Old Mar 08, 2011, 03:52 AM
joel0407 is offline
Find More Posts by joel0407
joel0407's Avatar
Australia, WA, Jane Brook
Joined Oct 2010
Just be careful with that Range Video regulater, Firepower. Mine blew and took out my carema with it.
Now I'm using a 7812 regulator.
Happy Days.
joel0407 is offline Find More Posts by joel0407
Old Mar 08, 2011, 04:57 AM
AP_OZ is offline
Find More Posts by AP_OZ
disenfranchised...
AP_OZ's Avatar
Joined May 2010
gents,
Now that ive graduated to fpv'in wings I dont see any need for my easy star... so, here is an offer that should be an awesome option for someone looking at getting into FPV...
To save me stripping a working model, im willing to sell a ready to go, flight tested easy star FPV platform... Literally bind it to your radio and get in the air with a flight tested and bug free setup - if you have doubts Im sure a number of people on this thread will back me up regarding how good this thing goes... Comes with:
- Easy star
- Readymade RC camera mount
- HS81 servos
- AR6100 Rx
- stryker engine + 25amp ESC
- 6x4 prop
- 900mhz 700mw transmitter + 900mhz receiver + associated cables (for video)
**total cost to assemble less than 2 months ago = $550+**
$350
and if you want i'll:
add FlycamoneHD camera with 16gb high speed mini SD memory card for an extra $200
add black stork OSD (GPS/Altitude/Speed/battery meter) for an extra $180
add FY20 flight stabilisation system for an extra $100
****total all up cost to assemble = $1000+ & 20hours of my time****
So, here is the bottom line:
Easy star FPV bind and fly with all the fruit can be yours for $800 or without the fruit for $350...
also willing to discuss options if you want some bits but not others. Please note that the only other thing you'll need it a set of goggles or a monitor.. see www.mongrelgear.com.au for further info.
Ill even set it up, test fly it and assist with the first couple of flights.. or if you are a local I will happily help out with the first dozen or so flights as long as you come to me
PICKUP ONLY!!.... Im not posting this so dont ask.... Obviously this is located in Canberra - Northside.
Cheers,
John
AP_OZ is offline Find More Posts by AP_OZ
Old Mar 08, 2011, 05:22 AM
Firepower is offline
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
Happy Days.
Must be why RangeVideo do not sell them any more. At least I can not see them there.
That is why I mentioned it may need a heat sink but I wonder if it will work on 5 volts. I am trying to check this out but can not find anything at present.
If it runs on 5 volts this should improve the reliability. Anyone know if it does? The regulator is shown in the photo in post 3075. Guess it will not hurt to try.
Firepower is offline Find More Posts by Firepower
Old Mar 08, 2011, 05:31 AM
Nellik is offline
Find More Posts by Nellik
Australia, QLD, Brisbane
Joined Jul 2010
Originally Posted by Firepower View Post
I am just setting up this 1 gram camera and 2 gram video TX on the AXN Floater to get some practice up and then put it on a smaller Swift. I have just started to install the gear but has anyone had to put a heat sink on the 3.3 volt power supply in the photo or is there a better power supply.
Anyone help with a Vee antenna for the 5.8ghz TX in the photo? I have just put a bit of wire on which will be no good.
Firepower,
As you are going to be using that setup on your wings, I'd suggest dumping that bulky linear regulator altogether (although it is a very good regulator).
I'm not sure how well it would work, but it would be MUCH more efficient to power one of THESE of your BEC (providing it's a switching bec). The thing would hardly even get hot!
I'm guessing you're powering the lot off a 3s battery? (12.6V) If that 5.8GHz Tx is the 200mW one which apparently draws 200mA and and the camera draws 60mA, your going to be using around 300mA as your antenna probably won't be tuned.
Linear regulators convert the excess voltage into heat so if you were using a 3s battery, you would loose (12.6V - 3.3V = 9.3V. 9.3V x 300ma = ) 2.79 Watts to heat. Now BEC's differ in efficiency so we'll forget about that for now. Using that 5V - 3.3V regulator and the same maths, you would loose about 500mW at the regulator to heat and save loads of space and weight. (I think that's the right maths)
If you need more help with it shoot me a PM. I can help with the V antenna also (though at the ranges you usually fly I reckon a dipole would be fine.
Also have you managed to find somewhere else to fly yet?
