Old Nov 29, 2009, 01:22 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by hobie14 View Post
Jurgen ..... can it take a larger battery than the 950 mAh lipo in the specification ...... It seems very small? .....
Depending on the shape of the battery, a 3s 1300 - 1500mAh should not be a problem.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Nov 29, 2009, 01:51 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Originally Posted by Jurgen Heilig View Post
For slope soaring, I don't the additional weight will be such a problem, but I inititally I thought the Xeno would be a nice competitor against my Sport Wing:
http://www.rcgroups.com/forums/showthread.php?t=1107042
At twice the weight I don't think it can get anywhere near the HLG- and thermal performance of it, but we'll see.
Jürgen
I still think it'll be a good HLG for lighter lift
Xpress.. is offline Find More Posts by Xpress..
Old Nov 29, 2009, 03:17 PM
Joined Sep 2000
At least the decor is light: Only 2.1g per wing half.
Jürgen
Old Nov 30, 2009, 03:07 PM
alex.guzun is offline
Find More Posts by alex.guzun
iCharger 106B user
Lab, Slovak Republic
Joined Jun 2008
what esle do i need to fly it? i saw some shaft assembly from motor to the spinner, does it come with a kit, if not... can i use regular setup?
alex.guzun is offline Find More Posts by alex.guzun
Old Nov 30, 2009, 03:26 PM
Thekid3418 is offline
Find More Posts by Thekid3418
The Kid
Thekid3418's Avatar
Detroit, MI
Joined Dec 2007
So whats going to be the fastest Xeno???? Neu motors anyone?
Just kidding Jurgen
Thekid3418 is offline Find More Posts by Thekid3418
Old Nov 30, 2009, 07:06 PM
cmulder is offline
Find More Posts by cmulder
Ireland
Joined Apr 2001
i wonder if you have no problem with the wing being single piece how low you could go leaving the plastic parts out (just buy the elapor parts)
Then you might be able to end up with a fairly light wing wich should be more durable as that mini zagi thing from years ago.
Anyway i see kit bashing potentional
cmulder is offline Find More Posts by cmulder
Old Dec 01, 2009, 12:03 AM
Joined Sep 2000
Originally Posted by cmulder View Post
i wonder if you have no problem with the wing being single piece how low you could go leaving the plastic parts out (just buy the elapor parts).
Buying just the Elapor parts does not seem to be a viable option.
The complete kit at www.hoellein.com costs €55.90
Looking at the spare parts:
Wings: €22.90
Fins: €9.90
Plastic parts: €20.50
It would be better to buy a kit, and leave the parts off you don't want.
Leaving the center section off might save you 100g or so, but you would also lose a feature, which makes this wing so attractive: Easy transportation and storage, glider/motor-model change in seconds.
Jürgen
Old Dec 01, 2009, 12:05 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Originally Posted by Pook View Post
I still wonder why they decided to put so much plastic in the Xeno, seems like an odd choice combined with the "unbreakable" foam. I guess that also hurts the weight problem.....well not so much of a problem for the electric version I imagine.
All that plastic is the "foldable" part from this wing features.
renatoa is online now Find More Posts by renatoa
Old Dec 01, 2009, 12:17 AM
Joined Sep 2000
Plus the removable fin features, canopy and linkage protectors.
Jürgen
Old Dec 01, 2009, 01:41 AM
Joined Sep 2007
I find very weird it has no main spar / wing reinforcement...
Wondering what gives the overall strength
Old Dec 01, 2009, 03:13 AM
Joined Sep 2000
Look at the center section: There are two short spars going into the roots of the Elapor wings, the wings have a firm fit and adequate area to be glued to the plastic center parts. There are also two additional carbon spars embedded in the bottom of the wings.
Jürgen
Old Dec 01, 2009, 03:20 AM
iCharger 106B user
Joined Jun 2008
Jürgen? what about that shaft form motor to spinner. Is it mandatory?
Old Dec 01, 2009, 03:23 AM
Joined Sep 2007
Me to wondering about alternate ways to mount a motor in the back, without sacrificing foldability
Old Dec 01, 2009, 03:41 AM
Joined Sep 2000
If you mount the motor in the back, you would need a lot of extra weight in the nose to achieve the correct CG. If you wanted to fly without motor at the slope, you would have to remove the additional weight.
The idea behind the "power pod" with motor shaft extension is a very quick "configuration change" without having to re-adjust the CG.
Jürgen
Old Dec 01, 2009, 03:53 AM
iCharger 106B user
Joined Jun 2008
does it came with a kit, or you should buy it for extra money
New Product Multiplex Xeno checkup Flying Wings 129 Apr 10, 2010 08:47 AM
Yippee! New Multiplex Models 2009: MERLIN and XENO Doubletap Slope 12 Feb 26, 2010 10:31 PM
Discussion XENO, New to Multiplex??? sparkie624 Hitec/Multiplex USA 4 May 27, 2009 06:16 PM
Discussion Multiplex Xeno as FPV JakAck FPV Talk 7 Mar 09, 2009 06:40 PM
New Product Multiplex Xeno soundcheque Flying Wings 2 Mar 03, 2009 09:25 PM
