Old Apr 09, 2012, 02:20 AM
vvV FANG Vvv is offline
Find More Posts by vvV FANG Vvv
Formerly bUd~Fokker
vvV FANG Vvv's Avatar
Australia, NSW, Eurongilly
Joined Aug 2008
its in the main fotum in last ten pages id say or check in my last 20 comments ...im lazy to search hah...http://www.rcgroups.com/forums/showthread.php?t=1624245
vvV FANG Vvv is offline Find More Posts by vvV FANG Vvv
Last edited by vvV FANG Vvv; Apr 09, 2012 at 02:23 AM. Reason: http://www.rcgroups.com/forums/showthread.php?t=1624245
Old Apr 09, 2012, 02:50 AM
dutch jones is offline
Find More Posts by dutch jones
thats Mr dutch to you
Australia, NSW, Jeremadra
Joined Mar 2011
sweet fang thanks just looking this may be the answer to my problem instead of trying to track down another jr dx9 to fit the uhf gear to ill fit the 2.4g receiver onto this with the uhf transmiter on other side, looks like its only $100 bucks or so. hopefully it works
anyone have a thought about this?
dutch jones is offline Find More Posts by dutch jones
Old Apr 09, 2012, 04:29 AM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Originally Posted by vvV FANG Vvv View Post
I think theres a few locations in oz where these happen ....it has to be the ultimate oz fpv ride ....i think one happens in SA ....might suit you omma !
http://www.dropbears.com/m/morning_glory/
I have a different kind of Morning Glory..its got bugger all to do with flying
ommadawn is offline Find More Posts by ommadawn
Old Apr 09, 2012, 04:44 AM
ZIPPER is offline
Find More Posts by ZIPPER
by ZIPPER
ZIPPER's Avatar
East Kurrajong Sydney Australia
Joined Aug 2004
I was flying off the slope at Bondi a couple of years ago, and there was happening there, from the coast to the horizon.Very cool thing to see. But it was in the afternoon not in the morning, so dose that make it an evening glory?
ZIPPER is offline Find More Posts by ZIPPER
Old Apr 09, 2012, 06:00 AM
Friar Fnord is offline
Find More Posts by Friar Fnord
Climbing the learning curve!
Australia, QLD, Brisbane
Joined Jan 2011
Hey guys! Just to change the topic (I'm good at that!) I was thinking of building a tricopter from the ground up using something like this:
http://www.rcexplorer.se/Educational.../triguide.html
It will be my first foray into multicopters and was looking at this control board:
HobbyKing Multi-Rotor Control Board V2.1 (Atmega168PA)
.. then flashing it to suit tricopter control. For a multicopter newbie, is a tri a good place to start considering also I am on a budget (less parts to buy)? I'm assuming more motors = greater stability and lift capability?
I'm about to search around for a good resource on some of the basics behind it as all I really know at this stage is that on a multi with even number of motors, the opposing sides motors spin the same way and alternate the torque effect. Whereas on a tri, the rear one needs a servo.. Each arm also needs a gyro along the pitch axis + one central for the yaw?
Curious
Friar Fnord is offline Find More Posts by Friar Fnord
Old Apr 09, 2012, 06:01 AM
Formerly bUd~Fokker
Joined Aug 2008
Yah no worries man ...
Er9X For life! I even have the tatt!
Just changed my start screen now to this! Haha kinda spun my mates out when i said it now uses the Android 4.0 Os !
Old Apr 09, 2012, 09:28 AM
onkelz is offline
Find More Posts by onkelz
onkelz's Avatar
Joined Nov 2011
What Bands can i use in Aus?
Hi all,,
I have been reading all over the place in search for what freek-Bands i can use here in sydney-Aus apart from 2.4 etc..
i see fpv kits that go from 900mhz to 5.8ghz..
as i use a Dx8 it runs on 2.4 etc etc..i know all this bit ..so i will get a immersion Uhf 433 and diverity UHf reciver in the plane (Sky Surfer) hang a clover leaf of the plane and a 5.8ghz stub antenna,,should give me 1-3 k i am thinking ..
i have land near Gouldburn 30k in land from it,,so interferance etc would be small or none..
but for video etc,,can somebody please tell me what bands i can use here in aus
900mzh?
1.2
1.3
are there any probs with using the above bands here?????
as i read and as we all 5.8 is the way to go if you use a 2.4 trans.
but there are heaps or 2.4-systems out there cheap and with heaps of power.
and 5.8-systems are like 600mw ..i cant seem to find anything higher then that in 5.8 that i dont have to take a second morg out on the house to pay for it that is.
thankyou all,,i will post a pic or 2 if i can here soon..