Nellik is offline Find More Posts by Nellik
Old Mar 08, 2011, 05:34 AM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
Hello Lads,
I managed to actually put a battery through my Trilogy today, the result... Well... Here it is!!
Speed Kills (3 min 46 sec)
The_Mongrel is offline Find More Posts by The_Mongrel
Old Mar 08, 2011, 05:41 AM
joel0407 is offline
joel0407's Avatar
Joined Oct 2010
I tried to get another one to replace it but like you say they dont sell them anymore.
I dont think it had anything to do with heat because I had only just pluged it in. I had it set at 12v and run of 4s.
Now I'm using a 7812 regulator. They are linear and yes there are not the most efficient way of reducing power but the loss isn't great. You can tune out the noise with a couple of capacitors.
If you only want 5v just use a 7805.
Happy Days.
Old Mar 08, 2011, 05:42 AM
me_wantee is offline
Find More Posts by me_wantee
Not a Doctor
me_wantee's Avatar
Australia, NSW, Sydney
Joined Aug 2006
Nice flying John
me_wantee is offline Find More Posts by me_wantee
Old Mar 08, 2011, 05:45 AM
joel0407 is offline
joel0407's Avatar
Joined Oct 2010
I like hellik's idea. Use a switching BEC first to cut the voltage closer to the 3.3v you need.
Happy Days.
Old Mar 08, 2011, 06:00 AM
Firepower
Firepower's Avatar
Joined Mar 2010
Originally Posted by Nellik View Post
Firepower,
I'm using it in a bigger AXN Floater first but eventually a wing hopefully.
Still wondering if the linear regulator will work on an input of 5v.
That is the TX but the RangeVideo One.
I have highlighted some comments above and looks like I need to make a regulator.
I'll PM you about the new location.
Old Mar 08, 2011, 06:02 AM
Firepower
Firepower's Avatar
Joined Mar 2010
Happy Days.
Guess I'll need to solder up a regulator - bugger nothing off the shelf.
EDIT: Even a one cell LiPo might be the easiest way. 3.7v
http://www.hobbyking.com/hobbyking/s...Product=16575# This one is 3.3volts. Spot on.
Old Mar 08, 2011, 06:38 AM
spitfire_Doug is offline
Find More Posts by spitfire_Doug
spitfire_Doug's Avatar
Australia, WA, Carlisle North
Joined Jul 2008
Originally Posted by The_Mongrel View Post
Hello Lads,
http://vimeo.com/20783353
This is awesome!! exactly the type of flying I want to do.
Is that Stevie Ray playing Guitar Boogie
Cheers
Doug
spitfire_Doug is offline Find More Posts by spitfire_Doug
Old Mar 08, 2011, 06:40 AM
Joined Dec 2007
Thanks Wantee!!
DOUG - Yep. The song is called Rude Mood, by the legend himself... SRV.
Old Mar 08, 2011, 02:54 PM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Note:
SRV died in helicopter crash.
ommadawn is offline Find More Posts by ommadawn
Old Mar 08, 2011, 04:42 PM
subsonic is offline
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Hello Lads,
Mongrel, that is some really nice flying man. I'm trying similar things with my tri, but at the moment, am keeping it quite high up, doing large manouvers and away from "stuff". It's really great to see what's actually possible with these things. Thanks for sharing!
subsonic is offline Find More Posts by subsonic
Old Mar 08, 2011, 04:57 PM
Joined Dec 2007
OM - Yes... Sadly he did. He was doing a charity event and jumped in a chopper to go home - only the pilot slammed it into the mountain in thick fog. He would be one of the big reasons I play guitar, and in fact have a rare 92 issue SRV Signature Strat that is my baby. RIP SRV.
SUB - Thanks man - I love getting in there and amongts it. I already have my next adventure planned, but as I will be flying over some really hard ground, I am going to ut the GoPro back in its case. If I crash it would be destroyed without it.
Cheers
Mongrel
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 11263 Yesterday 09:40 AM
Discussion FPV Beginners Reference Mega Thread... rc_ron FPV Talk 169 Sep 05, 2016 10:47 AM
Build Log Easy Fly Glider ST330 (Easy Glider Clone) FPV Build Thread SoMoney FPV Talk 493 Nov 12, 2012 03:08 PM
Cool Aussie XBOX Live thread ozzi supercub Australia 7 Oct 22, 2009 01:42 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
