Old Nov 23, 2011, 01:02 AM
PLD is offline
PLD
Find More Posts by PLD
PLD
Magicsmoke maker
PLD's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
Revision 15 of the LOM main boards arrived today... will try get one built up tonight.
Initially I'll try the SMD reference resistors, since with the 4x flat planar layout should help massively with the thermal drift (note the exposed pad area also for further dissipation.
The key isn't trying to keep the temperature from changing, but rather to keep everything as close as possible to the -ambient- temperature which the onboard temperature sensor picks up and uses.
PLD is offline Find More Posts by PLD
New Product PLDaniels LMA-02 Spektrum compatible lost model alarm with built in voltage protector PLD Product Announcements 0 Aug 26, 2009 08:10 PM
Astro Micro Meter Low Volt Modification Gordon Johnson Scratchbuilt Indoor and Micro Models 0 Apr 23, 2002 01:23 PM
