Old Aug 29, 2010, 12:13 PM
Mr_B is offline
Find More Posts by Mr_B
Flying White Rabbit
Mr_B's Avatar
Australia, NSW, Sydney
Joined Nov 2009
Hi All,
Here is some video from my latest plane.
Mr_B and the Icon A5 Maiden (3 min 50 sec)
Info:-
Plane - Icon A5
Radio - Futaba 36mhz
Vid Tx - 500mw 2.4 AvionicsRC
Vid Rx -Fat Shark
Cam - GoPro
Nellik - if I were to get a new module in 36mhz I would definantly go with a synth one, It just makes things easier I think.
Mr_B is offline Find More Posts by Mr_B
Old Aug 29, 2010, 09:25 PM
SPG is offline
SPG
Find More Posts by SPG
SPG
Sydney, Australia
SPG's Avatar
Joined Jan 2010
Originally Posted by Mr_B View Post
Hi All,
Info:-
Plane - Icon A5
Vid Rx -Fat Shark
Cam - GoPro
Another professional produtioin by Mr_B. And this time in Hi Def!
Have you flown the Icon much since?
SPG is offline Find More Posts by SPG
Old Aug 29, 2010, 10:04 PM
Polish Pornstar is offline
Find More Posts by Polish Pornstar
Australia, Victoria, Gippsland
Joined Aug 2010
Just saying Hi.
Hi guys and girls been flying planes and helis for years but always wanted more. So stupid me stumbled across a video in this thread of the tricopter following the mountain bikers and also a guy on a oval flying.
And it all started again, I had to do it, I was like a kid with a new idea.
So the tricopter build started and I am now waiting for some more parts from HobbyKing to arrive and I should be ready for a test flight. My tricoper is mainly built out of aluminium as I am lucky enough to have a lathe (And a understanding Wife).
HK 500 tail booms for arms.
Hobby King 401B AVCS Digital Head Lock Gyro
Hobbyking SS Series 18-20A ESC
I think I have chosen the wrong motors as my machine with radio, batteries, camera etc will be around 1.4kg. Any advice would be appreciated.
TowerPro Brushless Outrunner 2410-08T 890kv
http://www.hobbyking.com/hobbyking/s...?idProduct=664
Look forward to talkig to you guys and hopefully one day share my own videos.
Regards Pete
Fellow FPV Addict
Polish Pornstar is offline Find More Posts by Polish Pornstar
Old Aug 29, 2010, 10:41 PM
Kahnx is offline
Find More Posts by Kahnx
Registered DSer
Kahnx's Avatar
Australia, VIC, Hadfield
Joined Mar 2003
1.4kg is a bit too heavy, P*rn. My sign-guy (wooden, with HK equipment) build is about 750grams with 3S 2200 battery, and about 1 kilo with a GoPro and vidTX on board. Your weight will fly, but will require heaps of amps (=heat + short flights). I get about 7 mins out of mine. ALso make sure that hub is nice and stiff - if the arms can flex too much, you'll have stability (gyro gain) issues. kV is a bit high - aim for 750, otherwise use smaller props (say 10X3.8). Signguy is now recommending these http://www.rctimer.com/index.php?app=goods&spec_id=145 for the motor - I am just about to order some myself, though the DT's have worked well for me to date.
Where is Melbourne are you?
Cheers
Roger.
Kahnx is offline Find More Posts by Kahnx
Old Aug 30, 2010, 12:35 AM
Joined Aug 2010
Stuffed up
Weight my tricopter again with everything but the speedcontrollers 1kg. Dont know what I did the first time when I weighed it. lol
I milled some of the frame away to save a bit more weight.
And I am in Bairnsdale Victoria.
Regards Pete
Old Aug 30, 2010, 06:10 AM
me_wantee is offline
Find More Posts by me_wantee
Not a Doctor
me_wantee's Avatar
Joined Aug 2006
I think arm flex might be giving mine the slight wobbles. How did the carbon tow work Rog? If its good, I might do mine.
me_wantee is offline Find More Posts by me_wantee
Old Aug 30, 2010, 06:24 AM
narcas is offline
Find More Posts by narcas
Lame-As The real alternative!
narcas's Avatar
Bulli, Australia
Joined Nov 2006
Started work on the FPV ship on the weekend. I cut some foam cores that will just be taped up (no fancy finishing). I dug out a tower pro $14.95 combo I got ages ago but never used. Spun it up and got 1.2kg thrust which should be heaps. It's going to be a twin boom pusher with 5 servos in the wing. Ailerons, centre flap and "A" tail on a "V" tail mix. That should leave the fuz empty for batteries and camera stuff.
If I do the Rx antenna extension and double it back on itself along the wing, does it defeat the purpose of extending it? Or is it like winding the length around a rod like with CB whip antennas?
