Old Nov 11, 2012, 06:57 PM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Originally Posted by GrahamWilson View Post
Great video, what a fantastic location.
What, no criticism? Or CASA comments?
Teamsherman is offline Find More Posts by Teamsherman
Old Nov 11, 2012, 07:43 PM
Gwalch is offline
Find More Posts by Gwalch
Gwalch's Avatar
Australia, VIC, Inverleigh
Joined Mar 2004
Now that is the sort of country I love to fly in.
When we get our FPV sorted out it will be in areas like that!!
As for criticism... screw it.. I just wish it was me... that's enough criticism.
Gwalch is offline Find More Posts by Gwalch
Old Nov 11, 2012, 09:37 PM
BillzillaAus is offline
Find More Posts by BillzillaAus
My cat moderates better
BillzillaAus's Avatar
Australia, QLD, Worongary
Joined Apr 2011
It flies again.
I fitted the landing gear extensions (6 mm carbon square tube with rubber feet tied to the old gear) and also mounted the video transmitter antenna upside down to try to get better reception at longer range.
Did two local visual flights to see if everything was working okay after the crash then just did an FPV one. I'd forgotten how difficult it was! To be fair it was pretty windy though.
BillzillaAus is offline Find More Posts by BillzillaAus
Old Nov 11, 2012, 09:47 PM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
Nice one mate! I am putting one together myself shortly - am just waiting for the bits to arrive!
What size motors did you use?
The_Mongrel is offline Find More Posts by The_Mongrel
Old Nov 11, 2012, 10:24 PM
Joined Apr 2011
It's all just standard DJI gear.
Edit - apart from your FPV gear, of course!
Old Nov 12, 2012, 01:09 AM
Joined Dec 2007
Cool. I plan on running 6 of the Carbon Bird motors - Only because I have them sitting in a box and thought I would use them. Might be overkill though. 750Kv I think.
Old Nov 12, 2012, 02:42 AM
Munyuk is offline
Find More Posts by Munyuk
Joined Nov 2008
Hey guys, let me introduce myself
My name is Zac and i live in darwin. I mainly fly imac but i have wanted to take part in fpv for a while now and I was in katherine over the weekend and an IMAC buddy of mine said he had some gear he barley used. I scored a set of base edition fatshark goggles and a 900mhz set from hobbyking (guessing around the 200mw range)
I have some average quadcopter experience and have a (HK) dji 450 frame, would this make a good first fpv rig?
Also, I want a close range set up (as far as i can go with stock futaba 8fg transmitter) plane, what would be a good aircraft for this. I also want it to be able to carry a hero 3.
Any suggestions?
Cheers
Zac
Munyuk is offline Find More Posts by Munyuk
Old Nov 12, 2012, 04:22 AM
muduck is offline
Find More Posts by muduck
muduck's Avatar
Australia, NSW
Joined Apr 2004
I do not believe that CASA are on a witchhunt..sure, I imagine they have their sights on the morons who potentially endanger lives, but if you're flying in the bush, I don't really think they're interested.
Had a great day yesterday with the Hexacopter, learning more all the time, jeez that Naza is something else...one of the resident "experts' came out to lend a hand..I was really peed off that my 5.8 was breaking up at 30m, yet his identical setup was good to 900m....so I copied his TxRx settings & BINGO.....I have been running the VTx thru the GoPro but the results are not good so I've ordered yet another one of those brilliant cams from security camera2000.....My fixed wing FPV has been thru the fatsharks, but after using the mates 8" screen from Foxtech,wow! I just ordered one for the HEXA....you just need to be able to glance up occasionally
muduck is offline Find More Posts by muduck
Old Nov 12, 2012, 04:31 AM
muduck is offline
muduck's Avatar
Australia, NSW
Joined Apr 2004
I used these T-motor 2216-12 KV800 Motor (TMOTOR 2216-12)
with 1047 Carbon fiber propeller CW&CCW (1047CFCWCCW) props...Ihad to do some slight balancing, but the whole thing works a treat on 4S 5000..flight time 7mins, using 2300 out of the pack...I haven't worked out how to adjust the voltage yet,so could get more time.....I got all the bits from Foxtech.....the hexa is a great machine.
I got this landing gear & gopro holder....
http://www.aeroxcraft.com/index.php?...products_id=20
Old Nov 12, 2012, 04:43 AM
Joined Dec 2007
MUDUCK - I did look at that landing gear! It looks like a great bit of kit - but I would have to buy the GoPro gimbal as well as it states it does not come with it- and then it gets expensive!!
Old Nov 12, 2012, 04:49 AM
muduck is offline
muduck's Avatar
Australia, NSW
Joined Apr 2004
You dont have to mate, as I found out after I bought both
theres a flat plate that you can attach the gopro to UPSIDE DOWN..you dont need the gymble, as a matter of fact, I have hot glued the roll axis solid, & only use the up-down movement of the gymble
Old Nov 12, 2012, 04:58 AM
acky is offline
Find More Posts by acky
addicted rc'er
acky's Avatar
Adelaide, Australia
Joined Dec 2009
Hey teamsherman I read somewhere your using rangelink and a er9x are you using ppm? With rvosd? I'm considering setting it up -ppm that is, not sure where to start with the er9x
acky is offline Find More Posts by acky
Old Nov 12, 2012, 05:04 AM
Joined Dec 2007
Are you serious??
The site states... "GoPro Gimbal NOT included. see gimbal product page."
I thought I would have to but this...
http://www.aeroxcraft.com/index.php?...&products_id=5
Old Nov 12, 2012, 05:16 AM
muduck is offline
muduck's Avatar
Australia, NSW
Joined Apr 2004
Are you serious??
no..thats the gymble, but with the landing gear is a flat plate that slides along the rails..u can use that to mount the gopro upside down
Old Nov 12, 2012, 05:18 AM
Joined Dec 2007
Ahh..I see what you are saying. But will it line up good enough - I guess it would if it's nice and flat and level.
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 11003 Jun 28, 2016 02:47 PM
Build Log Easy Fly Glider ST330 (Easy Glider Clone) FPV Build Thread SoMoney FPV Talk 493 Nov 12, 2012 03:08 PM
Discussion FPV Beginners Reference Mega Thread... rc_ron FPV Talk 167 Mar 24, 2012 07:31 AM
Cool Aussie XBOX Live thread ozzi supercub Australia 7 Oct 22, 2009 01:42 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
