Old Jun 21, 2010, 08:50 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by flyingrally View Post
I can't find anything on the o ring ? I went back to my kit and don't have any parts left over ? Also I can't see the part in the manual, Could you let me know which ABB (manual picture) it's in ?
Cheers
The drive-set comes with its own manual. There are two O-Rings included (one spare):
http://www.rcgroups.com/forums/showp...&postcount=128
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jun 21, 2010, 09:18 AM
flyingrally is offline
Find More Posts by flyingrally
Where did Steve go ?
Alexandra
Joined Jul 2007
Oh cool so not only did we get shipped the old stock of tune kits but mine came without orings. Sigh....not typical multiplex that's for sure. Think the rings are needed with the esc brake ?
Jürgen
flyingrally is offline Find More Posts by flyingrally
Old Jun 21, 2010, 09:27 AM
GFBurke is offline
Find More Posts by GFBurke
allthingsthatfly.com
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
na.. i wont bother with them. just like any other folder, the wind pushes them back instantly anyways. I don't see the point.
GFBurke is offline Find More Posts by GFBurke
Old Jun 21, 2010, 12:28 PM
Willem01 is offline
Find More Posts by Willem01
Joined Oct 2009
A few things I noticed:
1. The O-Ring which keeps the blades together is missing.
2. The end of the hinge pin needs to be located inside the fuselage, not in the finger hole (check the manual).
3. The front ends of the wing are held together by the canopy as well. Check the inside of the canopy.
Jürgen
Well now, there`s an eye opener.
I already found out that the front fuselage is kept together with the canopy. I did get the O ring (even 2 ). You actually hear the blades snap together in the air.
But I didn`t know that the end of the hinge pin was to be stored inside the fuselage. Took it apart tonight and corrected it. Now it can`t pull any grass along with it.
Thank you Jurgen
The O ring is not needed, even with the brake on. But it makes sure that the blades fold together.
Willem.
Willem01 is offline Find More Posts by Willem01
Old Jun 21, 2010, 01:34 PM
hobie14 is offline
Find More Posts by hobie14
hobie14's Avatar
Western Europe 52.7° N 8.9° W
Joined Jul 2007
Your not the only one who feels that way .......
hobie14 is offline Find More Posts by hobie14
Old Jun 21, 2010, 11:34 PM
Joined Sep 2000
At slow speeds, one blade most likely will be "dangling" down without the O-Ring.
Jürgen
Old Jun 22, 2010, 12:12 AM
GFBurke is offline
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
True, but then that means no real wind resistance if they aren't being pushed.
and they will flap back with the grass.
it would just look better.
Old Jun 22, 2010, 01:35 AM
Joined Sep 2000
Well, it would take quite some drag/force to get the blades into the same position as with the O-Ring installed.
Better looking with O-Ring installed? You bet.
Jürgen
Old Jun 22, 2010, 04:11 AM
Alexandra
Joined Jul 2007
Case of you never know what your missing if you don't know it exists in the first place.
Never seen a blade dangling so in no hurry to correct it.
Finally got a reply from local distributer on new shaft.. now the wait for it to arrive and be shipped out.
Old Jun 22, 2010, 11:41 AM
hobie14 is offline
hobie14's Avatar
Joined Jul 2007
Jürgen
install O ring ..... to look better
Servo's etc underneath to look better .....
where will it all end .....
Old Jun 22, 2010, 01:27 PM
Willem01 is offline
Joined Oct 2009
And I think it already looks great the way it is! But that`s just my 2 cents...
Willem.
Old Jun 27, 2010, 05:02 AM
Breitling is offline
Find More Posts by Breitling
Marlborough
Joined Mar 2009
Took my Xeno out yesterday. Built it in the morning in a couple of hours and was on the slope by the afternoon. Great flyer with the Tuning power set. No balancing or trimming required really except a little to bring the nose down a bit under power. I got the kit with the metal shaft 73 3505 and it works very well. It has a bit of vibration when it's powered up initially, which I presume is to do with the blades spinning out to the correct position?
Breitling is offline Find More Posts by Breitling
Old Jun 27, 2010, 08:25 AM
frogbmth is offline
Find More Posts by frogbmth
frogbmth's Avatar
Poole, England
Joined Jun 2008
Had power loss flying my Xeno today, throttled back to glide in. Found that one of the motor wires I had tucked away had come loose and fouled the motor. I should have put a clip of some sort in to tether the wires, definitely gonna do that now. Lesson learnt.
frogbmth is offline Find More Posts by frogbmth
Old Jun 27, 2010, 01:14 PM
hobie14 is offline
hobie14's Avatar
Joined Jul 2007
drill a small hole in the plastic wall between the motor/battery area's and use a light cable tie to keep the cables on the side wall and away from the motor .........
Old Jun 28, 2010, 02:01 AM
Marlborough
Joined Mar 2009
Sound like a good plan for keeping the cables tidy. I've got some 1300 lipos I'm going to use in mine, so I've ordered some MPX connectors to fit to them. Is it pretty obvious which pins I solder the lipo terminals to?
New Product Multiplex Xeno checkup Flying Wings 129 Apr 10, 2010 08:47 AM
Yippee! New Multiplex Models 2009: MERLIN and XENO Doubletap Slope 12 Feb 26, 2010 10:31 PM
Discussion XENO, New to Multiplex??? sparkie624 Hitec/Multiplex USA 4 May 27, 2009 06:16 PM
Discussion Multiplex Xeno as FPV JakAck FPV Talk 7 Mar 09, 2009 06:40 PM
New Product Multiplex Xeno soundcheque Flying Wings 2 Mar 03, 2009 09:25 PM
