Old May 15, 2010, 04:03 AM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
I'd like to give it a whirl. So consider me chimed in. I'll probably miss the new thread though. I don't check the FPV forum that regularly...
Gree is offline Find More Posts by Gree
Old May 15, 2010, 05:32 AM
SPG is offline
SPG
Find More Posts by SPG
SPG
Sydney, Australia
SPG's Avatar
Australia, NSW, Sydney
Joined Jan 2010
Definitely interested Mr B. Might have to bolt a camera to my easytstar for a bit of low level flying.
SPG is offline Find More Posts by SPG
Old May 15, 2010, 05:40 AM
SPG is offline
SPG
SPG
Sydney, Australia
SPG's Avatar
Joined Jan 2010
Originally Posted by The_Mongrel View Post
SPG - I have an eagle eyes and tracker left from my current order if you want one!
All the rest have sold. I was keeping one of each for one customer but he does not want it now.
Let me know
Cheers
Mongrel
Thanks Mongrel. But they are already in the mail. Will keep you in mind for my next purchase though.
Old May 15, 2010, 10:25 AM
Thumb_number is offline
Find More Posts by Thumb_number
I think my wheels fell off.
Thumb_number's Avatar
Perth
Joined Oct 2009
It's been at least 3 pages since an Aussie FPV video.............. Here ya go.
http://www.vimeo.com/11763122
Thumb_number is offline Find More Posts by Thumb_number
Old May 15, 2010, 07:56 PM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
MR B - Sounds like a great idea mate.
Keep me posted.
Cheers
Mongrel.
The_Mongrel is offline Find More Posts by The_Mongrel
Old May 17, 2010, 05:44 AM
Firepower is offline
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
[QUOTE=Thumb_number;15093385]It's been at least 3 pages since an Aussie FPV video.............. Here ya go.
Great video. What size flying wing was that and what camera.
Just starting in FPV and all ideas help.
Firepower is offline Find More Posts by Firepower
Old May 17, 2010, 05:58 AM
Perth
Joined Oct 2009
Thanks mate.
It's a 'Ritewing' Zephyr 54".
The cameras is one I got locally form here:
http://www.allthings.com.au/PCB/Mod-...%20Camera.html
I swapped the stock lens (3.6mm) for a 2.9mm which unfortunately gives those blurry edges.
Good luck.
Old May 17, 2010, 07:00 AM
SPG is offline
SPG
SPG
Sydney, Australia
SPG's Avatar
Joined Jan 2010
Where did you pick up the Ritewing? Are they easy to build?
Old May 17, 2010, 07:37 AM
Perth
Joined Oct 2009
'Easy to build' is dependent on your ability, having said that, I'm no guru and managed it ok.
Chris from RitewingRC will send a build DVD, if you follow that you'll be fine. You need to email him as the Zephyr's are still a special order I think.
http://www.ritewingrc.com/
My build specs:
http://www.rcgroups.com/forums/showp...2&postcount=69
Zephyr build thread:
http://www.rcgroups.com/forums/showt...1087978&page=5
Enjoy.
(ps. check Trappy's blog, really shows what this wing can do)
http://www.rcgroups.com/forums/member.php?u=140585
Old May 18, 2010, 07:39 AM
SPG is offline
SPG
SPG
Sydney, Australia
SPG's Avatar
Joined Jan 2010
Cool, thanks for the info.
Is there something that make the Zephyr more suited than their other models?
Old May 18, 2010, 08:29 AM
Perth
Joined Oct 2009
Yeah, the airfoil is designed to lift a load. With respect to a flying wing anyway.
Old May 19, 2010, 09:14 AM
Firepower
Firepower's Avatar
Joined Mar 2010
Anyone know what this is for - TX or receiver.
http://www.rangevideo.com/index.php?...6bea733f8d02fe
I did use it and got a good picture but not sure where I used it. I think I used it on the receiver.
Also where can this one be used TX and receiver?
http://www.rangevideo.com/index.php?...22082bab86cf89
Is the standard antenna all right on the RangeVideo 200mw and 500mw TX 900mhz or is there something better like the rubber duckie?
Old May 19, 2010, 09:20 AM
Kev.au is offline
Find More Posts by Kev.au
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Hey firepower, i have both of them and have used them on my RX and TX without any problem. It doesn't matter, either way is fine.
Cheers, Kev.
Kev.au is offline Find More Posts by Kev.au
Old May 19, 2010, 05:31 PM
Firepower
Firepower's Avatar
Joined Mar 2010
Cheers, Kev.
Thanks for the info Kev.
I am just setting up the pan tilt with the patch and the second receiver. Guess the next things are the EagleEyes and OSD Pro.
I just found this recorder which should be all right.
http://cgi.ebay.com.au/ws/eBayISAPI....=STRK:MEWAX:IT
Old May 19, 2010, 10:54 PM
Firepower
Firepower's Avatar
Joined Mar 2010
Originally Posted by captain stowed View Post
What would this be like as an airborne camera?
http://cgi.ebay.com/CCTV-Camera-Boar...item58821587be
420 lines
3.6mm lens
looks pretty cheap but the specs seem ok?
Michael.
I guess no one has tried the camera mentioned above. They are so cheap they might be worth trying.
I just got today this camera:
http://www.securitycamera2000.com/pr...etCurrencyId=1
Looks like a really good picture for when I turned it on this morning. Unfortunately I can not record it at the moment. There is no audio.
It is a 540TVL high resolution 1/3 SONY CCD at US$43.
There are almost hundreds of other cheap cameras on the site. It is big and heavy for larger planes. After taking off the metal bracket it is 45grams or 59grams with the plugs. I usually cut them off. Also 35mm by 35mm.
Now I need to look through the site for a smaller one for smaller planes.
I mentioned the clear negative as a filter to fix the white trees. I only have slides which did not work. I can not find a negative yet to try it.
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 11278 Yesterday 10:41 PM
Discussion FPV Beginners Reference Mega Thread... rc_ron FPV Talk 169 Sep 05, 2016 10:47 AM
Build Log Easy Fly Glider ST330 (Easy Glider Clone) FPV Build Thread SoMoney FPV Talk 493 Nov 12, 2012 03:08 PM
Cool Aussie XBOX Live thread ozzi supercub Australia 7 Oct 22, 2009 01:42 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
