Old Aug 16, 2010, 12:41 AM
subsonic is online now
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
The 9C (and the 10C I believe) is a module radio. That means that the basic model can be configured to run on any frequency including 40, 36, 72, 2.4 etc by just changing out the module.
If you buy a radio from overseas no problem, just buy a 36mhz module as well and do the swap when you get it.
Don't assume that you won't be shot down using any of the other frequencies because they are in use for other purposes in Australia. Check out the MAAA website if you want, but since it is so easy to change the frequency by just getting the appropriate module, why bother?
s.
subsonic is online now Find More Posts by subsonic
Old Aug 16, 2010, 03:13 AM
Roo2 is offline
Find More Posts by Roo2
Roo2's Avatar
Joined Aug 2007
I recently bought a Futaba 10CAP (module/airplane) radio out of Hong Kong with a 35MHz module and Rx (etamiya.com). 10CAP and 10CHP are module radios (airplane/heli). The 10CAG and 10CHG are not module radios (fixed 2.4G sets). 35MHz egal here in Singapore but will need to change to 36 or 40MHz module if I move back to Brissy next year. I probably should have bought the 40MHz set which I think is is legal in Oz but not so common. Anyway it's an awsome radio. It only came with a fixed channel module and Rx though (not a synth system) which was a bit of a dissapointment when I opened the box but it was 100 bucks cheaper than elsewhere so... I have also bought a 2.4G Frsky module and lots of cheap Rxs for it from Hong Kong from rc-fans88.com for my foamys (not for FPV). Frsky works very well and many recommend it over other 2.4G module systems. I'm thinking about buying a 1W wifi booster for it and trying it for FPV. I have also bought one of the Corona RP6D1 35MHz synth Rxs from Hobbyking and it tunes into the fixed channel Tx module that came with my 10C. For me the Corona Rx works well for FPV and is heaps smaller, lighter and cheaper than the Futaba bricks. I'm thinking of getting a long range UHF system down the track. UHF appears to be the way to go for reliable range.
Roo2 is offline Find More Posts by Roo2
Old Aug 17, 2010, 01:11 AM
nathan089 is offline
Find More Posts by nathan089
BRISVEGAS BABY
Joined Mar 2010
Cheers Guys for you help
but i think i am about to go crazy for trying to find a retailer who sells what i need, the radios i was looking at before where mode 2 and i need mode 1. All i want is a radio with 8 or 9 channels which is 36mhz which can support Head Tracking. Anyone got anything second hand???
nathan089 is offline Find More Posts by nathan089
Old Aug 17, 2010, 02:41 AM
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Don't worry about the mode. All the 9C and 10C radios can be swapped over between one of four modes. You just change a setting within the software, and then swap over the throttle ratchet and elevator centering spring. It is really easy and there are plenty of online tutorials if you are really stuck, but it is self explanatory as soon as you have the back off.
s.
Old Aug 17, 2010, 02:42 AM
barnett is offline
Find More Posts by barnett
Joined Jan 2010
g'day im a noob at this, what are your thoughts on the dragon link tx and rx long range system?
barnett is offline Find More Posts by barnett
Old Aug 17, 2010, 03:15 AM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Hey Mr B, how are the bird attack videos coming?
Gree is offline Find More Posts by Gree
Old Aug 17, 2010, 04:16 AM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
Nathan, I will call FUTABA tomorrow and see what they have in stock!
The_Mongrel is offline Find More Posts by The_Mongrel
Old Aug 17, 2010, 05:29 AM
BRISVEGAS BABY
Joined Mar 2010
Cheers Mongrel that would be hugely appreciated.
thanks subsonic i will keep that in mind if Mongrel does not have any luck with futaba.
Old Aug 17, 2010, 08:16 AM
Firepower is offline
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
I am looking at getting another camera. This Sony one is great for $47 plus $3 insurance at 540 lines but a heavy metal case.