I might get a pic for y'all if you're interested
narcas is offline Find More Posts by narcas
Old Aug 30, 2010, 07:31 AM
fpvme is offline
Find More Posts by fpvme
;-)fellow pacifist(-;
fpvme's Avatar
Australia, VIC, Balnarring
Joined Aug 2010
hey,
im in vic if anyones local and wants to do a fly in the future
whats the best supplier for fpv gear in australia? ive been using www.bevrc.com thus far .... any local solutions?
cheers guys
regards Mitch
fpvme is offline Find More Posts by fpvme
Old Aug 30, 2010, 07:59 AM
CrashingDutchman is offline
Find More Posts by CrashingDutchman
CrashingDutchman's Avatar
The Netherlands, Utrecht, Amersfoort
Hi All,
Plane - Icon A5
Vid Rx -Fat Shark
Cam - GoPro
Available from HK now for US$ 35.67: http://www.hobbyking.com/hobbyking/s...idProduct=13848
CrashingDutchman is offline Find More Posts by CrashingDutchman
Old Aug 30, 2010, 01:24 PM
Kev.au is offline
Find More Posts by Kev.au
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Hey fellas , i'm after a used DX7, 7c or 9c transmitter only.
I have a Trilogy Tri-copter for swap, + cash. If interested, PM me.
Cheers, Kev
Kev.au is offline Find More Posts by Kev.au
Old Aug 30, 2010, 06:56 PM
Mr_B is offline
Flying White Rabbit
Mr_B's Avatar
Joined Nov 2009
Nah, haven't flown this one much at all. I'm happy with the plane it flies ok but the sink rate with the Go pro on it is prety high asthat camera is like a big air brake on the nose. It really doesn't help puting bricks on the nose like that. Might have to look into reorganising the fleet electronics and to put just the go pro on the easy or make a new plane just for the gopro.
I was thinking of making a new plane for the gopro, I was thinking probably making a DHCommet for this. What you think of that? Would be an interesting bird that one.
Mr_B
8)
Old Aug 30, 2010, 07:40 PM
Firepower is offline
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
I just bought a used Futaba 9C yesterday with the 2.4ghz & 36mhz modules and receivers.
I know this is a very basic question but you would think they would put it in the manual or be able to find it on google but it does not appear to be there.
I have other 2.4GHZ receivers but not with the pins on the end like on the R608FS.
The question is - I suspect the negative pin goes to the rear on the receiver. Can someone confirm this.
EDIT: Just did not want to blow it up. I was correct but found a REAL futaba lead with the extra bit of plastic on one end (key) and that gave it away.
Firepower is offline Find More Posts by Firepower
Old Aug 30, 2010, 09:26 PM
Joined Aug 2010
I think this is a Bargain.
Hi Guys stumbled across this camera and had to buy it.
Pal 425 Lines
Weight 50g
And best of all $25 delivered.
http://cgi.ebay.com.au/Mini-SPY-Squa...rity_Equipment
Old Aug 30, 2010, 09:52 PM
Mr_B is offline
Flying White Rabbit
Mr_B's Avatar
Joined Nov 2009
That sounds like an interesting build, I think it would be interesting to see the result from the extension double back. I don't think that it is optimal to do the double back but I guess it couldn't hurt to try it out. I tried to go from wing tip to tail to wing tip with an old radio I had, It worked well till I powered up the VTX then it killed the range of the reciever in the plane. Mind you I was using an old glitchy RX so I couldn't really tell if it improved anything. From there I went to the DX7 so haven't really played much with the 36mhz stuff and I have only just got a newer futaba 36 which I am only just starting to test now with the Icon.
Pal 425 Lines
Weight 50g
http://cgi.ebay.com.au/Mini-SPY-Square-Color-Digital-CCD-Surveillance-Camera-/370408114562?pt=AU_Security_Equipment
That's one of the first cameras I bought for flying. Tough little blighter that one. Just don't fly after the sun is over the horizon, as soon as the sun dissapears the ground will go really dark and hard to see, the contrast between ground and sky is too much for it.
Mr_B
8)
Old Aug 31, 2010, 01:35 AM
Firepower
Firepower's Avatar
Joined Mar 2010
Pal 425 Lines
Weight 50g
Wonder how that compares with the hobbyking $15 plus postage one but no case.
Probably the same?
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 11263 Today 09:40 AM
Discussion FPV Beginners Reference Mega Thread... rc_ron FPV Talk 169 Sep 05, 2016 10:47 AM
Build Log Easy Fly Glider ST330 (Easy Glider Clone) FPV Build Thread SoMoney FPV Talk 493 Nov 12, 2012 03:08 PM
Cool Aussie XBOX Live thread ozzi supercub Australia 7 Oct 22, 2009 01:42 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
