Old Nov 27, 2009, 06:04 PM
jethead is offline
Find More Posts by jethead
jethead's Avatar
danielsville,pa
Joined Jul 2007
Js 1400 and js 1400 for 90mm fans
I just ordered both of these motors the sale was to good. The 1400 for 70mm fans has a nice long adapter but why doe's the 1400 for 90mm fans not have this ? Is it not needed? Can you buy an adapter for this motor and where?
jethead is offline Find More Posts by jethead
Old Dec 14, 2009, 06:51 PM
PlaneCrazee is offline
Find More Posts by PlaneCrazee
Burner!!
PlaneCrazee's Avatar
United States, AR, Sherwood
Joined Jun 2005
Most 70mm fans are designed to fit a 28mm motor max and the JS 1400 has a bell that's larger. Most 90mm fans accept 36mm. I don't work for them or even own one yet but that is most likely the reason for the adapter, so they can fit a big honkin' motor in a 70mm fan. Getting the bell into the cooling flow is also a plus but the negatives are the long shaft and the greater weight. The 1400 is not a high power setup for a 90 so it wouldn't be worth the cooling advantage. Maybe they will adapt the Extreme Scream for 90mms!?? Now that would be a high power set up.
PlaneCrazee is offline Find More Posts by PlaneCrazee
Old Dec 20, 2009, 01:26 PM
jethead is offline
jethead's Avatar
danielsville,pa
Joined Jul 2007
My mistake the ls motor I'am talking about is the ls 1490,when bought from hl the list it as 1400 for 90mm fans I think the kv is 1830 with 7 pounds of thrust.
Help! need output numbers for JS 1400,Hoffman storm 70 INCARUS Electric Ducted Fan Jet Talk 2 Nov 01, 2009 09:26 PM
Wanted JS 1400 and FAn INCARUS Aircraft - Electric - Power Systems (FS/W) 1 Oct 31, 2009 07:53 PM
Discussion JS-1400 rewind for 6 cell and 800 Watts mrblucor Electric Motor Design and Construction 3 Sep 22, 2009 05:59 PM
Discussion Jetscreamer 1400 for 90mm fans kevin Electric Ducted Fan Jet Talk 38 Aug 19, 2009 10:01 AM
