This thread is privately moderated by sylair, who may elect to delete unwanted replies.
Old Nov 27, 2009, 01:04 AM
sylair is offline
Find More Posts by sylair
Trader Rating: 39
Toledo, Ohio
Joined Apr 2003
Trader Rating: 39
For Sale
22 inch EPP wing Kit w/3000kv, 24 gm brushless motor, APC Prop, can be FAST, ON SALE
This is a KIT Designed for speed and has been flying since late 2006.
The X-22 is our brushless 22 inch high-speed wing kit which includes a 24gm 3000kv brushless CD ROM and an APC 4.1x4.1 prop for some great speeds. Flown for over 2 years with the Johnson 250 motor, , this new brushless upgrade provides lighter, faster and more powerful handling for a remarkable increase is speed and overall performance.
The uniquely shaped high speed airfoil allows the X-22 to fly faster than most similar sized wings when using the same power setup. It has been clocked at an average, upwind/downwind,level approach speed of 105 mph, using the Wicked Jr 3000kv motor(www.donsrc.com) and a 4x4.75 (cutdown) prop.
Flies slow,if you want and has nice stretched out glides for landings. Very aerobatic and smooth handling at all speds. Also tracks nicely. Has blurring rolls, endless loops from level and unlimited vertical flight.
The kit also includes CNC cut high density EPP foam cores(for those brushless high-speed strikes), a Slofly 8mm aluminum CD Rom tube mount, a 3 mm prop saver and all other parts needed to build the wing except glues and radio gear.
The parts are of top quality materials and are pre-cut for quick assembly. It requires about one evening to complete the build. You only need to supply glue, radio gear, battery and standard building tools.
The motor operates on 2 or 3 cell lipo packs and requires a 20A ESC.
More info: sylair@aemail4u.com
SALE price: $42.95 (Plus S&H)
Also uBro Mini E/Z pushrod connectors
are available to urchase.
sylair is offline Find More Posts by sylair
Old Nov 27, 2009, 02:51 AM
7up is offline
7up
Find More Posts by 7up
Trader Rating: 120
7up
,ɯǝ ʇoƃ ɐʎ ɟı ,ɯǝ ǝʞoɯs
7up's Avatar
USA, KY, West Liberty
Joined Jun 2001
Trader Rating: 120
Your kit info and pics link doesn't work.
7up is offline Find More Posts by 7up
Old Nov 27, 2009, 04:14 PM
sylair is offline
Trader Rating: 39
Toledo, Ohio
Joined Apr 2003
Trader Rating: 39
Thanks 7up, we're checking that out. If you wanted to see pics orknow anything about this wing kit,(or our other wings) just PM or e-mail us at the given address.
Art
For Sale Frenzee 27 in. Flying Wing Kit, EPP Cores, 24 gm Brushless Motor, mount, prop sylair Aircraft - Electric - Airplanes (FS/W) 4 Nov 11, 2009 02:40 PM
For Sale Brushless X-22 wing kits, Hi- Speed cores w/3000kv, 170+ Watt motor, 20-90+mph sylair Aircraft - Electric - Airplanes (FS/W) 0 Sep 16, 2009 05:13 PM
For Sale Brushless Goliath Micro-Wing kits, 20-85+mph EPP , 3000kv motor, plus more......... sylair Aircraft - Electric - Airplanes (FS/W) 12 Sep 09, 2009 08:15 PM
For Sale X-22, a 22 inch Wing kit, no motor, Hi-Density EPP, (91 MPH !!! w/ 3000kv Rom) Sale sylair Aircraft - Electric - Airplanes (FS/W) 3 Mar 22, 2009 09:11 PM
Sold 20 inch EPP Foam wing kits with Johnson Motor and props. Can be FAST- SALE PRICED sylair Aircraft - Electric - Airplanes (FS/W) 10 Mar 27, 2007 06:27 PM
