Old Dec 01, 2009, 04:38 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by alex.guzun View Post
does it came with a kit, or you should buy it for extra money
What exactly is your question? There are two drive system sets for the Xeno. Standard, with a 20A ESC, Himax C 2212-1180 and a 8x5" folding prop, and Tuning, with a 30A ESC, Himax C 2816-1220 and a 9x6" folding prop.
If you want to use your own ESC and motor, you need to buy all the necessary parts individually.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Dec 01, 2009, 05:16 AM
alex.guzun is offline
Find More Posts by alex.guzun
iCharger 106B user
Lab, Slovak Republic
Joined Jun 2008
that was my question... thanks
when i buy Xeno i'l will not get any props or shaft at all? so i need also to buy 22 4111 (can't find a price )
alex.guzun is offline Find More Posts by alex.guzun
Old Dec 01, 2009, 05:55 AM
Joined Sep 2000
The Xeno kit includes only the components for the glider/sloper version.
You need M 332654 for the standard drive system, or M 332655 for the tuning drive system.
M 22 4111 is just the plastic parts for the "motorized Xeno"
Jürgen
Old Dec 01, 2009, 06:00 AM
Joined Sep 2000
Originally Posted by Xpress.. View Post
Neat
I wanna see this thing fly too
Well, there has already been a video of the prototype available on Youtube since 13. August:
Multiplex Xeno (1 min 0 sec)
Jürgen
Old Dec 01, 2009, 06:05 AM
iCharger 106B user
Joined Jun 2008
Jürgen
These are full Xeno power set # 33 2654 and Xeno Tuning power set # 33 2655
But i wish to use my own esc and motor, what should i buy then?
Old Dec 01, 2009, 06:56 AM
Joined Sep 2000
In this case, you would need:
- Drive cowling # 22 4108
- Canopy # 22 4109
- Plastic parts # 22 4111
- Drive shaft with collets for Ø 3mm/4mm motor shafts # 73 3505
- Spinner assembly Ø 35 mm, with blade holder and adapter # 73 3504
- Folding prop 9x6" # 73 3492
Assuming all these parts are already available, expect to pay approx. €70.-
Jürgen
Old Dec 01, 2009, 07:00 AM
iCharger 106B user
Joined Jun 2008
damn.. too much.
Xeno is flying away from me i'm saaad
Old Dec 01, 2009, 07:10 AM
Joined Sep 2000
damn.. too much.
You could of course build something yourself (like the Robbe's Sportwing drive: http://www.hobbydirekt.de/images/pro...s/RH1-3284.jpg), but it's not really the same as an integrated solution.
Jürgen
Old Dec 01, 2009, 07:43 AM
iCharger 106B user
Joined Jun 2008
yes
i think Plastic parts # 22 4111 will be enough for me to make it electric.
Old Dec 01, 2009, 07:52 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Extra, excerpt from documentation:
"...power set assembly, # 33 2654 / # 33 2655 - parts not included in the kit!...
renatoa is online now Find More Posts by renatoa
Old Dec 01, 2009, 07:57 AM
Joined Sep 2007
I intended it for FPV purpose, but it seems not the right wing, based on the new findings.
Glad I switched last week to other model, mainly because the local MPX dealer told me no chances for this year.
If you mount the motor in the back, you would need a lot of extra weight in the nose to achieve the correct CG. If you wanted to fly without motor at the slope, you would have to remove the additional weight.
The idea behind the "power pod" with motor shaft extension is a very quick "configuration change" without having to re-adjust the CG.
Jürgen
Old Dec 01, 2009, 11:16 AM
kepople is offline
Find More Posts by kepople
Real Men Fly Pink Planes...
kepople's Avatar
United States, TX, Rockwall
Joined Jun 2001
I was wondering if you could run some CF across the wing and convert it to a DLG?
Saving that, I wonder if you could make this bird a screamer with a mega 16/15 3
kirby
kepople is offline Find More Posts by kepople
Old Dec 01, 2009, 11:42 AM
Joined Sep 2000
kirby
Put that motor in a Projeti and you have a screamer. The Xeno is much bigger and therefore has much more drag than the Projeti.
Jürgen
Old Dec 01, 2009, 12:01 PM
kepople is offline
kepople's Avatar
Joined Jun 2001
What I would really like to do is set it up with a Really light power system. I have a Twin Jet with two Micro Dan speeds on it, and its so light I can elevator it down inverted, also cruse mid field at 1/2 throttle, pull vertical, add power and it accelerates on the upline.
Is the Xeno the same size as a Zagi?
What about the DLG idea?
Old Dec 01, 2009, 01:14 PM
Joined Sep 2000
The standard Zagi has a wingspan of 48" and a wing area of 2.03 sq ft.
The Xeno has a wingspan of 49", but a wing area of 3.55 sq ft.
I think the Xeno would be too heavy for DLG.
Jürgen
New Product Multiplex Xeno checkup Flying Wings 129 Apr 10, 2010 08:47 AM
Yippee! New Multiplex Models 2009: MERLIN and XENO Doubletap Slope 12 Feb 26, 2010 10:31 PM
Discussion XENO, New to Multiplex??? sparkie624 Hitec/Multiplex USA 4 May 27, 2009 06:16 PM
Discussion Multiplex Xeno as FPV JakAck FPV Talk 7 Mar 09, 2009 06:40 PM
New Product Multiplex Xeno soundcheque Flying Wings 2 Mar 03, 2009 09:25 PM
