Old Mar 17, 2010, 03:00 PM
hobie14 is offline
Find More Posts by hobie14
hobie14's Avatar
Western Europe 52.7° N 8.9° W
Joined Jul 2007
Originally Posted by Jurgen Heilig View Post
Recommended to Multiplex to add a new alu adapter when sending replacement shafts - to avoid burnt fingers.
Jürgen
Well done Jurgen .... every replacement shaft should come with a new shaft to motor adaptor ......
You may remember I had to replace my CF shaft after a handfull of flights ..... it was a pain in the $$$ to get the old shaft out of the adaptor .... I ended up using a vice ..... a small blow torch and a set of Mole Grips ...... Oh, and a suitable drill and 1.5mm bit to free up the vent hole in the adaptor .....
I really should stop using high quality Epoxy ....
hobie14 is offline Find More Posts by hobie14
Old Mar 20, 2010, 01:37 PM
popad is offline
Find More Posts by popad
RC Paramotor Pilot
popad's Avatar
Brasov, ROMANIA
Joined Aug 2008
Hi,
how to build a landing gear for xeno wing ?
Have you any idea ?
popad is offline Find More Posts by popad
Old Mar 20, 2010, 05:27 PM
ZamBeZi is offline
Find More Posts by ZamBeZi
The Hague, Netherlands
Joined Nov 2006
Finished my own carbon motormount in KD-style. Took some time because the guy where I cnc'd the parts by accident used 2 mm GFK instead of 1,5 mm. I then ordered 1,5 mm carbon at Hobbycity; very nice and very cheap.
I'm very happy with the results so far; very solid and looks really professional - 'will post some pictures when everyting is ready.
ZamBeZi is offline Find More Posts by ZamBeZi
Old Mar 21, 2010, 06:48 AM
Sleurhutje is offline
Find More Posts by Sleurhutje
Sleurhutje's Avatar
Netherlands
Joined Sep 2008
Have you any idea ?
Also had some thoughts about that. You need pretty long legs since the prop is mounted on the read of the wing. And long legs provide an awful lot of drag. So I was thinking about retracts like these at HC. Enough ground clearance for a 9" diameter propellor. But the project got cancelled because it will snap the retracts when landing on a bumpy grassfield like our clubs airfield.
Weather is looking great today (at last). No excuses...
Sleurhutje is offline Find More Posts by Sleurhutje
Old Mar 21, 2010, 02:26 PM
popad is offline
RC Paramotor Pilot
popad's Avatar
Brasov, ROMANIA
Joined Aug 2008
Landing Gear for XENO
Thanks Sleurhutje,
I think something simple that can be add or remove.
With some thin weels I think than aerodinamique will be not affected very much.
Old Mar 21, 2010, 05:52 PM
ZamBeZi is offline
Joined Nov 2006
Well; I have a few things to do to the airframe and I'm waiting for a few centimeters copperwire as extension between the motor and esc. Maybe next weekend!
Just fired up the Hyperion outrunner for the first time; 12 Ah with the Aeronaut 9x5 folder. Should be enough, but I'll order the 10x6 sometime. The motormount and carbon prophub (own design) works perfect; everything is extremely light, solid and the folding prop works without significant vibrations...
Old Mar 22, 2010, 06:10 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Thanks Sleurhutje,
That kind of landing gear would not provide enough ground clearance for the model to rotate without the prop hitting the ground.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Mar 22, 2010, 01:40 PM
Sleurhutje's Avatar
Netherlands
Joined Sep 2008
152mm should be enough for a 10" prop. So with a 9" prop plenty of clearance. The prop isn't in the middle of the wing but even a little higher.
Old Mar 22, 2010, 02:36 PM
ZamBeZi is offline
Joined Nov 2006
yeah, but I think you need the nose to point a little upwards, which compensates that
if the purpose of a lg is only preventing bloody fingers, you'll better consider a bungee
Old Mar 22, 2010, 03:26 PM
Joined Sep 2000
Why would you need a bungee for a glider? If you are afraid of the prop, just launch with the motor off and it on at a safe distance.
I can throw my Xeno and fly a 360° circle without any motor power at all.
Jürgen
Old Mar 22, 2010, 03:45 PM
ZamBeZi is offline
Joined Nov 2006
Jürgen
Agree, but I can't think of any other reason why somebody considers a lg on a Xeno
Old Mar 22, 2010, 05:15 PM
popad is offline
RC Paramotor Pilot
popad's Avatar
Brasov, ROMANIA
Joined Aug 2008
I think the lg only for landing on ground. Not for take-off.
How you landing on the ground ?
If there good grass on field, it's ok, without lg.
In this case the nose to point a little down it's ok.
Old Mar 23, 2010, 01:54 AM
Joined Sep 2000
Just add a little padding on the bottom of the fuselage when you don't have grass to land on and don't point the nose down when landing.
Jürgen
Old Mar 23, 2010, 06:49 AM
popad is offline
RC Paramotor Pilot
popad's Avatar
Brasov, ROMANIA
Joined Aug 2008
Thanks, good tips, Jürgen.
Old Mar 23, 2010, 11:11 PM
pyy1axs is offline
Find More Posts by pyy1axs
Abe
United States, IL, Chicago
Joined Nov 2007
I bought this plane and I have no idea what to do with it. Based on this thread, clearly there isn't an inarguable best solution that results in precision and performance... unless one performs unique re-engineering... the cross supports without the shaft seems like the only viable solution. I wish it came in a box as I'm not yet retired...
pyy1axs is offline Find More Posts by pyy1axs
New Product Multiplex Xeno checkup Flying Wings 129 Apr 10, 2010 09:47 AM
Yippee! New Multiplex Models 2009: MERLIN and XENO Doubletap Slope 12 Feb 26, 2010 11:31 PM
Discussion XENO, New to Multiplex??? sparkie624 Hitec/Multiplex USA 4 May 27, 2009 07:16 PM
Discussion Multiplex Xeno as FPV JakAck FPV Talk 7 Mar 09, 2009 07:40 PM
New Product Multiplex Xeno soundcheque Flying Wings 2 Mar 03, 2009 10:25 PM
