Netherlands, NH, Edam
Joined Jul 2004
Cheers, Sander. |
![]() *still thinking about one or two EDF's on top*
The Hague, Netherlands
Joined Nov 2006
Just dropped my Xeno in the trunk; will do some flying after work tomorrow. Will check the c.o.g. and "how" vertical mine will go with the 140-150W setup. Didn't configure the setup for vertical by the way. Last week on the first flight I did notice a slight wobble, but perhaps because my Xeno is relative light, it's not a real issue.
Will post results tomorrow; 'glad I didn't buy the powersetup ;-) |
Joined Nov 2006
Did some flights today. I like the plane, but I don't think it will be my favourite to bring to the club; had a little bit more fun with my Gemini today. The Xeno will be the one to take to the slope, on holiday etc.
The setup works fine; can't do vertical climbs, but that's not what I intended. Re-measurement showed that I'll need an extra of about 20g weight in the front to get de c.o.g. exactly on the second spar (you can easely use some kind of thin rope/wire and "loop" that through the rod that is used as hinge between the fuse-halves). Total weight of the ballast with the limited powertrain in the back will be in this case 45g. Is the c.o.g. exactly on the spar really needed, or can it be a little more afterwards? With the current amount of weight, the Xeno flies ok, but because of the wind this afternoon it was difficult to tell I still could improve significantly. Edit: AUW is now 800g, so will be 820g with extra weight, which is almost equal to the Tuningkit I presume... |
I've been watching this model for awhile now. I really like its aerodynamic shaping and of course being made out of very dependable Elapor foam, but I am not at all crazy about the "tuning power" setup. It is way, way overpriced IMHO. That was one of the reasons why I have not bought the plane. The wobbling in flight I can easily fix with larger fins/winglets etc... Any way I was brainstorming last night about just getting the Xeno, but without the power kit, while making my own motor mount. I was going over the spare parts list for the Parkzone Stryker and noticed its motor mount. The motor mount is a clamp down one that *might* work on the Xeno. For me, being able to fold the plane in half is a gimmick and is not necessary. What do you guys think, I already own all of the electronics/radio gear/batteries etc, but was being held back with the Multiplex power setup. Do you think the Stryker's motor mount could work on this plane with some modifications? If so, I would thumb my nose at Multiplex!
Motor mount: http://secure.hobbyzone.com/PKZ4234.html |
Joined Nov 2006
For a start: if you mount a 45g outrunner far in the tail with a very light motormount (carbon, cnc’d) and a folding prop, you’ll need a lipo of about 160g in the front to achieve the right c.o.g. (I have 1050 mah Rhino’s, so I needed about 50g weight as far as possible in the front). In this case, you’re AUW will be comparable with the Tuning-setup (with smaller lipo), which has a bit more power.
So: - a motor in the tail (even a relative light setup, 100-150 W) will almost certainly make the Xeno at least as heavy as with the Tuning-setup (using the recommended lipo), because you’ll need more weight in the nose (bigger lipo or lead) - if you want power and don’t want to go too heavy, you’ll have to place the motor more forward. In that case the Tuning-setup is an option, but expensive and with a fragile shaft - if you want more power in the tail, the weight needed in the nose will be much, much more, making the AUW 10-20% more compared to the Tuning-setup best regards, Dennis |
You will love flying it Nick but you will probably want to make the fin mod at least to make it really handle well.
I'm going to fit some FPV gear into mine in the next week or so. Got most of the bugs ironed out on my EZ* and it's now flying well with the RVOSD computer - even flew it FPV today in a gusty 15mph wind. It was difficult making headway into wind but managed to land it on our strip which was behind a barn from where I was sitting - almost lost the video link though ![]() George |
George, i will defiantly be making some kind of mod to the fins they do look very small. The fins on my funjet look like they would work well but i will try a more locost solution instead of getting a set of replacement funjet items.
Sander, when you say "- moved fins to the tips and angled slightly inwards." i take it you mean the front tips are closer together than the back edge? what is your thinking behind this dose it add a more positive (self centering feel) in flight a bit like toe on a car ? |
Joined Jul 2004
Cheers, Sander. |
| Thread Tools | |
| New Product Multiplex Xeno | checkup | Flying Wings | 129 | Apr 10, 2010 08:47 AM |
| Yippee! New Multiplex Models 2009: MERLIN and XENO | Doubletap | Slope | 12 | Feb 26, 2010 10:31 PM |
| Discussion XENO, New to Multiplex??? | sparkie624 | Hitec/Multiplex USA | 4 | May 27, 2009 06:16 PM |
| Discussion Multiplex Xeno as FPV | JakAck | Video Piloting (FPV/RPV) | 7 | Mar 09, 2009 06:40 PM |
| New Product Multiplex Xeno | soundcheque | Flying Wings | 2 | Mar 03, 2009 09:25 PM |
