That's the plan - I imagine I could end up using it for quite a few other future designs. I better make sure I accommodate for the various pin-headers that the different designs use, including some of those fancy flexible/strap leads (as per the photos you showed above)
Latest blog entry: What a change of life. No more R/C.
Ah yes, had forgotten about that - thanks.
I was planning on getting some PCBs done for the new Linear branded refs that I have, putting 1.25, 2.50 and 5.0V into the same box (all isolated of course, running off a 9V drycell). Paul. |
Hopefully the 24-bit ADCs will arrive today and we can start to get a real idea on how far this chip will go before the noise takes over. I'm planning for 20-bit resolution which is a full order of precision higher than the 16-bit.
I've also sent off an order for a PCB I drew up last night to be a graphics LCD driver, again with an AVR mega on it, though I might get away with a mega48 (4K should be more than ample I hope to hold 2 sets of bitmaps for digits, 20px and 8px high). The board won't arrive for probably 2 weeks or more. Paul. |
Oh yes, I forgot to say that after I had routed everything, I barely had 2 or 3 pins left over on the gfx driver board, so there's certainly no way I could have done both the LOM aspect and the gfx-LCD aspect on the same chip in this case, at least not without moving to a bigger AVR (mega32 or such)
24 bit ADCs arrive... still waiting on some 'odd value' resistors to arrive (different supplier).
Kelvin leads
Good news everyone, I received my Kelvin leads today... they've got shielded BNC connectors on them but I think I'll use that to my advantage for the high precision unit.
Not sure, looks like Au plated to me. Still fortunately at least with the nature of the 4-wire setup it's not a big issue, so long as they don't corrode severely.
LOM prototype #3
Here's the high precision one showing the resistance down to 0.0001 resolution, I could in theory go to 0.000001 (that's 0.01mR) but it'll be dominated by noise and probably explode the memory requirements of the AVR (as I'll have to deal with 64-bit math)
Not sure when production will start... or if it will.
Just gone insane tonight as I did -something- and now the math is all wrong, I'm out by 1 bit somewhere and it's driving me bananas! Perhaps I should plug in a 16x2 LCD for the short term and fill the rest up with raw bit-dumps
Well, I got it back up and running "normally" again. I did have to use 64-bit math which ballooned the firmware size from ~4K to 7.9K. I can say already that beyond 0.1mR resolution is incredibly noisy - even the 0.1mR resolution is something you would want to take much longer term samples of.
A wiser man than me once said, "The best solution is the one that gets the job done - just."
0.1mOhm from something this simple is pretty impressive. Better than that and we are starting to talk Lab gear and big money surely? John Quote:
I adjusted the firmware a bit more and made the uC go to sleep during the time that the ADC is doing its magic (about 140mS/sample), it's cut down the noise a little bit and I suspect once I mount this board into a metalised chassis and load up the front panel with BNC connectors with common grounds etc etc it should become useful.
| Thread Tools | |
| New Product PLDaniels LMA-02 Spektrum compatible lost model alarm with built in voltage protector | PLD | Product Announcements | 0 | Aug 26, 2009 07:10 PM |
| Astro Micro Meter Low Volt Modification | Gordon Johnson | Indoor and Micro Models | 0 | Apr 23, 2002 12:23 PM |
