Old Dec 21, 2009, 01:56 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by Franz2002_01 View Post
how do you guys start the XENO? are you throwing it with engine running overhead or are you letting it go by releasing it by throwing it like a DLG?
If you look at the bottom of the Xeno, you can see two "pockets" and a finger hole:
http://static.rcgroups.com/forums/at...g?d=1261074968
I launch my Xeno with motor off.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Dec 21, 2009, 04:07 AM
hobie14 is offline
Find More Posts by hobie14
hobie14's Avatar
Western Europe 52.7° N 8.9° W
Joined Jul 2007
Originally Posted by austin13 View Post
Hobie 14 thank you very much for the tip on safety barrier tape. How long would you typically put ? the target is to do combat with this : does it break easily in combat when a prop gets into it ? thanks
Austin ..... I run my Superfly with one metre (say 40 inches) tapes ...... I did run equally well with 2 or even 3 metres of 12mm wide tapes but the shorter tapes give me all I need for orientation etc .....
I have to confess I don't fly Combat ...... however, thinking further about it I do suspect the Safety tape will not break and thus is highly likely to bring down both planes ....
Sounds like some sort of Paper streamer would be better .....
hobie14 is offline Find More Posts by hobie14
Old Dec 21, 2009, 04:34 AM
alex.guzun is offline
Find More Posts by alex.guzun
iCharger 106B user
Lab, Slovak Republic
Joined Jun 2008
Jürgen, could you please measure the length of that carbon drive shaft?
alex.guzun is offline Find More Posts by alex.guzun
Old Dec 21, 2009, 04:38 AM
austin13 is offline
Find More Posts by austin13
Failure is an option !
austin13's Avatar
Marseille - France
Joined Nov 2007
exactly 16 cm (when not broken )
austin13 is offline Find More Posts by austin13
Old Dec 21, 2009, 04:40 AM
iCharger 106B user
Joined Jun 2008
got a xeno and waiting for 224111, so gonna buy some Savage dogbone (if it is long enough), it is made of hard steel.
Old Dec 21, 2009, 06:24 AM
iCharger 106B user
Joined Jun 2008
not long enough
need this
http://www3.towerhobbies.com/cgi-bin...?&I=LXEAC3&P=7
or this
http://www3.towerhobbies.com/cgi-bin...?&I=LXRTN7&P=7
Old Dec 21, 2009, 06:42 AM
Joined Sep 2000
A titanium shaft doesn't come cheap:
http://www.titan-concept.eu/catalog/...hp?cPath=50_39
€12.- for a 200mm rod (plus p&p)
Jürgen
Old Dec 21, 2009, 06:46 AM
iCharger 106B user
Joined Jun 2008
steel shaft rod from hw store
i'll see
Old Dec 21, 2009, 08:38 AM
hendrix is offline
Find More Posts by hendrix
Greece, Attica, Piraeus
Joined Jun 2004
Jürgen
After spending 130 Euros for the standard motor kit 12 Euros look cheap enough
Thanks for the link i will get me one as i don't want to loose the prop in the air.
I imagine that a 10 Inch prop that barely fits between the rudder fins will do a lot of damage on the elapor if it gets loose.
Chris
hendrix is offline Find More Posts by hendrix
Old Dec 21, 2009, 08:49 AM
Joined Sep 2000
Chris
In case of the collet losing grip on the shaft, I would expect the prop to lose rpm, fold, and fall off the end of the plane.
Jürgen
Old Dec 21, 2009, 08:53 AM
iCharger 106B user
Joined Jun 2008
If you move the motor to the top end of the xeno, how the COG will be shifted?
Old Dec 21, 2009, 09:02 AM
Joined Sep 2000
Depends on the weight and the position.
Jürgen
Old Dec 21, 2009, 09:10 AM
hendrix is offline
Joined Jun 2004
i'll see
I think this will be way too heavy.
Aluminium or titanium i think will be acceptably light.
Btw Jurgen i was amazed from the solution given for the blade folding mechanism.
The trick with the rubber is very good indeed and i was wondering if you know any type of spinner that has a blade folding mechanism as standard.
After seeing what a simple rubber band can do i know think that all folding prop spinners should have this as an option or standard.
In any case i will convert all mine (where applicable of course) by fitting springs.
Chris
Old Dec 21, 2009, 10:08 AM
iCharger 106B user
Joined Jun 2008
let say the motor from your power kit, and place it next to spinner.
Old Dec 21, 2009, 01:00 PM
Joined Sep 2000
Apart from the fact, that the 28mm outer diameter outrunner would not fit into the narrow end of the drive pod, you would need additional 75g ballast in the nose.
Jürgen
New Product Multiplex Xeno checkup Flying Wings 129 Apr 10, 2010 08:47 AM
Yippee! New Multiplex Models 2009: MERLIN and XENO Doubletap Slope 12 Feb 26, 2010 10:31 PM
Discussion XENO, New to Multiplex??? sparkie624 Hitec/Multiplex USA 4 May 27, 2009 06:16 PM
Discussion Multiplex Xeno as FPV JakAck FPV Talk 7 Mar 09, 2009 06:40 PM
New Product Multiplex Xeno soundcheque Flying Wings 2 Mar 03, 2009 09:25 PM
