Old Dec 23, 2011, 06:08 AM
vvV FANG Vvv is offline
Find More Posts by vvV FANG Vvv
Formerly bUd~Fokker
vvV FANG Vvv's Avatar
Australia, NSW, Eurongilly
Joined Aug 2008
I had my first FPV for a long time today with my new EZGP. Sure is a tight fit trying to squeze all the bits in ...im so glad i put the servos from the bay to the tail.. but everything fitted in their right spots and balance with the 2200 3s or the 5000mah plus an 800 3s vtx battery without any extra lead needed!
Tested it at the local airstrip, and besides needing some more trimming and fine tuning of the rth it all went well!
I have the camera mouted high on a cf tube and it clears the prop and was nice and stable for the test flight.
Also tested the RF Beacon tracker which has a microphone on it that detects noise... and when it hears anything it keeps the tracker in a standby mode to save power and save it emmitiing stuff out on the uhf channel.
I mounted it on a wing, and wanted to see if it would switch on in a glide when everything was silent ... and even on a very slow glide in with no stick inputs to chatter the servos it stayed off ... which is awesome too!
So yeah i am pretty much all set to go for Christmas, as was my goal.... now the next goal is some cloud surfing and some distance testing!
Should be off to some nice scenic locations after boxing day...so fingers crossed i will be able to get some footage!
vvV FANG Vvv is offline Find More Posts by vvV FANG Vvv
Old Dec 23, 2011, 06:17 AM
Kev.au is offline
Find More Posts by Kev.au
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Originally Posted by The_Mongrel View Post
Hello Lads,
Just thought I would pop in to wish you all a Merry Xmas. Man it has arrived quick!!
Let's just hope summer turns up soon.
Cheers
Mongrel
Hey mate, longtime.
Hope business is doing well, have a safe & happy Xmas.
Cheers, Kev.
Kev.au is offline Find More Posts by Kev.au
Old Dec 23, 2011, 06:20 AM
Boxhead is offline
Find More Posts by Boxhead
Look outside the Square
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Great Stuff Bud. Glad it all went well. No fly'n here at the moment. Its either raining or Blow'n.
Bx
Boxhead is offline Find More Posts by Boxhead
Old Dec 23, 2011, 06:35 AM
Peril is offline
Find More Posts by Peril
Jets Suck (and blow)
Peril's Avatar
Australia, QLD, Deception Bay
Bixler back in stock Aus Warehouse
http://www.hobbyking.com/hobbyking/s...dProduct=18328
Peril is offline Find More Posts by Peril
Old Dec 23, 2011, 07:54 AM
ozzimadman is offline
Find More Posts by ozzimadman
Australia, WA, Bunbury
Joined May 2011
hey all
I cant get my tracker to set to point north have tried several times with the setup but when its not just sitting there spinning around its off by quite a bit
here is a reset and north cal vid (easier to see it than me explain lol)
reset and north cal on MFDAAT (2 min 5 sec)
and here is a vid of it following the plane you can see the plane in some shots and the tracker is following the plane way behind it
MFDAAT tracking plane but not pointing at it (3 min 52 sec)
please help as i need to get it working (i've just ordered the ezuhf system for some long range but it will be useless if i have no vid
its not beeping so i don't think its loosing any data packets
ozzimadman is offline Find More Posts by ozzimadman
Old Dec 23, 2011, 03:45 PM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Does it need to be pointed at true N or magnetic N for its reference?
ommadawn is offline Find More Posts by ommadawn
Old Dec 23, 2011, 04:57 PM
Peril is offline
Peril's Avatar
Originally Posted by PMRfly View Post
hi all
question for LRS users (433mhz) ... i have a question you may be able to help with..
has anyone ever had interference with LRS from digital servo's?
my antenna is very close (3cm) to a digital servo and i am wondering if that would cause interference with LRS (433mhz) signal?
cheers p
Not personally with 433mhz, but I have had this happen on 36mhz. Try a search on the net as someone will have written on this for sure. I remember reading about twisting servo leads to minimise interference, so someone is concerned
Anything is possible, test and you'll know.
Old Dec 23, 2011, 05:02 PM
Peril is offline
Peril's Avatar
Originally Posted by BingWing View Post
I wonder if the Fatshark Predators are superior to the Dominators ! I cant work it out !
