Old May 19, 2010, 04:39 AM
georgebinns is offline
Find More Posts by georgebinns
Multirotors blow
georgebinns's Avatar
Peterborough, England
Joined Dec 2006
Originally Posted by Jurgen Heilig View Post
Hi George,
I am not too sure whether increasing the fin area is such a good idea, especially when flying in cross wind turbulence, i.e. slope soaring.
Control linkages on top are better, except from an aesthetics point of view.
The CRP drive shaft is only good for the basic drive. On the Tuning drive it will fail - no matter how well aligned.
Jürgen
With all due respect Jürgen, a flying wing that "wallows" is not right by anybodys standards - especially when it is so easy to fix. If it is too much for the slope, order a spare set of standard fins to use there!
Control linkages on top - no brainer - end of argument!!!! Even the wing folds better!!!
My second carbon shaft (broke my first one when the prop caught my finger on launch with power on) is just fine after 50+ flights launching power off on my tuning set motor so don't see the problem - unless you touch the ground while the props are still spinning then it is likely to break or fracture as yours did.
[/QUOTE]I like the curves of the Xeno, whats the old saying.....if it looks good it will fly good. Time will tell.[/QUOTE]
Dusty - go fly and enjoy the Xeno - it is a lovely smooth model when set up correctly.
George.
georgebinns is offline Find More Posts by georgebinns
Old May 19, 2010, 05:54 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Hi George,
have a look at my video. Do you see any "wallowing"?
My carbon shaft started to develop a hairline fracture during the 5th flight and I replaced it, before the condition got worse. The prop never touched the ground while spinning and I used soft start and soft brake with the original ESC. You must be very lucky to still fly your CRP shaft.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old May 19, 2010, 03:13 PM
frogbmth is offline
Find More Posts by frogbmth
frogbmth's Avatar
Poole, England
Joined Jun 2008
I bought a secondhand Xeno this week, looking forward to taking it out this weekend. Thanks to everybody who posted their experiences and advice in this thread, it's awesome
Andy
frogbmth is offline Find More Posts by frogbmth
Old May 20, 2010, 06:19 AM
Multirotors blow
Joined Dec 2006
Hi George,
Jürgen
Jürgen, It's hard to see the "wallowing" from the ground, I accept that - but it is very obvious if to fit a camera on the nose! As I intend to use the airframe for FPV work I needed to fix the problem. As an added bonus, with the bigger fin area you can really crank it round at low speeds and it won't side slip out of the sky. I like to do very slow and low figure of eights in front of me and with the original fins it was almost impossible.
I'm going away for a couple of days but when I get back I will post some great video I took the other day of me doing this maneuver - great fun.
George.
Old May 20, 2010, 06:37 AM
fpvnick is offline
Find More Posts by fpvnick
My other vehicle is unmanned
fpvnick's Avatar
Joined Jan 2010
Had my 1st FPV Crash yesterday evening! I was flying low down this small gravel track in between the trees ether side and miss judged my speed / spacing between trees when i pulled out woops tree! felt a bit like Luke skywalker till it all went wrong. couple of dents to the left hand leading edge near the center but not to bad everything else survived im glad i added the carbon rods. that will teach me not to be to adventures.
fpvnick is offline Find More Posts by fpvnick
Old May 21, 2010, 02:48 AM
magrinsi is offline
Find More Posts by magrinsi
magrinsi's Avatar
Florence Italy
Joined Dec 2009
motor news
Assembly with little lipo 4s 1300 mah and 1400 kv 45gr brushless 25A
Fast...
Uploaded with ImageShack.us
magrinsi is offline Find More Posts by magrinsi
Old May 21, 2010, 03:19 AM
fpvnick is offline
fpvnick's Avatar
Joined Jan 2010
paint job looks great and a nice compact motor mount very clean build have you got any videos?
Old May 21, 2010, 04:14 AM
magrinsi is offline
magrinsi's Avatar
Florence Italy
Joined Dec 2009
tomorrow...may be
Old May 23, 2010, 08:08 PM
DustyPockets is offline
Find More Posts by DustyPockets
A fool in a field.
United States, IL, Mahomet
Joined Dec 2006
All done, one flight on it with a fixed prop. Added the folder tonight but fairly windy so I will save it for another day. First flight was with a 1300 Mah and balanced well. Added a motor cover I salvaged from some unknown project and moved the ESC under it. I may need a 1800 to correct the CG, but not too worried about the weight as it does have a somewhat big wing area.
DustyPockets is offline Find More Posts by DustyPockets
Old May 24, 2010, 03:37 AM
fpvnick is offline
fpvnick's Avatar
Joined Jan 2010
my xeno still fliyed great with 2300mAh 3 cell lipo so i dont think you will need to worry about the weight
Old May 24, 2010, 09:09 AM
Sleurhutje is offline
Find More Posts by Sleurhutje
Sleurhutje's Avatar
Netherlands
Joined Sep 2008
My Xeno weights 970 grams AUW, 3S 2000mAh Graupner LiPo and Turnigy 3530-1450kV with Aeronaut Carbon 9x6" folding prop. Still unlimited vertical (oky, it drains the battery pretty fast ).
Sleurhutje is offline Find More Posts by Sleurhutje
Old May 24, 2010, 12:22 PM
A fool in a field.
Joined Dec 2006
2 flights with the folder this morning. The 1800 works ok perhaps a bit tail heavy, right at the edge of the recommended CG by MPX. Glides well.......3 go arounds at the local soccer field to get her in.
Old May 24, 2010, 02:22 PM
Trunks is offline
Find More Posts by Trunks
Joined Jul 2007
I just received my steel rod which replace the carbon rod. Anyone here get their hollow steel rod?
Trunks is offline Find More Posts by Trunks
Old May 25, 2010, 02:16 AM
Joined Sep 2000
Strange: I thought I had read about other guys receiving their steel tubes, but I can't find their posts?
Jürgen
Old May 25, 2010, 12:44 PM
hobie14 is offline
Find More Posts by hobie14
hobie14's Avatar
Western Europe 52.7° N 8.9° W
Joined Jul 2007
Jürgen
Mine is in the country .....
just have to get over to my LHS and pick it up ....
hobie14 is offline Find More Posts by hobie14
New Product Multiplex Xeno checkup Flying Wings 129 Apr 10, 2010 08:47 AM
Yippee! New Multiplex Models 2009: MERLIN and XENO Doubletap Slope 12 Feb 26, 2010 10:31 PM
Discussion XENO, New to Multiplex??? sparkie624 Hitec/Multiplex USA 4 May 27, 2009 06:16 PM
Discussion Multiplex Xeno as FPV JakAck FPV Talk 7 Mar 09, 2009 06:40 PM
New Product Multiplex Xeno soundcheque Flying Wings 2 Mar 03, 2009 09:25 PM
