Old Dec 15, 2011, 06:32 PM
basadia is offline
Find More Posts by basadia
Keith
Australia, New South Wales, Newcastle
Joined Apr 2011
Sad news, lost my Skywalker and all flight gear today. I thought I would do a beach flight at Stockton, launch was successful but got about 2.5 Ks toward the Signa which was my intended destination and motor went WOT. Plane piched down and to the right and landed in the water. Spent several hours combing the beach to no avail.
What I lost:
Skywalker
FY21AP
AP117
GoPro with 16 MB SD card
4 x MG servos
2 x HXT800 servos
1 x 5000 MAH Turnigy 4s LIPO
1 x 1800 MAH Turnigy 3s LIPO
KX181 Camera
Foxtech 500 mw TX
Chainlink RX
Really bummed now not sure what to do.
Here is the flight from the ground station:
Skywalker Lost at Stockton Beach, Newcastle (3 min 10 sec)
basadia is offline Find More Posts by basadia
Old Dec 15, 2011, 06:37 PM
PMRfly is offline
Find More Posts by PMRfly
Joined Mar 2011
been there, feel ya pain...
i lost almost the exact same set up.. ;-(
What I lost:
Skywalker
FY21AP
AP117
4 x MG servos
2 x HXT800 servos
KX181 Camera
Foxtech 500 mw TX
Chainlink RX
http://youtu.be/36hzSEOaD9M
PMRfly is offline Find More Posts by PMRfly
Reply With Quote  (Disabled)
Old Dec 15, 2011, 06:56 PM
Kahnx is online now
Find More Posts by Kahnx
Registered DSer
Kahnx's Avatar
Australia, VIC, Hadfield
Joined Mar 2003
Originally Posted by ticketec View Post
Hey Roger,
Looking forward to seeing how your setup goes this christmas. the dragon link should be here in time to take it down to Melb with me.
Do you want me to bring down some more EPP? the center section looks to be as aerodynamic as, errr.... umm... a bus
I left some extra on the nose for some additional bump protection during the first few flights. Once I have the settings sorted, I'll hone it down a bit to give the cameras a clear view and make it more aerodynamic.
Bring your goggles with you, Dave, and your DL (with that antquated Mode 1 funny stick radio too - you know: dual axis gimbles were invented about 50 years ago) - we can fly the Funjet, tricopter and Scout Bee in combinations. I have an extra VRX that you can use to fly through.
Have you fixed dates yet?
Cheers
Roger.
Kahnx is online now Find More Posts by Kahnx
Old Dec 15, 2011, 07:12 PM
Kahnx is online now
Registered DSer
Kahnx's Avatar
Joined Mar 2003
Originally Posted by AP_OZ View Post
Very nice roger!! I have the 48in windrider wing and love it..
Can you tell us more about the centre section? Ive seen it once before and might give it a go on my next build.
Cheers,
John
John
The centre section is simply a big chunk of EPP. It comes in 2" thick sheets, and I cut a 4" wide panel for the Fuselage. All the electronics except the VTX and the antennas are mounted in deep, lidded bays. Much more available room than trying to lay it out all over the wing, and the fuselage is a good motor mount out back and camera mount our front. You'll see in the pic below that the raw fuselage length was much longer - I anticipated that the plane would be tail-heavy and that the cameras would be waaay out front to get the CoG right. It turned out that the the piece I cut off the nose was added to the rear to push the motor back!
I have 2 'bays' for electrics, one for the EagleTree, LRS RX and guardian, and the other for the power wiring (battery leads, connectors, Y-harness for parallel batt connections, 12V tapping for the VTX, and routing of the ESC wires. This keeps my fingers out of the electronics wiring (read: accidentally disconnecting something while rummaging around plugging-unplugging batteries) for flight-to-flight use. Recesses are cut into the nose for the panning servo and GoPro, and out back for the ESC. I used a piece of rectangular PVC downpipe for the motor mount, which fits snugly over the 2" thick EPP block at the rear. So the "Fuselage" is a pretty handy addition, and it might even generate a little extra lift to boot! The spars (ribbon top and bottom, and 6mm tube through the trailing edge) both go through the fuselage, therefore the ribbons finish 2" short of the wingtips. This is OK as I have covered the whole wing in light laminating film and it is rigid enough.
CoG is about 1/2" behind the ribbon spars.
Cheers
Roger.
Old Dec 15, 2011, 07:15 PM
vvV FANG Vvv is offline
Find More Posts by vvV FANG Vvv
Formerly bUd~Fokker
vvV FANG Vvv's Avatar
Australia, NSW, Eurongilly
Joined Aug 2008
Basadia, that sucks man sorry to hear of your loss. It's always a bugger when that unexpected element jumps up.
