Old Feb 27, 2012, 12:11 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Too much effort! Lol
Teamsherman is offline Find More Posts by Teamsherman
Old Feb 27, 2012, 12:57 AM
AussieHoppy is online now
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
AussieHoppy is online now Find More Posts by AussieHoppy
Old Feb 27, 2012, 01:09 AM
hpcoolahan is offline
Find More Posts by hpcoolahan
Fatshark Repairs AU/NZ
hpcoolahan's Avatar
Australia, NSW, Yamba
Joined Oct 2008
QUOTE=AussieHoppy;20870172]get a 1 watt booster, i used to regularly fly 1.5-2km with little more than the occassional beep
note that this was with 2.4 friendly 5.8 vid
I have a brand new booster in box that i never even got to use , went the dragonlink route instead .
Its the same one from rangevideo
$40 shipped inside AU and can have it
Cheers
Patrick
hpcoolahan is offline Find More Posts by hpcoolahan
Old Feb 27, 2012, 01:49 AM
Gimmer is offline
Find More Posts by Gimmer
Gimmer's Avatar
Australia, QLD
Joined May 2011
Originally Posted by Teamsherman View Post
AnyOne here using FrSky? I have just got my module and 2 D8RII rx's and want to know what I'm supposed to do with the jumper pins.
Cheers!
I have Frsky and Dr8IIs. Never used any of the telemetry add ons, just bind and fly for me. Helpful ? :P
He is a tip though, crack rx open and make sure the antenna are connected well to the board. I have had one that had come loose and have read about a few others that have had the same problem. I always check now and usually throw a bit of hot glue on just to be sure.
James
Gimmer is offline Find More Posts by Gimmer
Old Feb 27, 2012, 01:54 AM
Gimmer is offline
Gimmer's Avatar
Australia, QLD
Joined May 2011
Originally Posted by Stunt Double View Post
I just put the 'fun' back into my funjet - 900+ watts of pure fpv madness!!!
Quite an easy job to fit all the fpv gear inside the fuse. This one doesnt have rth or autopilot so i pray for clean video before each flight. Only issue is the range with Frsky. Im getting a few beeps less than 500m away so this one might have to switch over to dragon link.
Have you checked your antenna connection? I have a 1W booster on my Frsky 9x.
Actually did you have a dodgy Frsky RX Hoppy?
Old Feb 27, 2012, 01:57 AM
Peril is offline
Find More Posts by Peril
Jets Suck (and blow)
Peril's Avatar
Australia, QLD, Deception Bay
Cheers!
I has jumper pins?? I use FrSky telemetry with the Bixler, unboosted range in conjunction with a 5.8G FPV vTXD is ~500m. Hence why I brought your 2.4G booster, I want a bit more range for my FPV
Range without a vTX (RC LOS) using the v8 one way has been tested out to over 2km.
You think to much TS, just bind and fly
Peril is offline Find More Posts by Peril
Old Feb 27, 2012, 02:09 AM
Stunt Double is offline
Find More Posts by Stunt Double
Australia, VIC, Melbourne
Joined Oct 2007
I'll pull it apart and check the antenna. Wouldnt hurt to check it anyway as the first frsky module I got had solder in one of the connectors and couldnt be connected to the rf pins.
Stunt Double is offline Find More Posts by Stunt Double
Old Feb 27, 2012, 06:09 AM
Firepower is offline
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
James
I have FrSky with telementry and is great. I bought one without telemetry for a mate and was busy so did not open the box before I gave it to him.
I saw the receiver just before it was ready to fly and the range check was really bad. He reakons that he did not do it but the end bits on the two wires (antenna) were cut off. We had LOL.
He reckons it must have came from HK like that. Just thought wonder if Customs have scissors. Anyway the antenna are cheap from HK now and that fixed the problem. We kept laughing about it for quite a while.
Firepower is offline Find More Posts by Firepower
Old Feb 27, 2012, 01:27 PM
Joined May 2010
Old Feb 27, 2012, 03:31 PM
Joined Oct 2007
just keep in mind the frsky signal strength telemetry has signal latency beyond 2km and the latency increases exponentially, so make sure you have fail safe set up, something like have the fpv cam pan servo turned a little on FS, so you instantly know through the goggs if FS has kicked in, no matter how briefly (good practice on any setup really)
Thats a great tip. My failsafe has a lost model alarm and I heard it beep once about 20m away from me which was a bit of concern. Range test is fine but i'll be sure to check the rx antennas also the module before next flight.
Old Feb 27, 2012, 06:27 PM
Macattaka is offline
Find More Posts by Macattaka
Beyond the BlackStump
Macattaka's Avatar
Australia, SA, Adelaide
Joined Mar 2006
Happy to report that I plucked up the courage to test RTH on the RVOSD last night and it worked flawlessly
Made it out 2.2km (only using omni's so far) then enjoyed the view as a passenger on the ride home and for the figure 8's overhead. Annoying that RVOSD fly's smoother than I do...
Macattaka is offline Find More Posts by Macattaka
Old Feb 27, 2012, 07:36 PM
Member #1
Joined Aug 2011
I'm not using FrSky for FPV, I have Rangelink UHF LRS for that.
Old Feb 28, 2012, 02:28 AM
Kahnx is offline
Find More Posts by Kahnx
Registered DSer
Kahnx's Avatar
Australia, VIC, Hadfield
Joined Mar 2003
With 900W on a slippery airframe like a Funjet, I reckon a LRS is a very good idea!
Look forward to some Funjet formation flying!
Kahnx is offline Find More Posts by Kahnx
Old Feb 28, 2012, 04:47 AM
Joined Oct 2007
I pulled apart the Frsky rx and module and checked over the connections. The rx antennas do pull off very easy so some hot glue went on them. Can someone confirm is it just the last inch of the antennas that is active? Originally my antennas were just dangling out of the fuse but now ive mounted one flat and the other vertical. Did a quick flight test and it certainly has improved radio reception. I still get a few beeps but by looking at the google maps distance calculator im getting good reception out to 1km now. I might try the frsky patch antenna.
Roger, im more interesting in getting an RTH system on the funjet first. Could also use some stabilization too - if only my RVOSD didnt go for a swim!!! And definitely up for some funjet formation but you better not lead me into video blackout with your fancy antenna tracking "go anywhere" setup....
Old Feb 28, 2012, 05:14 AM
Aussie Pete is offline
Find More Posts by Aussie Pete
Aussie Pete's Avatar
Joined May 2009
Aussie Pete is offline Find More Posts by Aussie Pete
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 11278 Yesterday 10:41 PM
Discussion FPV Beginners Reference Mega Thread... rc_ron FPV Talk 169 Sep 05, 2016 10:47 AM
Build Log Easy Fly Glider ST330 (Easy Glider Clone) FPV Build Thread SoMoney FPV Talk 493 Nov 12, 2012 03:08 PM
Cool Aussie XBOX Live thread ozzi supercub Australia 7 Oct 22, 2009 01:42 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
