Old Nov 23, 2009, 06:09 PM
Blueangels4 is offline
Find More Posts by Blueangels4
orlando FL
Joined Aug 2005
Build Log
Prop in slot Kfir / Mirage 6mm depron
Profile prop in slot Kfir/Mirage 6mm depron
here is my latest untried plan,.. its full size for any risk takers to tryout,.. as of yet I have no idea of the weight or center of gravity any testers wanna try it out go for it,..
I suspect it should fly just like the draken,...(please oh please oh please)
%100 inspired by GGRN's build
I plan on building it soon myself to work out any possible bugs
specs as of now:
Wingspan: 27.375”
Length: 41.5”Motor: 2212-06 (2200kv)
Prop: APC 6x4E
6mm depron.
2 Servos on the elevons only.
Blueangels4 is offline Find More Posts by Blueangels4
Old Nov 24, 2009, 07:07 AM
orlando FL
Joined Aug 2005
***UPDATE!!!!*** I will be revising in a major way,.. the only reason why the wing was so high was to accomadate the forward fuse,.. as i lower the wing, the forward fuse no longer makes sense to have BUT I will be losing extra lift,... and the knife edge profile look
I suspect this is why certain models 'werk' and some don't!
Old Nov 24, 2009, 03:28 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Yeah, it's tough to do a profile of these types of planes, unless you build up the upper fuse area like nac did with his F-4 Phantom. Because there are no intakes under the wing, you have a hard time creating an electronics bay.
Good luck on the revisions. Study up on nac's F-4 to get some ideas about how to still create a 3D nose section. You can use separate pieces of foam to the intakes for that if need be.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Nov 24, 2009, 04:40 PM
orlando FL
Joined Aug 2005
thanks for the Nac inspiration!,.. I think I can make it work that way,..
Old Oct 23, 2013, 04:28 PM
hfenn is offline
Find More Posts by hfenn
Barnwell, SC
Barnwell, SC
Joined Sep 2004
Sorry for grave digging (but it is nearly Halloween), but was this ever built? Any thought on moving the motor back so the slot would not be open at the top or bottom? Thanks in advance if you care to respond. Hollis
hfenn is offline Find More Posts by hfenn
Build Log Prop in slot Saab Draken - Plans (6mmFlyRC) vleisie Pusher Prop Jet Models 757 Jun 03, 2016 04:41 AM
Build Log Bede BD-5, 6mm Depron, plans vleisie Pusher Prop Jet Models 2 Nov 13, 2009 07:45 PM
Discussion 6mm depron profile plane ?? scousethief Scratchbuilt Indoor and Micro Models 2 Oct 31, 2009 12:30 PM
Discussion 6mm depron for 24" Parkflyer Pete?? Truman40 Foamies (Scratchbuilt) 3 Oct 30, 2009 11:19 AM
Discussion Slot design for "prop in slot" leadfeather Foamies (Scratchbuilt) 32 Oct 17, 2008 09:45 PM
