Old Nov 24, 2009, 07:31 PM
Maturo is offline
Find More Posts by Maturo
Maturo's Avatar
Joined Nov 2009
Question
Lipo Charger Charging to 12.7 volts
Should I be concerned. This charger's port used to charge to 12.65. Could it be my latest 3S lipos have less IR?
Maturo is offline Find More Posts by Maturo
Old Nov 24, 2009, 07:44 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Hard to say as some chargers do not have the most accurate displays in the world. I would be concerned that if the charger's display is accurtae the LiPolys most likely will have a somewhat shorter life.
Charles
Old Nov 24, 2009, 07:48 PM
Maturo is offline
Maturo's Avatar
Joined Nov 2009
The charger is a Polycharge 4 without a display that has charged hundreds of batteries. Port #3 typically charged to 12.65 (3s lipos), but now 12.7 is more typical, particularly w/new lipos. I did note that by the time the lipo came off the balancer, voltage was 12.65. Also, I check voltage by plugging into my amp meter. Thanks.
Old Nov 25, 2009, 10:32 AM
marc1 is offline
Find More Posts by marc1
I will be an angry old man!
marc1's Avatar
Canada, MB, Division No. 9
Joined Apr 2007
Strange ... usually the Polycharge 4 undercharges (4.1 to 4.15V/cell). A charger with an integrated balancer would be more likely to stop the charge if any cell goes above 4.2V.
marc1 is offline Find More Posts by marc1
Old Nov 25, 2009, 10:50 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
I had a Polycharge 4 that had 2 ports that persistently overcharged to ~12.65 volts as measured by a calibrated lab grade DMM. Wasn't comfortable with this so I took it back to my LHS and swapped it out. All was fine with its replacement but it has been sitting idle for over a year since purchasing my iChargers.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Nov 25, 2009, 11:02 AM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
Once upon a time, we were told by cell manufacturers that maximum full charge was 4.235 volts per cell - 12.7 for a 3S.
Bill
ebill3 is offline Find More Posts by ebill3
Old Nov 25, 2009, 11:54 AM
Southern Pride
I have always understood 4.2 volts per cell as being the 100% stste of charge point however some safety devices use 4.3 + / - 0.010 .
I seem to remember the old PQ overcharge safety devices using 4.325 per cell but I am not sure. The above 4.3 + / - 0.010 is on a specification sheet right in fron of me.
In the past some have charged LiPolys to 4.3 per cell on purpose to gain a little extra bost in competation. While fairly safe with balanced cells it tends to reduce their life.
Old Nov 25, 2009, 12:02 PM
Maturo is offline
Maturo's Avatar
Joined Nov 2009
Port #3 charges to an actual 12.63 measured by high end dvm, however my amp meter indicactes 12.70 and reads in .05 volt increments. I guess my polycharge is still working great and so convenient to have 4 chargers in 1 compact unit.
Old Nov 25, 2009, 12:05 PM
ebill3 is offline
ebill3's Avatar
http://www.rcgroups.com/forums/showthread.php?t=528582
Also, see page 8, "Charging" in attached document.
Discussion Sky Charger B6AC DUAL POWER 5-in-1 LiPo Charger w/ USB PC Charging & Monitoring hobbypartz HobbyPartz.com 47 Sep 15, 2012 12:02 PM
Discussion Getting 14.8 volts from two 7.4 lipo's mowery1 Batteries and Chargers 3 Sep 26, 2009 09:39 PM
Discussion Is 12.7 volts to high on a 3s lipo? missle Batteries and Chargers 11 Jul 15, 2007 05:54 PM
Discussion Charger Charging to 8.53 volts for 2S LiPo OK? Manchild Batteries and Chargers 2 Dec 09, 2006 04:42 AM
how to get 7.2 volts from 12 volts car battery? r4rosal DIY Electronics 9 Feb 18, 2005 04:07 AM
