CB100 Hangar
ALMOST STICKY: Since the opening of this hangar 17 months ago - there has been considerable effort trying to organize and collate the information in some kind of reasonable order to minimize some of the same questions. If you are searching for help in a specific topic (how to eliminate tail wag for example) - you might want to try the condensed versions offered in some of these links. Some redundancy but better than sifting through 345 pages!!
http://www.rcgroups.com/forums/showthread.php?t=1320483 http://www.rcgroups.com/forums/showthread.php?t=1186337 http://www.rcgroups.com/forums/showthread.php?t=1112568 5166 posts and counting - lots of good advice and help and encouragement for those just getting their CB100 off the ground - as well as the seasoned pilot doing a 100 hour maintenance and checkup. ........................................_______________________ .................................................. ....__|__ .................................................. ...|.......| .................................................. ....\...../ .................................................. .....---- .................................................. .. /.......\ FIRST HAND EXPERIENCE Flies beautifully without any modifications or changes or upgrades, but first time heli fliers may find it difficult to control without some prior experience with a coaxial or sim or both. The 45° fly-bar provides a stability that won't be found on most other fixed pitch helicopters, but don't let go of the sticks and don't blink until it is hovering. On the CB100 the fly-bar is shifted 45° instead of the usual 90° degrees from the main rotor and the theory revolving around that is enough to make your head spin just thinking about it. But putting all the theory aside - brushless motors hardly get warm - an exceptionally stable gyro - 8-9 minutes flight time - can take a lickin and keeps on tickin - what an incredible flying machine!! I'm a looooong way from expert (in anything) but sure can appreciate the amount of development that was put into this micro. SECOND HAND EXPERIENCE Bought a 2nd one. Flies better than the first. Probably something to do with all the practice on the first? I named them one and two. When one crashes - there is still two left!! ![]() captJack, author Taking Off With RC Helicopters - FAQ's 101 |
I have to start out by saying that I don't have one yet, but I'm glad I waited because reading the other thread has increased my knowledge base. I had a 4#3b for a very short time and found I could not get that silly thing to fly and also spent a ton of time doing maintenance on it in an attempt to get it stable. I am hoping the newest addition to the Walkera random number generated heli's
will be the ticket. Before anybody goes out and spends mega bucks on aftermarket mods that may or may not be necessary, just recently the other thread has discovered that changing motor pinions gives an equivalent result at a fraction of the cost!! If that pinion change is made, you can avoid the 2.9g tail motor that, supposedly, was a necessity. The only caution with that is the stock 2.0g motor has bushings instead of bearings, so , the motor life is still in jeopardy. I am planning on getting one after Christmas, but by then, the number of palm size FP heli's Walkera has available may grow exponentially.![]() ![]() ALTERNATE SKIDS: http://www.rc711.com/shop/product_in...oducts_id=2322 |
Joined Nov 2009
I started w/ a picco 2 ch., then to a mosquito 3 ch., I got the 4#3b last xmas.(2% trying to fly, 98% maint.). my wife said it wasn't a good gift, i called her crazy cause i loved it....then I bought the cb100(hesitantly).
after getting off the ground (no real ground wash probs. either)I could easily hover it tail in. so much better than the 4#3b. after about 30 flights the battery seems a little weak already. but all in all i love this heli and im going to transplant the guts to my MIA frame(bought it thinking it was stronger than the 4#3b frame and boom). Weak parts on the CB, tail fin, tail rotors,(strip out, easily fixxed w/ ca glue), main rotors, and of course TAIL BOOMS...ohh and use med. thread lock on any screws that come loose. especially the ball screws on the linkage. I'm going to buy a couple of pinions, instead of a more powerful motor. so thanx for that idea. Wowhobbies.com is due for my next order(tail booms and rotors). HAPPY THANXGIVING
While it's still fresh in my head.. My son came over with his CB100 so I could do some work on it for him..
