Old Aug 10, 2010, 05:07 PM
AussieHoppy is offline
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
AussieHoppy is offline Find More Posts by AussieHoppy
Old Aug 12, 2010, 01:51 AM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
BARGAIN!!!!!
Better be quick I reckon!!
http://www.rcgroups.com/forums/showp...&postcount=548
The_Mongrel is offline Find More Posts by The_Mongrel
Old Aug 12, 2010, 02:46 AM
Griffo is offline
Find More Posts by Griffo
Griffo's Avatar
Australia
Joined Oct 2003
PM'd him .
Although it's tx only. Actually, If you buy the 10C kit brand new from PowerGrunt Hobbies for $600 and sell the $260 rx that comes with it then it's not really much of a bargain.
Griffo is offline Find More Posts by Griffo
Old Aug 12, 2010, 03:40 AM
Joined Dec 2007
Really!! The 12 Channel Rx that comes with it is worth $260?? FWARK!!!
Old Aug 12, 2010, 03:57 AM
Griffo is offline
Griffo's Avatar
Australia
Joined Oct 2003
It comes with a 14 channel Rx. $260... Yes, Fwark!
Old Aug 12, 2010, 04:08 AM
Joined Dec 2007
14?? Not the 10Cs I have ordered from Futaba?? They come with a 12 Channel.
Do you have a link?
Old Aug 12, 2010, 04:15 AM
Griffo is offline
Griffo's Avatar
Australia
Joined Oct 2003
Yeah mate. Unless I've missed something it says it comes with the 14ch.
10C kit from Powergrunt:
http://powergrunthobbies.com.au/shop...oducts_id=2226
Futaba R6014 rx:
http://powergrunthobbies.com.au/shop...oducts_id=4533
Old Aug 12, 2010, 05:02 AM
Und3rmind is offline
Find More Posts by Und3rmind
Joined Aug 2010
Hello
Im a complete noob at this i have only been flying for a few months and looking in to start building a fpv setup what radio controller would be best for this and what range would i get please if you could recommend a setup atleast a 7c system
Sorry im trying to learn as much as i can.
if anyone can help my out it would be great help
Und3rmind is offline Find More Posts by Und3rmind
Old Aug 12, 2010, 05:14 AM
Firepower is offline
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
Originally Posted by The_Mongrel View Post
BARGAIN!!!!!
What a night to come home late. I PMed him and said I was in Brisbane which may help.
Probably too late. Bugger. Thanks for putting it up on here.
Firepower is offline Find More Posts by Firepower
Old Aug 12, 2010, 06:51 AM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Originally Posted by Und3rmind View Post
Hello
Hi There,
Welcome aboard.
Its still not too late to reconsider, as you will possibly become addicted.
Most guys find that 36Mhz is the preferred frequency.
Seems to give better range and is more resilient when obstacles get in the way.
Most guys use Futaba.
9Ch is very popular but you can have less. 7 is doable.
More is better.
Get a good handle on RC flying first before trying to FPV.
Range is extremely variable depending on how you set up your plane, as extra electronics can affect your rc reception, but a well setup 36Mhz should be good for at least 1.5-2Km.
I personally havent flown beyond 3600ft away yet, but am being cautious.
There are long range setups you can attach to your R/C to go 15Km+.
Check out the stickys at the entance to the forum. Theres most of the stuff there that you need to know.
Cheers
Frank
ommadawn is offline Find More Posts by ommadawn
Old Aug 12, 2010, 06:55 AM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
Cheap FPV
Hi guys. I am a reasonably experienced pilot (enjoying flying scale, 3-D and helis), and I've decided to have a go at FPV, but first I want to do a really cheap and simple set-up to see if I enjoy it.
I want to set something up with about 200-300 metres range so I can fly around my local park. I will be using a small electric foamie trainer style plane. Plane only weighs about 300 grams, and I'll be flying very low and slow (say 50 to 100ft altitude). Park is about 300 x 500m square, and I only fly when there is no-one around...so no safety issues flying such a small plane low and slow. I'll also use a spotter with buddy box (yes, I'm paranoid).
I only have 2.4G Spektrum radio gear, and am hoping not to have to buy anything else, at least for this venture.
I was thinking of trying one of those combined Camera/AV transmitter/AV receiver setups that you can buy for $35 on ebay, making up the goof proof patch antenna to suit, and simply using my laptop to display the picture. Definitely not wanting to get into gyro pan/tilt system, although could use a simple servo connected to the rudder for pan if I want.
Firstly, which frequency should I get? I guess 2.4G is no good with my Spektrum gear, so should I get 900M or 1.2G? I have read that 900M may clash with mobile phones, but that 1.2G could have a second harmonic that would clash with the 2.4 GHz. (The 2nd harmonic idea throws me a bit, as I always thought it was odd harmonics such as 3rd, etc that were generated by any waveform distortion.)
Also, am I going to upset anyone using either of those frequencies? If so, and given I only want the limited range, what is the minimum power that I should be able to get away with, as they are available in many power ranges. (100mW, 200mW, 500mW, etc.)
Harrow.
P.S. I can already hear suggestions that I should buy a decent setup to start (36MHz radio, etc.), but really, I just want to have a simple dabble at the moment as I don't have time (or storage space!) to get serious with this at the moment due to current family/work situation.
Harrow is offline Find More Posts by Harrow
Old Aug 12, 2010, 08:44 AM
chancesAU is offline
Find More Posts by chancesAU
chancesAU's Avatar
Australia
Joined Apr 2008
I rang both ur mobiles, ur home and ur voip!
chancesAU is offline Find More Posts by chancesAU
Old Aug 12, 2010, 08:46 AM
Joined Aug 2010
thanks ommadawn for the reply but yeah its way too late for me im already lost to this hobby.
could anyone recommend a good australian or online store i could buy a Futaba 9c 36mhz radio system from.
Old Aug 12, 2010, 08:57 AM
chancesAU's Avatar
Australia
Joined Apr 2008
Yes! North Coast Hobby Center in Lismore
Ordered in the arvo, had it the next morning
Nice guys too...
+61 2 6621 3956
May only have 10c?? youll have to call
Old Aug 12, 2010, 09:04 AM
Joined Aug 2010
thanks chancesAU i will give them a call
Discussion FPV Car and Other Fun FPV Projects Thread: Crash9 FPV Talk 10995 Yesterday 08:09 PM
Build Log Easy Fly Glider ST330 (Easy Glider Clone) FPV Build Thread SoMoney FPV Talk 493 Nov 12, 2012 03:08 PM
Discussion FPV Beginners Reference Mega Thread... rc_ron FPV Talk 167 Mar 24, 2012 07:31 AM
Cool Aussie XBOX Live thread ozzi supercub Australia 7 Oct 22, 2009 01:42 PM
Discussion FPV WARS (Thread for FPV "B" Movies) ch1 FPV Talk 8 Sep 16, 2009 05:37 PM
