Old Nov 26, 2009, 06:05 PM
kyle7119 is offline
Find More Posts by kyle7119
United States, IA, Cedar Rapids
Joined Aug 2009
Best receiver for FPV
I am planning on getting the Futaba 9c to use with my FPV plane. What is the best reciever I can get to use with this radio (PPM or PCM, it doesn't matter). I have read some good reviews about the Corona RP8D1, but I have also read that it is very glitchy. Any suggestions?
kyle7119 is offline Find More Posts by kyle7119
Old Nov 26, 2009, 07:03 PM
EyeFlyPlanes is offline
Find More Posts by EyeFlyPlanes
So Cal FPV Aviator
EyeFlyPlanes's Avatar
United States, CA, Santa Clarita
Joined Feb 2008
Yep go with the corona, inexpensive & you will love it. Just picked up one for My 9c and I was convinced after reports of up to 3 miles glitch free. Also another huge tip, use a 3 cell lipo in the transmitter and you'll get a stronger transmission, up to 20% farther.
EyeFlyPlanes is offline Find More Posts by EyeFlyPlanes
Old Nov 26, 2009, 07:28 PM
Bonafidepirate is offline
Find More Posts by Bonafidepirate
define("BEASTMODE", "1");
Bonafidepirate's Avatar
United States, LA, Moreauville
Joined Jan 2002
I like the RP8D1, so far I've tried a Futaba FP-R127DF, a Hitec Electron 6, and the Corona RP8D1, and the corona is the best of the lot, closely followed by the Electron. The Futaba was good, but easily affected by EMI/RF noise on the plane.
I just paid for a used Futaba R149DP PCM receiver to try out. I've often heard PPM is better, you have more warning signs that you're getting out of range than the sudden drop off with PCM, but I've also been reading of 8km flights with the R149DP, so I thought I'd give it a shot. If it doesn't work out, I've got a couple large planes that need a receiver, it'll find a home either way...
Bonafidepirate is offline Find More Posts by Bonafidepirate
Old Nov 26, 2009, 07:39 PM
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
I use the Futaba R149DP PCM receiver on both my FPV planes and I love them.
Tarro is offline Find More Posts by Tarro
Reply With Quote  (Disabled)
Old Nov 26, 2009, 08:12 PM
JettPilot is online now
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
That is an old wives tale There is no better warning of getting on the edge of your range than seeing your plane go into failsafe. PCM with the failsafes set correctly is a minimum for FPV flight, its much better to have all controls go to neutral and have the plane go into a slow glide, with a slight up elevator in failsafe than have them go crazy like would happen with PPM. I have flown as much FPV as anyone and more than most, and I would NEVER fly FPV without a PCM receiver without properly set failsafes.
JettPilot is online now Find More Posts by JettPilot
Site Sponsor
Old Nov 26, 2009, 08:30 PM
Joined Jan 2002
I certainly agree about having a failsafe, but the RP8D1 has it on all channels as well. I've never had to use it yet though, thankfully...
Old Nov 27, 2009, 04:01 PM
kyle7119 is offline
Joined Aug 2009
bump
Old Nov 27, 2009, 05:56 PM
aaron_gx is offline
Find More Posts by aaron_gx
Flying FPV from the lab.
aaron_gx's Avatar
Canada, AB, Lethbridge
Joined Jun 2008
my rp8d1 is great. i love the synth feature, and the failsafe. i thought my berg7p was a cool PPM reciever, but the corona far exceeds the berg, and is literally 1/2 the price (and no crystal to buy).
I heard extending the antenna is helpful in extending range also, there is a thread going on about it somewhere here...
aaron_gx is offline Find More Posts by aaron_gx
Old Nov 27, 2009, 09:55 PM
kason is offline
Find More Posts by kason
kason's Avatar
Taiwan
Joined Aug 2009
i'm wondering would it be able to let those osd detect rc link lost.
i know it's not ppm and can't set fail-safe like pcm does. however, it does have it's own
fail-safe switch. any ideas?
kason is offline Find More Posts by kason
Old Nov 28, 2009, 12:16 AM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
http://www.rcgroups.com/forums/showthread.php?t=953701
scrape is offline Find More Posts by scrape
Old Dec 09, 2009, 04:08 AM
patricklupo is offline
Find More Posts by patricklupo
Joined Jul 2009
Hi Kason,
I've created a thread regarding fail safe and RVOSD here. You might check it to see if anyone has a solution.
patricklupo is offline Find More Posts by patricklupo
Old Dec 09, 2009, 07:49 AM
gaviator is offline
Find More Posts by gaviator
gaviator's Avatar
Tbilisi, Georgia
Joined Feb 2007
I had such a situations both with PPM and PCM. PCM was better for recovery... predictable. Just rise your Radio Tx antenna ahead immediately after loss of signal and you should gain it back soon.
gaviator is offline Find More Posts by gaviator
Discussion Best for Fpv - Ezstar or Twinstar? EyeFlyPlanes FPV Talk 30 Mar 12, 2010 02:57 PM
Discussion Which is the best receiver for sailplanes? dimbohall Sailplane Talk 6 Nov 16, 2009 11:56 AM
Question Best Slow and Stable FPV Platform? SSM FPV Talk 20 Sep 17, 2009 06:02 PM
Question Best FPV set up? flyboy321 FPV Talk 27 Sep 06, 2009 09:14 AM
Discussion Best motor for fpv easy star Manic Flyer FPV Talk 42 Dec 16, 2008 02:45 PM
