Old Aug 14, 2010, 01:51 AM
Firepower is online now
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
Originally Posted by AussieHoppy View Post
Ive just got back from a fly, so you've prob already gone flying, gorgeous morning...
My batt's a 1000mAh, fits in perfect, & with this batt and everything pushed as far fwd as possible, the cg seemed good for mine.
See how you go after your maiden, I mixed a little rudder with my ails to clean up aileron turns.
I hope she went well for you
Where do you fly?
Firepower is online now Find More Posts by Firepower
Old Aug 14, 2010, 02:22 AM
AussieHoppy is online now
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
AussieHoppy is online now Find More Posts by AussieHoppy
Old Aug 14, 2010, 04:25 AM
Firepower
Firepower's Avatar
Joined Mar 2010
I was flying at an undisclosed park at Cannon Hill, seldom see anyone at all there early mornings (I won't fly unless it's devoid of people), but a guy from LHS spotted me, told me that the council Fun Police are about to post signs banning any form of rc recreation. Apparently they've actively been fining people & banning more and more areas. Looks like yet another recreation forced into submission, I might have to join TMAC to fly without fear. There are a couple of other places I fly but I wont mention here for obvious reasons.
If you are unimpressed with the ASW, you'll probably remain so lol
I bought mine on special, dirt cheap, so for that reason I didnt mind it, just very "flighty" and flimsy. Treat with care, trim it out, and I actually enjoyed it... but not enough to go looking for prop replacement yet- I have a Cularis on the way...
Where we go there is usually no people but am lucky to go to my mates large property not far away every few weeks.
Cularis - now that is a glider. I should have been happy with the Easy* and EasyGlider which I have only barely started putting together.
When I trim it properly is will be better but looks like any wind is a problem. There was not any wind this morning. Just have to add weight to it and a bigger motor. Probably not.
Old Aug 14, 2010, 05:24 AM
me_wantee is offline
Find More Posts by me_wantee
Not a Doctor
me_wantee's Avatar
Australia, NSW, Sydney
Joined Aug 2006
Had a good day putting 6 packs through the tri today (all visual flight). I'm loving this thing. Sorted the oscillation (note to self - set gyros to act not inh)
Stuck the Go-Pro on and got some footage (complete with a little jello shake)
Sorted out the nervous tail servo with this highly recommended mod to HK gyros.
http://sergio.salvi.ca/2009/10/18/my...ations/?src=hk
Strapping the FPV gear on tonight and will poss. do the fpv maiden in the morning.
It's happening
me_wantee is offline Find More Posts by me_wantee
Old Aug 14, 2010, 08:31 AM
Not a Doctor
me_wantee's Avatar
Joined Aug 2006
Sweet........my Tri-Copter is ready for its FPV maiden tomorrow. I cant wait!!!!!!
No wonder my wife just laughed at me
Old Aug 14, 2010, 09:01 AM
Mr_B is offline
Find More Posts by Mr_B
Flying White Rabbit
Mr_B's Avatar
Joined Nov 2009
Mr_B is offline Find More Posts by Mr_B
Old Aug 14, 2010, 06:32 PM
subsonic is offline
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
What do you guys recommend as the best RX for FPV on 36mhz - PPM or PCM? I'm running a Futaba 9C and am trying to narrow the search between the different RX types
s.
subsonic is offline Find More Posts by subsonic
Old Aug 14, 2010, 08:48 PM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
It's happening
Hmm Are you saying the Yaw gyro did not have the foam in it? I open every gyro and pack with foam... hmm How did I miss that one???
The_Mongrel is offline Find More Posts by The_Mongrel
Old Aug 14, 2010, 09:37 PM
Not a Doctor
me_wantee's Avatar
Joined Aug 2006
Nothing apart from the two standard bits of tape. Meh, it's fixed now.
Went and did the FPV maiden this morning. Started out ok, then I lost video after about 30 seconds??? I'll have to check it out later. No biggie, I picked it up vis and flew it home.
Yesterday while I was flying, the rear motor 'missed' (like when the timings out) a few times resulting in hickups then after about 5 mins stopped altogether. I turned off, dis/reconnected the speedie and turned back and on and it seemend to fix it...so I thought.
It was flying fine today for 10 mins, then the same motor burped a few times, then stopped resulting in a couple of broken props. What causes that?
Old Aug 14, 2010, 10:09 PM
narcas is offline
Find More Posts by narcas
Lame-As The real alternative!
narcas's Avatar
Bulli, Australia
Joined Nov 2006
I wish I read all this before I forked out for a setup
Did you record the video?
narcas is offline Find More Posts by narcas
Old Aug 14, 2010, 11:07 PM
Joined Dec 2007
Hmm.. Could be the motor or the ESC. I can't tell you either way, as does not happen often. I have had some reports of a bearing going, but again, rare.
My current copter has the original ESCs and Motors, and I can't even imagine how many flights (and crashes) it has had.
Let me know what you find out. Do some static bench tests swapping ESCs etc and get back to me.
Cheers
Mongrel
Old Aug 14, 2010, 11:09 PM
Joined Dec 2007
What setup did you get? You purchased the goggles through us, but what did you settle on for TX/RX??
Old Aug 14, 2010, 11:29 PM
chancesAU is offline
Find More Posts by chancesAU
chancesAU's Avatar
Australia
Joined Apr 2008
s.
Futaba PCM RX's are too exy, go the corona 9ch for $20 if you want bang for buck.
I would trust the futaba PCM RX over the corona but the price is scary.
I got 2 R319DPS RX's and they go into anything big and/or expensive.
Neither have randomly failed on me but $20 dont seem like alot of money for the thing thats flying your plane
chancesAU is offline Find More Posts by chancesAU
Old Aug 15, 2010, 12:20 AM
subsonic is offline
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
So, you prefer the PCM RX's because they offer better range? why are they better?
s.
Old Aug 15, 2010, 12:48 AM
chancesAU's Avatar
Australia
Joined Apr 2008
s.
Well ive never modified an RX antenna but Ive had my stock R319DPS RX in 2 different planes with different video TX's / setups.
The funjet I had locked out on me with 30 meters altitude @ 300meter from home this was at a big park in town.
Another time in an apprentice I was 1.1km from home @ 250m and it locked out, this flight was done in a remote area with complete LOS.
I didnt trust it after that for long range.
I still think its very reliable, the price is a big turnoff.
Also PCM is propriety to the brand, eg. futaba PCM wont work with JR or Multiplex...
PPM Rx's like the corona are universal, some say the overhead which PCM uses to encode the data (which makes it "glitch free") reduces the range a little and increases latency, I dont know if thats correct but it kinda makes sense?
A new corona well looked after should preform amazingly, I have one coming tomorrow for an FPV wing, it should be great for inside 1km.
Antennas on them are a little flimsy compared to the nice thick futaba ones... this can be changed with a little solder work
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 10724 Feb 04, 2016 08:14 PM
Build Log Easy Fly Glider ST330 (Easy Glider Clone) FPV Build Thread SoMoney FPV Talk 493 Nov 12, 2012 04:08 PM
Discussion FPV Beginners Reference Mega Thread... rc_ron FPV Talk 167 Mar 24, 2012 08:31 AM
Cool Aussie XBOX Live thread ozzi supercub Australia 7 Oct 22, 2009 02:42 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 06:37 PM
