Well I seem to have all the pieces to the puzzle, but I can't bring up my nerve to try it
![]() A9 side - http://www.rcgroups.com/forums/showp...7&postcount=21 Module side - http://www.rcgroups.com/forums/showp...&postcount=564 |
Well I hooked up the Aurora 9 tonight, but no success. While holding the bind button, and tapping "Yes" to transmit on the A9, the LED on the module quickly blinks. After that, nothing happens. No bind, no control. Similar to this - http://www.rcgroups.com/forums/showp...postcount=1144
At first I thought it might be due to the discrepancies between pins 3 & 4 on the module. Sometimes they are defined as ground, or RF sense, or even not connected, etc. I opened up the module and found them to be internally connected, so that doesn't matter. Second hypothesis was that maybe the supply voltage was indeed an issue, but I can confirm that V+ is ONLY passed to Vin on U1 which can be anywhere from 3.8VDC to 20VDC. Now I think removing R2 may have something to do with it. To me it looks like a pull-up resistor. Given that it is meant for a Futaba radio, it is expecting negative shift PPM (signal is normally high and is pulled low for pulses) so if you were modifying the module to work with a positive shift system I can see the need for removing this resistor, but the A9 allows you to choose pos or neg shift, so I can't see how this would make any difference. Good news is nothing turned into smoke, and the stock module works just fine. Anyone have any ideas or can tell me if/why removing R2 would help? |
I too am trying to figure out resistors in this module. (here: http://www.rcgroups.com/forums/showthread.php?t=1219407) I notice that I can make the module work (without desoldering R2) if I hook a 330 Ohm pulldown resistor between ground and PPM line. This does look awful small resistance for a pulldown.
Ari. |
http://en.wikipedia.org/wiki/Resistor#SMD_resistors If you look at my schematic, R2 is a pull-up resistor, ie, it keeps the PPM line high (3.3V from the regulator) to the micro input if the PPM line from the TX is disconnected. The thing I still don't get, is the micro only has a Vdd + 0.5V maximum input voltage (3.8V) and the module is designed to just pass the PPM signal straight from the TX to the module. Do the Futaba modules that this is designed for have a lower PPM voltage? I am not super familiar with the "programmable system on a chip" systems, so I am not sure if there is some way to program the "Direct switched capacitor block" to attenuate the input. |
Thank you for pointing out my error. I hadn't looked inside my own module, I was going on what I saw in this post http://www.rcgroups.com/forums/showt...=2#post7788582 and that appeared to me as "201". Now that I open my module, the writing on R2 is too small for me to read anyway! If I hold it one way, I see 201; if I turn it around, I see 102. But I measure 1K across it exactly as in your photo, so it must be 102.
I gather that old Futaba radios use 2.5V PPM signals. Not sure what you're saying about the 3.8V on the micro. My audio line can generate up to 1.2V. This is enough to register in the micro, but with the pullup, the line swings from 1.9V to 3.1V instead of 0 to 1.2V and the micro sees it as all 1s. With my 330 Ohm pulldown, The line swings from 1.0V to 2.2 and the module recognizes that as a valid pulse train. Ari. |
Auxerre, France
Joined Dec 2007
Sorry to read that...
What i meant in my previous message is : there are other Spektrum modules available (for JRPropo or Multiplex or new shape Futaba) that might be "more" compatible than that one you have been testing... Any suggestion on which one would be best choice? I might have a go myself... Thanks for your help. |
| Thread Tools | |
| Discussion XPS module for Hitec Aurora 9? | sbc | Xtreme Power Systems | 43 | Sep 17, 2012 04:45 PM |
| Sold Multiplex Royal Pro 9 + Spektrum module | jjmouris | Aircraft - General - Radio Equipment (FS/W) | 4 | Oct 29, 2009 04:37 PM |
| Discussion Jim -XPS module for new Hitec Aurora 9 ?? | Howard L | Xtreme Power Systems | 4 | Apr 21, 2009 12:06 AM |
| Discussion Futaba 14MZ spektrum module mod | Xnaron | Radios | 6 | Mar 07, 2009 06:09 PM |
| For Sale Spektrum 2.4ghz AIR MOD module for futaba transmitter | xxcysxx | Aircraft - General - Radio Equipment (FS/W) | 3 | Jan 03, 2009 01:52 AM |
