Old Nov 24, 2009, 06:19 PM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
Key chain camera battery
I have a key chain camera and brought out 2 wires from the battery so I can use my Li-po charger. This circuit board was on the battery (1S 3.7 270mah). What's it for? The camera is supposed to be charged through the 5v usb port which causes the camera and battery to get very warm when doing so, hence bringing out the 2 wires.
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Nov 24, 2009, 08:45 PM
SteveM732 is offline
Find More Posts by SteveM732
SteveM732's Avatar
United States, OR, Beaverton
Joined Feb 2008
The chip on the left is an 8205A dual n-channel mosfet and the chip on the right is a DW01 single LiXX cell protection circuit. See page 5 of the DW01 datasheet so see how the two chips are connected and work together.
SteveM732 is offline Find More Posts by SteveM732
Old Nov 24, 2009, 09:28 PM
Joined Mar 2008
Great! Thanks. Do I really need this in my camera?
Old Nov 24, 2009, 09:32 PM
SteveM732's Avatar
Joined Feb 2008
If you are going to charge from USB you must as it is a ~5 volt supply. If you charge using your own charger then you won't have any issues with over charging, but you won't have the circuit to protect you from over discharges.
Old Nov 25, 2009, 07:43 AM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
Steve summed it up and as usual he's Johnny-on-the spot with a link. As I mentioned in the other thread the main purpose in these spy cams is to prevent discharge. Without it the Key Cam would be a "one use" camera.
Overcurrent and overvoltage functions never used because the cameras do not draw very much even when taking pics (50ma in the ones I measured) and the charging circuit never went above (4.19v worst case in mine).
PS However note that, like the Silverlit ones, it does not function as a charger and will not work simply connecting to a 5v supply.
rich smith is offline Find More Posts by rich smith
Old Nov 25, 2009, 09:57 AM
SteveM732's Avatar
Joined Feb 2008
Originally Posted by rich smith View Post
As I mentioned in the other thread...
Oh great, there is nothing like spending time helping someone only to find out they had received the correct answer hours earlier in another thread.
Old Nov 25, 2009, 10:50 AM
rich smith's Avatar
Joined Dec 2006
I dunno Steve. How come you don't read EVERY SINGLE WORD of EVERY SINGLE LINE in EVERY SINGE POST in EVERY SINGE THREAD of EVERY SINGLE WEBSITE like me?
Discussion Confused about current draw in battery-esc-motor chain tseuG Power Systems 20 May 28, 2016 01:29 PM
Idea Upgrade Pentax Li_Ion Camera Battery using existinging LiPos wedge98 Aerial Photography 8 Oct 10, 2009 10:21 AM
Discussion Walgreen's Key Chain Camera bt98 Aerial Photography 5 Jul 17, 2006 12:12 AM
What is the difference between an NF chain and a TT chain? Akura2 Motorcycles 4 Aug 25, 2005 04:16 PM
