Old Nov 26, 2010, 07:51 PM
Mr_B is offline
Find More Posts by Mr_B
Flying White Rabbit
Mr_B's Avatar
Australia, NSW, Sydney
Joined Nov 2009
Originally Posted by ommadawn View Post
Hey Brendan, you are getting slack! Where's the Cularis?
Yeah well, I'm still waiting on some more parts. I'm still contemplating on what to do with the servo connectors in the wing saddle as I would like to be able to put the GPS on one wing and the alt and speed sensors on the other.
I haven't found a suitable connector yet. I was looking at the MPX connector but I come up 2 - 3 connections short with them. The USB connectors may be what I go with on a custom PCB for mounting to the plastic saddle. Which version of that plug I'm not sure yet.
I have 2 FW190's now I'm getting better at this foam/glue/shaping combination. The first FW190 is the one from my latest vid. It had a catastrophic finish and has been in many, many bits since may 2008. I was going to chuck it but I didn't as the mainwing was still ok, so it has lived the last little while under the workbench. It's looking good as the camera is in the cockpit and has pan. The led strip voltmeter is in the dash too now. I am going to be doing a test tomorrow with the crappy cam and if that goes well it will be replaced with a better camera.
The other FW190 had a test with a 14V 3800mah batt last week. It had the problem in that the motor got too hot for the main gear and melted the gears and I have been too busy to get to replace the gearbox hopefully tonight.
Cheers
Mr_B
8)
Mr_B is offline Find More Posts by Mr_B
Old Nov 26, 2010, 09:19 PM
Face is offline
Find More Posts by Face
Sydney, Australia
Joined Sep 2008
Originally Posted by Mr_B View Post
Face,
There was a reason I didn't recomend the 2.5W version. However at that power for video, I think that the trouble to get the separation from reciever and TX on a car may cause you greif. I'm prety sure the car you want to use is not a 1:1 scale.
8)
Haha, alright, I'll go with the 1500mw.
Face is offline Find More Posts by Face
Old Nov 26, 2010, 10:15 PM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
So that's what happened!? Melted the gears. Wow... Looking forward to seeing the new 190...
Gree is offline Find More Posts by Gree
Old Nov 27, 2010, 04:32 AM
fpvme is offline
Find More Posts by fpvme
;-)fellow pacifist(-;
fpvme's Avatar
Australia, VIC, Balnarring
Joined Aug 2010
Originally Posted by lloydh View Post
Hey guys, i'm interested in getting into FPV. Is there anyone around Melbourne who wouldn't mind me tagging along next time you go for a flight?? Of course there would be a heap of noob questions to answer.
I'm in Hastings if you are near by no problem
fpvme is offline Find More Posts by fpvme
Old Nov 27, 2010, 04:40 AM
daedelus82 is offline
Find More Posts by daedelus82
Joined Nov 2010
Just plugged in my lawmate tx and it went pop!!!
When I plugged it in I saw a tiny spark, think it may have gone between the positive and negative terminals on the connector, and after that the tx won't work.
I've never had anything like that happen before
daedelus82 is offline Find More Posts by daedelus82
Old Nov 27, 2010, 05:19 AM
Firepower is offline
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
I do not know anything about the Lawmate but if you did reverse polarity there is something here - may not help.
Stick this in Google:
lawmate transmitter polarity
and you'll see things like these:
http://www.rcgroups.com/forums/showthread.php?t=1307373
http://www.rcgroups.com/forums/showthread.php?t=1182899
If you are lucky you may have only done in something like a capacitor but maybe not that lucky. All the best. (in ordering a new one) sorry could not resist the comment.
Firepower is offline Find More Posts by Firepower
Old Nov 27, 2010, 04:09 PM
ZIPPER is offline
Find More Posts by ZIPPER
by ZIPPER
ZIPPER's Avatar
East Kurrajong Sydney Australia
Joined Aug 2004
Anyone know of a good supplier of 900MHZ 1500mW Tx/Rx's? I have been waiting for 2 months for HK to get them back in stock.
ZIPPER is offline Find More Posts by ZIPPER
Old Nov 27, 2010, 04:48 PM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
I have a few of 500mW 900 VTX and about 5 Rxs I no longer use. Plus duckys and a few DPCAV harmonic fiters. Want em? One of the RX has the saw mod done.
ommadawn is offline Find More Posts by ommadawn
Old Nov 27, 2010, 05:33 PM
ZIPPER is offline
by ZIPPER
ZIPPER's Avatar
Joined Aug 2004
That might get me started.
PM me with cost and details and Ill let you know.
The reason I was after 1500mw was I want to try it in our race car (as well as an FPV plane).
Old Nov 28, 2010, 01:52 AM
ommadawn is offline
The Flying Circus
ommadawn's Avatar
Joined Sep 2007
PM sent(x2)
Old Nov 28, 2010, 10:23 PM
Stunt Double is offline
Find More Posts by Stunt Double
Australia, VIC, Melbourne
Joined Oct 2007
Could someone tell me where I can get a small light-weight pan/tilt mount?
What servos are you using for 180 degree panning?
Stunt Double is offline Find More Posts by Stunt Double
Old Nov 29, 2010, 12:09 AM
mrleenagle is offline
Find More Posts by mrleenagle
fpv addict
mrleenagle's Avatar
Sydney, Australia
Joined Nov 2007
hobbyking hs81 or hs65
mrleenagle is offline Find More Posts by mrleenagle
Old Nov 29, 2010, 03:10 AM
Mr_B is offline
Flying White Rabbit
Mr_B's Avatar
Joined Nov 2009
There is a great PT at FoxTech
http://www.foxtechfpv.com/plastic-pa...vos-p-227.html
an there is a full 360 servo at eBay...
http://cgi.ebay.com.au/SM-S4306R-JR-...item43a1d24d41
Cheers
8)
Old Nov 29, 2010, 06:32 AM
Firepower
Firepower's Avatar
Joined Mar 2010
Is there any EasyGlider pilots out there?
I need suggestions on what motor to put on an EasyGlider. The weight including a motor is about 820 grams.
I have a bell style EMax CF2822 but apparently this is not good enough. I also have a good 1050kv motor but it has a threaded shaft. I need an unthreaded shaft to suit the folding propellers. I have put some balsa on the nose with some ply to mount the motor.
Any advice on what motor to use would be appreciated.
Old Nov 30, 2010, 01:40 AM
fpvme is offline
fpvme's Avatar
Joined Aug 2010
why not a 35-36 1300kv turnigy outrunner? only 14$ and really reliable
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 11003 Jun 28, 2016 02:47 PM
Build Log Easy Fly Glider ST330 (Easy Glider Clone) FPV Build Thread SoMoney FPV Talk 493 Nov 12, 2012 03:08 PM
Discussion FPV Beginners Reference Mega Thread... rc_ron FPV Talk 167 Mar 24, 2012 07:31 AM
Cool Aussie XBOX Live thread ozzi supercub Australia 7 Oct 22, 2009 01:42 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
