Old Jun 10, 2010, 06:03 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
I want to warn you about this mount.
It looks promising me too, used for a Slinger BL conversion, placed classical in the back, but developed a crack after some hard landings.
Now I replaced with a second one and also shows signs of fatigue, the paint exfoliates in the inflect area.
The metal bend is definitely not done right.
renatoa is online now Find More Posts by renatoa
Old Jun 10, 2010, 06:16 AM
hendrix is offline
Find More Posts by hendrix
Greece, Attica, Piraeus
Joined Jun 2004
Nice to know this Renatoa.
What i have in mind is to build a fiberglass pod and mount everything in it
if the test is successful.
I hope it can stand a couple flights.
The plane will be landing with it's belly with a parachute so my only fear now is not to loose the engine in mid air.
Btw i just mounted a 5000 mah lipo on the plane (it has to be where the old propeller was!!!) and it still looks light to me.
I think it will fly and if my calculations are correct the stream of air from the big propeller will give some authority to the control surfaces at low speeds.
How you Slinger flew?
Ahh i just understood what you meant, you used the motor mount but at the back following the classical pusher configuration.
Chris
hendrix is offline Find More Posts by hendrix
Old Jun 12, 2010, 08:34 PM
GFBurke is offline
Find More Posts by GFBurke
allthingsthatfly.com
GFBurke's Avatar
USA, ID, Meridian
Joined Jan 2007
ready for a maiden
I'll get some close up vids, pics etc.
GFBurke is offline Find More Posts by GFBurke
Old Jun 13, 2010, 01:22 AM
hobie14 is online now
Find More Posts by hobie14
hobie14's Avatar
Western Europe 52.7° N 8.9° W
Joined Jul 2007
First Xeno flights for me yesterday for about two months, while I waited for the metal drive shaft upgrade ..... fitted it and also changed to servo's on top ..... flying great ...... took it up on the slopes and must have had at least 2 hours air time ...... just a photo but must try and get some video next time ..... the new shaft gives a lot of confidence in the power train ........
http://img31.imageshack.us/img31/8312/img0378vi.jpg
hobie14 is online now Find More Posts by hobie14
Old Jun 14, 2010, 07:37 AM
hendrix is offline
Joined Jun 2004
Update on the tractor Xeno.
It flew alright with plenty of power but i screwed up the CG.
The factory CG does not hold true when the motor is in front.
Also the CG is very critical when the weight goes up.
I need to make another pod and move thing to the front.
Chris
Old Jun 14, 2010, 10:17 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
CG position is normally independant from weight. If your boom provides additional lifting area in front of the wing, the CG must be moved forward.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jun 14, 2010, 03:07 PM
Pook is offline
Find More Posts by Pook
Pook's Avatar
Bolton,England
Joined May 2003
With the motor at the front even a tiny change of thrust angle will have a rather larger effect due to the wash over the wings from the prop.
Pook is offline Find More Posts by Pook
Old Jun 14, 2010, 04:14 PM
mopetista is online now
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
Xeno wallowing on the slope
Just posted a video of my stock glider Xeno (4AA NiCd cells) on a slope in less-than-perfect conditions.
http://www.rcgroups.com/forums/showthread.php?t=1260318
Sorry for the mobile phone resolution, one can however still get a good impression what the Xeno will do under conditions one might find not too far from home.
Wallowing is induced either by turbulent wind or by pilot input especially when navigating a rather small space.
It flies best fast with a strong steady wind, but these conditions aren't always easy to come by (for me) so I ordered a Weasel Evo from dreamflight for the smaller slopes. I still believe that the Xeno will be an excellent plane for taking on a hike in the mountains where its size is a big plus when one wants to fly in a bigger space, and the good aerodynamics and considerable weight (even without ballast) make it capable of going quick - then it will also track. The foldable desigh for easier transport in a backpack was the main reason I bought it.
best
Clemens
mopetista is online now Find More Posts by mopetista
Old Jun 16, 2010, 03:17 AM
hendrix is offline
Joined Jun 2004
Jun 14, 2010 06:17 PM
You are both right!
There is additional lift from the boom and indeed the propeller wash makes the airplane very nervous.
Chris
Old Jun 16, 2010, 11:53 PM
Joe Pierson is online now
Find More Posts by Joe Pierson
Joe Pierson's Avatar
USA, CA,
Joined May 2001
Hi Guys,
I am starting on my Zeno today, as I Have received my steel tube, from Germany, now that
is great service surport !! This will keep me bussy while I am waiting for my Fun Cub.
Joe
Joe Pierson is online now Find More Posts by Joe Pierson
Old Jun 17, 2010, 12:31 AM
flyingrally is offline
Find More Posts by flyingrally
Where did Steve go ?
Alexandra
Joined Jul 2007
hi just wondering how you ordered your replacment ?[QUOTE=Joe Pierson;15337251]Hi Guys,
Joe[/QUOTE]
flyingrally is offline Find More Posts by flyingrally
Old Jun 17, 2010, 12:37 AM
USA, CA,
Joined May 2001
Hi flyingrally,
I sent a Email to Germany. It did take a long time, but they came through.
Joe
Old Jun 18, 2010, 05:23 PM
flybear is offline
Find More Posts by flybear
melrose,mt
Joined Oct 2006
How to launch Xeno
I have most of the Multiplex planes and I am interested in a Xeno. How can it be launched without getting my fingers bitten? I launch my other wing by the leading edge.
I am confused about the shaft problems.If I buy one now will it ge upgraded?
flybear is offline Find More Posts by flybear
Old Jun 18, 2010, 05:31 PM
USA, CA,
Joined May 2001
Hi Flybear,
Just throw it with the motor off, like any glider into the wind, then after it leaves your hand
then, turn on the motor Easy! or where a steel glove to protect your fingers!
The new tuning kits should have the new steel shaft, Check with Jurgen Heilig, he should know.
Joe
Old Jun 18, 2010, 05:44 PM
USA, CA,
Joined May 2001
My new Fins
Hi Guys,
Here is a photo of my new fins ready to cover. Also you can see my Servo Mod
with them on the top of the wing. Back to painting, it is going to look very nice!
I will keep a set of the stock fins, and glider canopy with it. It is a very easy build and fun. Multiplex is a great company! That makes great Airplanes
Joe
USA
New Product Multiplex Xeno checkup Flying Wings 129 Apr 10, 2010 08:47 AM
Yippee! New Multiplex Models 2009: MERLIN and XENO Doubletap Slope 12 Feb 26, 2010 10:31 PM
Discussion XENO, New to Multiplex??? sparkie624 Hitec/Multiplex USA 4 May 27, 2009 06:16 PM
Discussion Multiplex Xeno as FPV JakAck FPV Talk 7 Mar 09, 2009 06:40 PM
New Product Multiplex Xeno soundcheque Flying Wings 2 Mar 03, 2009 09:25 PM