I already have one of these and it is a good clear camera but a bit under coloured.
http://www.securitycamera2000.com/pr...y-0.01Lux.html
Anyone know of anything say smaller and lighter for about the same cost or dearer if necessary?
Firepower is offline Find More Posts by Firepower
Old Aug 17, 2010, 06:45 PM
Mr_B is offline
Find More Posts by Mr_B
Flying White Rabbit
Mr_B's Avatar
Australia, NSW, Sydney
Joined Nov 2009
hehe I have gotten some of the pieces from the video but as you know, I only recorded in low res so the quality isn't that good. I should have something to look at by Friday I would say atm.
There is some shots in there which the camera is looking straight at the eye of the bird which looks prety cool. This explains why there was a bit of turbulence in one paticular area doesn't it.
Might have to introduce the Mr_B Mascot in this video as the low res from this flight isn't enough to see all that well. We will have to wait & see what happens there.
Mr_B
8)
Mr_B is offline Find More Posts by Mr_B
Old Aug 17, 2010, 06:49 PM
Mr_B is offline
Flying White Rabbit
Mr_B's Avatar
Joined Nov 2009
I think with the colour in these cameras you put a 75 ohm resistor from the video signal to ground which will fix the bland colours and increase the contrast. Its here on the forum somewhere, just cant find it atm. I haven't tried it yet with mine but will be looking into that soon.
Mr_B
8)
Old Aug 17, 2010, 07:12 PM
Firepower
Firepower's Avatar
Joined Mar 2010
Mr_B
8)
Thanks for that. I'll check it out also. It is still a good camera but a bit more colour would be good.
Old Aug 17, 2010, 07:23 PM
Mr_B is offline
Flying White Rabbit
Mr_B's Avatar
Joined Nov 2009
That's the camera I use in the FW190 now, I haven't seen anything that comes close to being as good except the cameras that are like double the price. I have the WDR600 which is just as good as it I think except there is more control over the settings.
I think the osd version with no case is the same camera for an extra couple of $ is great if you are a bit of a tweaker
Mr_B
8)
Old Aug 17, 2010, 07:38 PM
Firepower
Firepower's Avatar
Joined Mar 2010
Mr_B
8)
Thanks - I do not think you can get a better camera for the price.
I just bought three 420 line hobbyking cheapies but I do not know why. (Just cheap and may be handy)
The KX 171 is a 420 line camera and smaller and lighter but I suppose not much netter than the HK ones. Do you know if this is the case?
http://www.nghobbies.com/cart/index....roducts_id=549
EDIT: I see you mentioned OSD version. Why is it OSD version?
Old Aug 17, 2010, 08:03 PM
Mr_B is offline
Flying White Rabbit
Mr_B's Avatar
Joined Nov 2009
Since I have been flying for a bit now I would honestly say don't really bother with the lower res cameras, the video quality is really just ok and that's about it.
I would be more inclined to spend up bigger on the actual camera and try to save on the TX/RX side of things or airframe more than anything now.
A 380TVL camera for fpv, foget it ! Pic turns to mush depending on the situation.
A 420TVL camera is ok for fpv but not that great.
A 550TVL or higher camera is the best and you will have better vision and be able to place the plane better if flying around trees and other obsticles.
The camera is your eyes so I would definantly recommend a camera that has 550TVL and if you want small I would go with something like this @ 5V
http://hobbywireless.com/cart/index....41f3bccb0b1cc9
or if you need 12V then something like this
but I don't think you can ever beat the one from security2000 except from an eBay seller I would think.
Mr_B
8)
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 10803 Yesterday 07:50 AM
Build Log Easy Fly Glider ST330 (Easy Glider Clone) FPV Build Thread SoMoney FPV Talk 493 Nov 12, 2012 03:08 PM
Discussion FPV Beginners Reference Mega Thread... rc_ron FPV Talk 167 Mar 24, 2012 07:31 AM
Cool Aussie XBOX Live thread ozzi supercub Australia 7 Oct 22, 2009 01:42 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