-Karl -Sydney
onkelz is offline Find More Posts by onkelz
Old Apr 09, 2012, 05:26 PM
RobJCook is offline
Find More Posts by RobJCook
RobJCook's Avatar
Wagga Wagga, Australia
Joined Sep 2008
omg beautiful day here in batemans bay and i cant find anyone to fly with grrrrr.
Nice coast - we used to live down there. Once flew at Moruya Heads beach (low level). Yep, wish we were there again to fly with you.
RobJCook is offline Find More Posts by RobJCook
Old Apr 09, 2012, 07:02 PM
basadia is offline
Find More Posts by basadia
Keith
Australia, New South Wales, Newcastle
Joined Apr 2011
I have been playing with multi rotors over the last 18 months and have just found what works for me. I have used the KK board, Multiwii board and I have now settled on the APM2 as the preferred multi rotor control system.
I initially built the RCExplorer Tri and have now moved onto a quad as I have found they are a bit more stable because of the extra motor and the yaw is controlled by counter rotating props which gets rid of the extra servo at the back.
The frame I am now using is the X525 picked up from Ebay for just under $40, you can get a set of props (10x4.5) for under $4 from Ebay as well. Get yourself some 18 amp Turnigy Plush ESC's as well, they work a treat.
Hope this helps.
cheer
Curious
basadia is offline Find More Posts by basadia
Old Apr 09, 2012, 10:16 PM
Macattaka is offline
Find More Posts by Macattaka
Beyond the BlackStump
Macattaka's Avatar
Australia, SA, Adelaide
Joined Mar 2006
Finally time and place overlapped and I had a chance to FPV the Zephyr II while camping over Easter. Still using a small omni on vrx, looking forward to the RV Tracker arriving.
This was the maiden FPV flight so the video is quite boring just doing basic circuits at altitude to get a bit of stick time/confidence going.
Macattaka is offline Find More Posts by Macattaka
Old Apr 10, 2012, 01:36 AM
Firepower is offline
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
Curious
I looked for a long time but decided on a quad after checking out the tricopters. I see basadia has also advised to get a quad. At a guess if you get a tri I think it will not be long before you get a quad.
I bought this one and if you see the link you will see how strong it is with all the bricks on it.
http://www.goodluckbuy.com/kk-x525-a...lticoptor.html
They also recommend the motors, ESCs and props so that leaves the controller.
If you go with the cheap controllers you may not be happy with them for long. I got this one - FF Controller and I got it flying great fairly quickly:
http://www.goodluckbuy.com/free-flig...on-sensor.html
It is a auto Balance Controller which the cheaper ones are not. It has gyros as well as accelerometers which just keeps it level and helps a LOT.
All the info is here and you can ask any questions and someone will help you:
http://www.rcgroups.com/forums/showt...opter&page=184
Now that I have just ordered a mini quad I now want a better controller with GPS and and a baro to hold height. I am considering the Rabbit controller by goodluckbuy.com but If anyone can suggest a better one that would be great. I am looking for a simple one to set up as spending too much time on one is a problem for me.
Firepower is offline Find More Posts by Firepower
Old Apr 10, 2012, 01:47 AM
cody069 is offline
Find More Posts by cody069
cody069's Avatar
Joined Dec 2008
Good luck buying from goodluckbuy....
Bought a quad frame Over 3 weeks ago from them , have not sent it...Wont answer emails....
cody069 is offline Find More Posts by cody069
Old Apr 10, 2012, 02:15 AM
Firepower
Firepower's Avatar
Joined Mar 2010
Yep - they are not quick but they seem to answer Skype. I suppose Skype text. I suspect they are selling more than what they expected and having trouble keeping up with everything. HK initially had the same problem.
Always look on EBay first and sometimes the items are there at the same price but mostly dearer.
Old Apr 10, 2012, 02:16 AM
OzparkPilot is offline
Find More Posts by OzparkPilot
Watts up ?
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
Bit of a long shot but, does anyone have a fatshark lipo they can sell me ? Happy to pay new price.. My died and I need one urgently. Many thanks please pm me if you can help :-(
OzparkPilot is offline Find More Posts by OzparkPilot
Old Apr 10, 2012, 02:47 AM
Joined Mar 2011
cant you just use a 3 cell lipo, thats what mine runs off.
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 10724 Feb 04, 2016 08:14 PM
Build Log Easy Fly Glider ST330 (Easy Glider Clone) FPV Build Thread SoMoney FPV Talk 493 Nov 12, 2012 04:08 PM
Discussion FPV Beginners Reference Mega Thread... rc_ron FPV Talk 167 Mar 24, 2012 08:31 AM
Cool Aussie XBOX Live thread ozzi supercub Australia 7 Oct 22, 2009 02:42 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 06:37 PM
