Old Sep 18, 2001, 10:11 PM
budorren is offline
Find More Posts by budorren
Desert Rat
Rancho Mirage. CA
Joined Jul 2001
OLY II fuselage
I have flown an OLY II for years with an Astro Cobalt 15 on direct frive with 8 cells and a large folder. It was a wierd combination but it worked very well. Unfortunately, the fuselage is gone (don't ask) but the wing is fine. Any idea where I can get a fusalage only, preferably in kit form? BudOrren in Rancho Mirage.
budorren is offline Find More Posts by budorren
Old Sep 19, 2001, 01:28 PM
Jacques Flambeau is offline
Find More Posts by Jacques Flambeau
Restful User
Jacques Flambeau's Avatar
Backwoods Alabama
Joined May 2000
Whyte Wings is no longer kitting the Oly II, so you are SOL for a fuse kit.
Best solution is to get a set of Oly II plans from RCM ( http://www.rcmmagazine.com/ ) and scratch-build the fuse.
--Bill
Jacques Flambeau is offline Find More Posts by Jacques Flambeau
Old Sep 19, 2001, 06:18 PM
budorren is offline
Desert Rat
Rancho Mirage. CA
Joined Jul 2001
Bill-Thanx for the info. Now I know why I have not been able to find the OLY in a catalogue or ad. Any suggestion for a kit close enough to use the wing and the electrifying? Bud
Old Sep 20, 2001, 09:26 AM
Restful User
Backwoods Alabama
Joined May 2000
Not practical to look for a "fuse kit" for an airplane. Fuse kits are not available. Wing kits are available and supply die- or laser-cut sheets of ribs since ribs are a PITA to cut from plans.
You could take your old fuse, make measurements and build a replacement from scratch or buy the plans and scratch build the fuse. The Oly II fuse and tailfeathers are not that difficult to make from sheets and sticks.
DreamCatcher has a lot of nostalgia kits and short kits: http://www.dchobby.com/ .
Good luck!
--Bill
FS OLY II Fuselage CHARLIE BRITT 7 Aircraft - Sailplanes (FS/W) 10 Jan 29, 2005 07:23 AM
Oly II budorren Aircraft - Electric - Airplanes (FS/W) 1 Dec 05, 2001 07:53 PM
Oly Ii budorren Electric Sailplanes 0 Dec 05, 2001 07:14 PM
Oly II C/G Gliderguy Electric Sailplanes 1 Oct 19, 2001 11:52 AM
F.S. Two Kits Oly II & Electro Express Ed Bassick Aircraft - Electric - Airplanes (FS/W) 0 Sep 26, 2001 12:24 PM
