmth is offline
Find More Posts by frogbmth
frogbmth's Avatar
Poole, England
Joined Jun 2008
This is what the rep here said and there are forum posts on other boards where people have been advised the same by local reps. They are a similar design to deans but have a larger area of contact and much easier to handle. I was a bit suspicious at first as I figured they would be more widely used if they were as good as people were telling me, but I ordered a few for one heli and quickly converted all my aircraft over.
There are knock-offs from HK you can get , I ordered a bag and they look just as good as the real deal and are compatible, so I will use these on my lower current draw machines
http://www.hobbycity.com/hobbyking/s...idProduct=9762
I pull 80A continuous and 150A bursts through mine on my bigest electric heli no problems, they don't get warm. They are well worth looking into for anybody with connetor woes
Andy
frogbmth is offline Find More Posts by frogbmth
Old Jul 07, 2010, 06:19 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
I changed all my models over to Traxxas high current connectors and never looked back. No more heat shrink, easy to solder, easy to connect and disconnect with the big grab areas and rated to 100A. Everybody I show them to on my planes and helicopters changes over, I can't understand why they are not more popular
+ one on this. I was a "deans4ever" kinda guy till I tried the traxxas connectors!. They are SO much easier to solder. No worries about warping them like deans (sure, you wont warp deans soldering them either.... If you are an expert solderer, which must of us arent) No worries about shrink wrap. I cant even count the number of times I soldered up a deans connector, then had to de-solder it because I forgot the stupid shrink wrap....
I use traxxas on everything now, even my mini's....
The biggest complaint I hear about the traxxas connectors is how long they are compared to deans, which is dumb because sure, the actual plastic part is shorter on the deans, but when you add in the lugs on the back and the shrink wrap, they are close enough to the same length that its a non issue.
And like many others, I have severely damaged a plane trying to get the deans connectors apart!
dacaur is offline Find More Posts by dacaur
Old Jul 08, 2010, 04:59 AM
rkopka is offline
Find More Posts by rkopka
Electric only
rkopka's Avatar
Graz - Austria
Joined Nov 2002
Originally Posted by Breitling View Post
Yep, I've tried that! I find that the plastic case melts when tinning the pins. The cables on the lipo are made from very fine silver threads, which don't take solder very well. I've upgraded my soldering iron to a 30w and still experience the same problem. Do you think I need a more powerful iron?
Yes ! And some soft solder flux. I put some on the cable and it just sucks in the tin. Some tin on the pins and then holding the cable inside or on the pins (depending on thickness). A short heating and everything flows together.
I use a 60W Ersa temperature controlled soldering iron - pays off in the long run. In contrary to other opinions I use very high temperature. Usually about 380°C. Even for semiconductors. This way I only need to heat the tin for a very short time and the surrounding doesn't get so much heat as with a lower temperature iron where you need to heat for a long time. I need less than 2sec. for a cable to a MPX connector. For thick cables and connectors I even go up to 440°C.
RK
rkopka is offline Find More Posts by rkopka
Old Jul 08, 2010, 05:18 AM
Joined Sep 2000
I would have thought doing that once would be lesson enough.
Jürgen
Old Jul 08, 2010, 06:50 AM
flyingrally is offline
Find More Posts by flyingrally
Where did Steve go ?
Alexandra
Joined Jul 2007
And I thought I was hard on the Xeno anyone else see the RCM&E review ?
flyingrally is offline Find More Posts by flyingrally
Old Jul 08, 2010, 07:12 AM
Joined Sep 2000
This issue has already been discussed:
http://www.rcgroups.com/forums/showp...&postcount=687
Jürgen
Old Jul 08, 2010, 12:15 PM
frogbmth is offline
frogbmth's Avatar
Poole, England
Joined Jun 2008
In fact the Xeno in that review is now mine, I bought it off the reviewer.
It CG balanced perfectly with a 1300mah Turnigy LiPo and was well put together. I've since upgraded to the tuning power set though and will pop the standard power set up for sale. It was very efficient and fine for cruising around the field, but struggled a bit aginst strong wind and didn't climb as fast as I wanted. It does not sag after launch for me and the nose tended to rise not drop until I sorted the diff.
I'm loving the Xeno which just goes to show, reviews are an opinion and do not often reflect the satisfaction levels everybody can expect from a model and their individual setup. We all enjoy different things and one person's minor niggle can be another's showstopper. Hat off to the reviewer for not praising a model outright which does become tiresome in magazines with a multi page spread from the manufacturer in question
Andy
Old Jul 08, 2010, 01:57 PM
Joined Sep 2000
Hat off to the reviewer for not praising a model outright ...
Hi Andy,
you don't need to praise a model when it doesn't deserve it and he (or she) can share his/her opinion, but they should still get the facts right.
When I write reviews, I always try to be as objective as possible, providing measured figures like climb rates, sink rates, weights, current consumption, prop rpm, motor-, battery- and ESC temperatures etc.
Jürgen
Old Jul 08, 2010, 06:07 PM
dacaur is offline
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Jürgen
Hehe yea if you do it every day, but just enough time goes by between my soldering connectors to forget, lol...
Old Jul 10, 2010, 01:01 AM
Alexandra
Joined Jul 2007
So what? it can't be discussed again? The issue has only just landed in store for anyone outside of the UK and subscribers.
Jürgen
Old Jul 10, 2010, 01:22 AM
Joined Sep 2000
Oops - DP.
Old Jul 10, 2010, 01:23 AM
Joined Sep 2000
So what? it can't be discussed again?...
Of course you can discuss it again, but facts and figures usually don't change by discussing them.
Jürgen
Old Jul 10, 2010, 02:06 AM
Breitling is offline
Find More Posts by Breitling
Marlborough
Joined Mar 2009
I took my Xeno out last night in about 8mph winds and it was pretty solid. Launching was fine, but I feel it could have done with some more weight in the nose. I am very new to flying, so my experience is minimal. The nose did seem to want to rise a bit when it was flying into wind or when I put the power on, so I decided to land to fit a 1300 lip which would add about 20g to the weight. When I landed (and cartwheeled!) I checked the Xeno over and found that all of the motor mounting screws had come loose, and one had fallen out and was rattling around inside the pod!! This was after about 20 minutes of flying with the tuning set. Is this a common occurrence or have I missed out some washers on the motor?
Breitling is offline Find More Posts by Breitling
Old Jul 10, 2010, 02:09 AM
Alexandra
Joined Jul 2007
But opinions generally do
and as a review is generally somoneones opinion + a few facts a figures ?
Jürgen
New Product Multiplex Xeno checkup Flying Wings 129 Apr 10, 2010 08:47 AM
Yippee! New Multiplex Models 2009: MERLIN and XENO Doubletap Slope 12 Feb 26, 2010 10:31 PM
Discussion XENO, New to Multiplex??? sparkie624 Hitec/Multiplex USA 4 May 27, 2009 06:16 PM
Discussion Multiplex Xeno as FPV JakAck FPV Talk 7 Mar 09, 2009 06:40 PM
New Product Multiplex Xeno soundcheque Flying Wings 2 Mar 03, 2009 09:25 PM