Hopefully you had your phone number on it and it floated and is picked up by someone.
vvV FANG Vvv is offline Find More Posts by vvV FANG Vvv
Old Dec 15, 2011, 08:33 PM
Firepower is offline
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
[QUOTE=basadia;20148911]Sad news, lost my Skywalker and all flight gear today. I thought I would do a beach flight at Stockton, launch was successful but got about 2.5 Ks toward the Signa which was my intended destination and motor went WOT. Plane piched down and to the right and landed in the water. Spent several hours combing the beach to no avail.
What I lost:
Skywalker
FY21AP
AP117
4 x MG servos
2 x HXT800 servos
KX181 Camera
Foxtech 500 mw TX
Chainlink RX
Also sorry to hear about your loss.
Have you contacted the local:
http://www.maritime.nsw.gov.au/maps/newcastle.html
Not sure what it is like down your way but there are usually volunteers than are at the neck of rivers in tall buildings and logging each boat in and out. They speak to the fishermen etc so they would be the ones to contact. Not sure how you go if you start talking frequencies you use to them.
Wonder if it was the speed controller overheating? I guess you had a good ESC with an extra UBEC or a SBEC.
Bad luck.
Firepower is offline Find More Posts by Firepower
Old Dec 15, 2011, 08:55 PM
ticketec is offline
Find More Posts by ticketec
Brisbane, Australia
Cheers
Roger.
I've seen you fly, no need for bump protection mate
Flying in Fri At this stage an no exit date set but no more than 3-5 days after arrival. maybe 26th??
Keen to see you gear combinations at work. we are just about to go dragonlink but I'm also shopping for a 5.8g VTX setup as well. Just on another tab looking at securtiycamera2000 website
trying to work out which camera to buy next
dave
ticketec is offline Find More Posts by ticketec
Old Dec 15, 2011, 09:09 PM
cody069 is offline
Find More Posts by cody069
cody069's Avatar
Joined Dec 2008
Pete.. Where you flying?
cody069 is offline Find More Posts by cody069
Old Dec 15, 2011, 09:33 PM
basadia is offline
Keith
Joined Apr 2011
It had a 60 amp Turnigy Plush ESC mounted on the outside of the fuse so would be surprised if it was overheating. Also had a 5 amp BESC. Going into the water would pretty much trash all the electronic componants so if by any chance I get it back (yes my name was on it) the only salvagable item would be the GoPro which I would love to get back. Unfortunately they are an attactive item so would be surprised if it made its way back to me.
Keith
Bad luck.[/QUOTE]
Old Dec 16, 2011, 01:46 AM
omelette is online now
Find More Posts by omelette
I didn't think it'd do that
omelette's Avatar
Australia, TAS
Joined Nov 2011
omelette is online now Find More Posts by omelette
Old Dec 16, 2011, 02:10 AM
Stunt Double is offline
Find More Posts by Stunt Double
Multi Rotor Maniac
Stunt Double's Avatar
Australia, VIC, Melbourne
Joined Oct 2007
Thats terrible news basadia. Hope you get the GoPro and the footage back!! Was the speedie tucked away in the cavity under the wing without any air flow?
Stunt Double is offline Find More Posts by Stunt Double
Old Dec 16, 2011, 02:12 AM
Multi Rotor Maniac
Joined Oct 2007
Roger, that wing looks pretty sick mate. Cant wait to see it in action. I like the way youve mounted the batteries. Do they sit right over the CG?
Old Dec 16, 2011, 04:09 AM
Firepower
Firepower's Avatar
Joined Mar 2010
Keith
Bad luck.
[/QUOTE]
The 60 amp Turnigy Plush ESC should be great particularly mounted outside the fuselage, as you say.
What brand of 5 amp (BESC)/BEC did you have? Apparently the HK ones are no good for what you are using.
I have been having problems getting a decent UBEC/SBEC. Does anyone know where you can get these in AU at a reasonable price?
http://www.rcdude.com/servlet/the-70...10A-BEC/Detail
I did not think they posted to AU but just noticed they do for $6 so that is all right.
Old Dec 16, 2011, 04:37 AM
Aussie Pete is offline
Find More Posts by Aussie Pete
Aussie Pete's Avatar
Australia, SA, Adelaide
Joined May 2009
Aussie Pete is offline Find More Posts by Aussie Pete
Old Dec 16, 2011, 05:46 AM
cody069 is offline
cody069's Avatar
Joined Dec 2008
Sounds good Pete..As long as I am not working :-(
If it Flys Should do well on a slope..
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 10724 Feb 04, 2016 08:14 PM
Build Log Easy Fly Glider ST330 (Easy Glider Clone) FPV Build Thread SoMoney FPV Talk 493 Nov 12, 2012 04:08 PM
Discussion FPV Beginners Reference Mega Thread... rc_ron FPV Talk 167 Mar 24, 2012 08:31 AM
Cool Aussie XBOX Live thread ozzi supercub Australia 7 Oct 22, 2009 02:42 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 06:37 PM
