This thread is privately moderated by Papa-Jay, who may elect to delete unwanted replies.
Old Nov 24, 2009, 02:47 PM
Papa-Jay is offline
Find More Posts by Papa-Jay
rcdatabase.org supporter
Joined Oct 2009
Servo database
Servo database updates information
The servo database is updated, with additional bearing count field.
So here the input fields we have in this database:
1. Product : Servo name (text field)
2. Part Number : text field
3. Digital/Analog : Drop down
4. Manufacturer: Auto complete text field
5. Torque @4.8v : Number only text field (kg/cm)
6. Torque @6v : Number only text field (kg/cm)
7. Speed@4.8v/60deg : Number only text field (at 60 degree, I will try to put linear speed calculator to convert from 30 or 45 degree to 60 degree, so we can have uniform value in database)
8. Speed@6v/60deg : Number only text field
9. Gears Material :Drop down.
10. Motor Type :Drop down (3 poles core, 5 poles core, coreless, brushless)
11. Bearing : Drop down number of bearing, if it bushing please use 0 value. (0,1,2)
12. Spline : Number only text field (vary across several manufacturer, 23-25 splines)
13. Weight (gr) : Number only text field
14. Length (mm) : Number only text field
15. Width (mm) : Number only text field
16. Height (mm) : Number only text field
Papa-Jay is offline Find More Posts by Papa-Jay
Old Dec 16, 2009, 10:54 AM
A Useless Geek is offline
Find More Posts by A Useless Geek
just Some Useless Geek
Chicagoland
Joined Oct 2008
Needs an additional field for the output shaft mean diameter, averaged from spline valley to spline peak. A bunch of the cheapo Chinese servos are "very close" in a field where a couple hundred nanometers is the difference between working properly and catastrophic failure.
And by the way -- do you have a DTD or schema for this thing yet?
A Useless Geek is offline Find More Posts by A Useless Geek
Data Servo Database volare Radios 7 Aug 05, 2015 11:57 PM
Discussion VTPR Model Database 2009 oldscooler Slope 763 Oct 03, 2012 04:02 PM
Discussion BATFE acknowledges NATIONWIDE DATABASE of firearm owners! KMKAZE Life, The Universe, and Politics 84 Nov 06, 2009 10:22 AM
Discussion Radio Control Database Papa-Jay Other Websites 1 Oct 24, 2009 05:18 AM
