Here's the answer to mounting the antenna.
http://www.xtremepowersystems.net/pr...S-24Ant&cat=12 |
Raleigh,NC
Joined Nov 2000
You can order them off ebay from Hong Kong for about $1.25 http://cgi.ebay.com/2dbi-Wireless-2-...item3f098600bf
If you search ebay you may find some shipped from the US for a little more. Any 2.4 GHz antenna with a RP-SMA connector should work. The higher the gain(ie higher dB) the more directional the antenna will be. The radiation pattern of a rubber duckie is roughly a donut shape around the antenna with little signal coming off the end so don't point the antenna at the receiver. The higher gain versions basically squash the donut so it is more important to have the antenna perpendicular to the receiver. PS Antenna I use came from an old dead WiFi router, many of which use RP-SMA antennas. |
USA, NY, Jamestown
Joined Jun 2000
PS-FWIW- I did look on XPS's web site and the replacement antenna they sell is 2.1dbi. |
I got mine on Amazon, waiting on it to arrive so I can run range checks.
http://www.amazon.com/gp/product/B004BLRMP0 |
Raleigh,NC
Joined Nov 2000
Gain is achieved in an antenna by taking the transmitter power and concentrating it in certain directions instead of spreading it all around equally. Here is a good explanation which also shows radiation patterns for some typical rubber ducky antennas. http://www.rcexplorer.se/page14/gain/gain.html |
| Thread Tools | |
| Discussion XPS module for Hitec Aurora 9? | sbc | Xtreme Power Systems | 43 | Sep 17, 2012 04:45 PM |
| Sold Multiplex Royal Pro 9 + Spektrum module | jjmouris | Aircraft - General - Radio Equipment (FS/W) | 4 | Oct 29, 2009 04:37 PM |
| Discussion Jim -XPS module for new Hitec Aurora 9 ?? | Howard L | Xtreme Power Systems | 4 | Apr 21, 2009 12:06 AM |
| Discussion Futaba 14MZ spektrum module mod | Xnaron | Radios | 6 | Mar 07, 2009 06:09 PM |
| For Sale Spektrum 2.4ghz AIR MOD module for futaba transmitter | xxcysxx | Aircraft - General - Radio Equipment (FS/W) | 3 | Jan 03, 2009 01:52 AM |