I installed the MIA skids and tail stick, replaced the boom I CA tooth picks into the hole inside and ran the wires on the outside, moved the tail esc up front, replaced main blades, put JB Weld on frame in tail boom hole area I figured that might as well do it before it broke there like my CB and 4#3 has, painted it black with magic marker. For someone learning to fly in area that makes my living room look big I think he is doing good.. Watched him fly it here and he didn't break anything..Was keeping in in the middle of the room OK.. |
His new skids have a place to attach some braces. I was thinking of using some black thread and CA to make up something.. But I have nine of the $1.00 booms left in stock. And with running the wires on the outside they are easy to replace/repair with CA and or tape now.. I did pick up some 3/32" aluminum tube at hobby shop thats 2.38mm and with a thick coat of CA might work OK.. three pieces in a pack each 12" long will give 9 booms for 2 bucks...
Long Island, New York
Joined Nov 2009
Hello all...I'm a first time poster on this site and am thankfull for this thread. I have been in this hobby since retiring a few years ago when I began playing with a nephew's picco. Since then I have gone thru many models(mostly co-axels, after destroying my first tail rotor model in about 10 seconds!) I have stuck with E-flite as they were available locally (spare parts etc) and since I have now finally mastered the MSR I needed a challange. I read all the trade talk about the Walkera 4-3 etc but was still reluctant to order one. I finally decided to get a CB 100 after all the good publicity on the web and all I can say is WOW!! Yes, I have pretty much (in one week)damaged it to the point of it's being useful only as a spare parts repository and have just ordered the upgraded package from wowhobbies. I hope I haven't gotten ahead of myself, but time will tell. I'll post my experience with the new mods(tail roter etc) as soon as it arrives. Thanks again for a great thread-
stblue(Bob) |
Stblue,
Welcome to RCG. It is a great family and I am sure I would not have lasted in this hobby without all the help and encouragement from the folks here. I started with a picoo z then lama 3 then 4#3 (which I could never fly) then 4#3B which is awesome then CB100 which is by far the best walkera I have had to date. I am so happy with mine and it really does fly great stock. I will not admit to modding mine as this is a stock thread and the CB100 needs nothing to make it a truly great first FP. Have fun and don't be afraid to ask when you need help. Vimd |
Hi Bob - I'll second that motion - we are all here learning and having fun - some of us learning - most of us crashing. If it wasn't hard we'd probably be doing something else. Lots of tips and tricks for improving the bird - would be interesting to hear some tips and tricks for flying. Something I just learned when turning nose-in during forward flight - give a tad of back elevator to slow it down during the turn to minimize the tendency for it to accelerate and head for the nearest piece of furniture. This has really helped to make smoother turns - especially in limited space. Bumping into things at relatively low speeds doesn't seem to bother it much - no visible damage yet with about 10 flights.
Note-1: Shut down the throttle as soon as you bump to keep the ESC's happy. Ready to take notes for other's hints and suggestions. Thanks Jack |
| Thread Tools | |
| Discussion Walkera CB100 In Our Hot Little Hands!!! | dkfuji | Micro Helis | 9942 | Jan 21, 2013 01:11 PM |
| Build Log AWESOME! Walkera 4#3s, CB100, 4G6, 5#6, 52, Novus, EP, MCX, 120 UPGRADES-MODS-HOW TO | MarioIArguello | Micro Helis | 2437 | Feb 05, 2011 08:52 PM |
| New Product Walkera 4G6 and CB100 At RcHobbyHelicopter.com | johnIn2SonAZ | Micro Helis | 546 | Mar 20, 2010 11:34 PM |
| Discussion Walkera 4G6 & Walkera CB100 Shipments | wowhobbies | Micro Helis | 34 | Sep 24, 2009 10:26 AM |
| Discussion ▇ MSR killer » Walkera CB100 heli and parts now available (4#3B replacement) | sebtomato | Micro Helis | 40 | Sep 16, 2009 06:59 AM |