A quick search finds this link to help:
Basically a different field of view, Dominator is 30deg, Predator 25deg.
http://fpvlab.com/forums/showthread....-vs-Dominators
Old Dec 23, 2011, 08:40 PM
Peril is offline
Peril's Avatar
OH man, forget the Funjet, meet the ultimate Park Flyer mount for FPV!
http://www.youtube.com/watch?feature...&v=Vmw-qzqqA-A
Old Dec 23, 2011, 10:40 PM
birdscarer is offline
Find More Posts by birdscarer
Australia, NSW, Albury
Joined Sep 2010
Hi guys, i'm looking at buying either a skywalker or a bixler, i need a slow flying-glider style platform for fpv.I have a taildragging hk epp fpv thats now resides in a rubbish bin.Any thoughts guys?
birdscarer is offline Find More Posts by birdscarer
Old Dec 24, 2011, 12:14 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
I've just bought a skywalker coming from a AXN floater. The reason I bought the SW is cause I wanted something a little more agile but with more room for better gear. The floater is really nice and floaty, with a really nice glide characteristic.
It all really depends on what sort of FPV you will be doing most of. If I was searching the same search as you, I'd go the skywalker hands down. Watching a shed load of SW vids its deffinately the airframe that will suit my FPV style.
This probably hasn't helped much but it is another opinion/idea to get you thinking.
Just take your time searching and don't rush it.
Teamsherman is offline Find More Posts by Teamsherman
Old Dec 24, 2011, 12:47 AM
Peril is offline
Peril's Avatar
Go the Bixler for mixed fun flying styles is my advice, covers all bases fairly well. SW is for the longer, slower, higher flight stuff where you need the extra space.
From your description the SW seems the go for you, but there are other better options if 'Gliding' is your passion.
Old Dec 24, 2011, 06:08 AM
AussieHoppy is online now
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
AussieHoppy is online now Find More Posts by AussieHoppy
Old Dec 24, 2011, 07:39 AM
joel0407 is offline
Find More Posts by joel0407
joel0407's Avatar
Australia, NT, Lyons
Joined Oct 2010
I built a Bixler for FPV over a 6 month period. You can get everything to fit very nicely and it'll flew fanastic with a 3000mha Lipo. Balanced perfect.
The problem with the Bixler is access. Once the halves are glued together you really cant get inside again.
That's why I'm going with the SW this time round. I dont really like the look of the SW but it's about functality.
Happy Christmas.
joel0407 is offline Find More Posts by joel0407
Old Dec 24, 2011, 03:11 PM
Peril is offline
Peril's Avatar
Well, Bixler is a good all rounder once you have done the mods, I was throwing mine around OK unclipped. I think if you're considering clipping the wing you are better off with a Tech Sumo or a pusher jet. The Bixler is that good all rounder, it glides and it flies low and fastish as is.
I'd not clip it's wings, what I would (and did) do is use the extra wing area to carry the weight of HUD gear/good camera and carry out the airframe mods needed for flying fast.
No.1 being a new beefed up CF wing joiner. I went all out in this area, my wing is now crash proof, as tested in the first flight where I hit the deck full throttle left wing first. Trashed the fuse but the wing barely had a mark
8mm CF tube in each half, sleaved to 6mm tub all the way out 20cm past the ailerons inside edge. I use a further 6mm solid CF as a wing joiner in the center. Rod bind the centre 8mm tube to stop the CF splitting. Read the bottom link, I did most of these mods with some changes of my own. Strangely enough I have not changed the servos, these seem OK to me, let's hope so anyway
http://www.rcgroups.com/forums/showp...postcount=9277
http://www.rcgroups.com/forums/showp...postcount=9330
http://www.rcgroups.com/forums/showp...postcount=6570
http://www.rcgroups.com/forums/showthread.php?t=1231310
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 10794 Today 02:22 PM
Build Log Easy Fly Glider ST330 (Easy Glider Clone) FPV Build Thread SoMoney FPV Talk 493 Nov 12, 2012 03:08 PM
Discussion FPV Beginners Reference Mega Thread... rc_ron FPV Talk 167 Mar 24, 2012 07:31 AM
Cool Aussie XBOX Live thread ozzi supercub Australia 7 Oct 22, 2009 01:42 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
