Old Nov 27, 2009, 10:19 PM
Panorama City, CA
Joined Sep 2004
Originally Posted by init4fun View Post
Hi John , im not computer savvy enough to know how to post links but if you search "Radical RC" thats who I get my A123 batterys from and they are a great company to do business with . An A123 is kinda like a lipo but safer and able to be used to power a receiver without any regulators or other devices . They are the best power source to use in our glow engined planes because they dont have the internal resistance problems of NIMH . Just make sure you get ones called "receiver packs" and charge them properly and you will be amazed at how well they work . Best of Luck to you and Happy flying
Thanks for information. I will check into it.
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Nov 27, 2009, 10:22 PM
Joined Mar 2008
YES !!! I just figured out how to cut and paste a photo . These are A123s that Hobbypartz.com sells and there also a good seller . Good Luck
init4fun is offline Find More Posts by init4fun
Old Nov 27, 2009, 10:31 PM
Panorama City, CA
Joined Sep 2004
I checked it out.
If the receiver pack voltage is 6.6V nominal, can it be used with a receiver and servos without voltage regulator to reduce it to 4.8V?
I was always wondering what happens if I used 2 cell LiPo at 7.4V with a receiver and servo.
Old Nov 28, 2009, 10:42 AM
codezilla's Avatar
Chino Hills, CA
Joined Feb 2003
Originally Posted by John Kim View Post
I checked it out.
If your servos are rated for 6.0V, then it's fine to use 2 Cell Li-Fe (A123) without a regulator. You can't use 2 Cell Li-Po's w/o regulator because their voltage is too high for most servos.
Adrian
codezilla is offline Find More Posts by codezilla
Old Nov 28, 2009, 11:43 AM
Joined Mar 2008
Yep , Adrians got it right ! As long as you use 6 volt rated servos A123 is the single best power source available {in my opinion }. Just get rid of anything that says "4.8 volts only" and you will do fine with A123 . Best of Luck to you and Happy Flying
Old Nov 28, 2009, 12:37 PM
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
I've been flying A123 and LiFePO4 cells for a couple of years now and wouldn't go back to NiMH or any other battery technology.
They're cheap, tough as boots, have very low internal resistance, a life of 1,000-2,000 charges and can be recharged much faster than most other technologies.
No regulators required either which eliminates yet another point of failure.
XJet is offline Find More Posts by XJet
Old Nov 28, 2009, 01:09 PM
Panorama City, CA
Joined Sep 2004
Adrian
Hi Adrian,
Thanks for good advice. I didn't know Li-Fe voltage is lower than Li-Po.
Old Nov 28, 2009, 01:11 PM
Joined Nov 2004
Xjet, have you been using non-A123 LiFePo4 cells? What has been your experience with the Non-A123 cells. Are the soft cell LiFe's (like a LiPo) as good as the hard A123 cells? I use and love my A123 1100 2 cell reciever packs but I can see a future need for different physical sizes. All the advantages of the A123 cells in different cell configurations would be great. Wish A123 made a few more different cell sizes! Rudy
Rudy F is offline Find More Posts by Rudy F
Old Nov 28, 2009, 01:12 PM
Panorama City, CA
Joined Sep 2004
XJet,
Do you buy LiFe cells from Chinese source you recommended me for LiPo before?
If not. where do you buy it?
Old Nov 29, 2009, 04:42 AM
most exalted one
BC Canada
Joined Aug 2002
John..you wasted my time and others researching Futaba 9C Supers and then bought a used 9c (not super) from a "friend". Then you claim a crash caused by XPS equipment and cause all sorts of fuss. You must indeed crave attention. Good to see you are getting it.
Now you are also getting an education on batteries while not doing any research yourself. Whatever works I guess, but I have to question someone who is on this forum shopping for a radio, then using XPS equipment who hasn't even heard of alternatives to 4 cell nimh or nicd batts.
Is this really true?
Oh BTW I am another who has used XPS, including the original stubby antenna on the TX. I have flown equipment over land and water until it was a speck and brought it back without incident to fly again. I did it with 4 cell packs but eventually have switched to 5 cell or A123 packs, just to be sure. For curiousity I also flew Spektrum and now Hitec, with exactly the same trouble free results.
4*60 is offline Find More Posts by 4*60
Old Nov 29, 2009, 08:47 AM
DougV's Avatar
United States, FL, Miramar
Joined Dec 2007
John,
Hope this helps: http://hangtimes.com/a123_batteries_for_giants_faq.html
Doug.
DougV is online now Find More Posts by DougV
Old Nov 29, 2009, 10:38 AM
USA
Joined Sep 2003
4*60
Check your PM's.
onewasp is offline Find More Posts by onewasp
Old Nov 29, 2009, 03:14 PM
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
Then clearly John's problems were unlikely to be the result of using a 4-cell pack.
Thanks for this useful information
Old Nov 29, 2009, 03:16 PM
The reviewer
XJet's Avatar
Tokoroa
Joined Mar 2004
I was buying the 1350mAH cells from DealExtreme for a while but they seem to have changed suppliers and although the old ones were excellent (although nowhere near as good as true A123s) and I have them in half a dozen .40-sized models, the new cells from that source are now a different colour and have very poor performance (extremely high internal resistance so no good for receiver packs).
I haven't tried the LiPo form-factor LiFePO4 packs but the price on them needs to come down a bit (IMHO) to match the A123s.
Old Nov 29, 2009, 03:43 PM
User
Colorado
XJet, have you seen these? LiFePO4 Rechargeable Single Cells (1C-15C Rate)
The 26650 (3400mAH) in looks interesting.
rmteo is offline Find More Posts by rmteo
Sold XPS 6 channel 2.4 receiver, parkflier bruff Aircraft - General - Radio Equipment (FS/W) 2 Nov 11, 2009 01:57 PM
For Sale 2.4 GHz Multiplex Evo 12 / XPS Combo Pack alvaro corzo Aircraft - General - Radio Equipment (FS/W) 0 Oct 29, 2009 12:08 PM
Off Site Multiplex Royal Evo 12 Ch. 72 and 2.4 XPS Combo !!! alvaro corzo Aircraft - General - Radio Equipment (FS/W) 0 Oct 14, 2009 04:27 PM
Discussion Graupner sells Weatronic 2,4 GHz-devices - End of Cooperation with XPS? udogigahertz Radios 12 Sep 18, 2009 03:06 AM
Discussion My brother crashed his plane into a tree and there was a crashed plane in a trash can BD Flyer Crash Discussion 8 Aug 09, 2007 09:00 PM
