Old May 03, 2003, 09:41 AM
mini-ellipse is offline
Find More Posts by mini-ellipse
mini-ellipse's Avatar
Stuck in Norway
Joined Feb 2003
Bad luck or..?
Guys,
in seven flight's I've cracked 4 white/black mini Gunther props, one large black Gunther-prop and 2 "pico-stick"-props..Just bad luck or... Ain't the props "unbreakable"
The arplanes I've used 'em on is something called HyperCub (an Old DPR rubber powered converted into electric model) and a "PizzaBox-aircraft"
Kristian
mini-ellipse is offline Find More Posts by mini-ellipse
Old May 03, 2003, 10:33 AM
NightSwan is offline
Find More Posts by NightSwan
Hmm, kerosene... :)
NightSwan's Avatar
Weert(LB) - the Netherlands
Joined May 2002
The only way I'm able to break the gunthers, is nose-in at full speed into concrete!
How do you land?
Hans
NightSwan is offline Find More Posts by NightSwan
Old May 03, 2003, 05:32 PM
Mike Taylor is offline
Find More Posts by Mike Taylor
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
I lose the Gunthers on a regular basis when they spin of the shaft of the Firefly, but I've never broken one. Perhaps you should shut the power off before you make contact...
Mike Taylor is offline Find More Posts by Mike Taylor
Old May 03, 2003, 05:51 PM
aeropenguin is offline
Find More Posts by aeropenguin
Who Says Penguins Can't Fly?
aeropenguin's Avatar
Bay Area, California
Joined Jan 2003
Yes, I was going to say what Mike did - maybe you should throttle off before you land, or, maybe your landing gear isn't tall enough or juuuuust baaaarely is? That's my best guess. If so, and nothing can be changed, I guess I'd cut throttle a while before landing, and if the prop stops spinning in a vertical position, then do a short burst of throttle, and see where the prop stops again. Repeat until it ends up horizontal, or close.
This is ridiculous, and for me, would kill the fun of flying, but just a thought.
-aeroP
aeropenguin is offline Find More Posts by aeropenguin
Discussion UnitedHobbies Servos, Good or Bad Luck?? Butch777 Electric Plane Talk 4 May 26, 2007 01:12 PM
Discussion Bad Luck Today - Is it Friday the 13th or something? oeginc Electric Plane Talk 7 Jul 03, 2006 11:07 PM
The number 13. Good luck, bad luck, depends, or neither. jay flay tway Life, The Universe, and Politics 16 Aug 18, 2005 03:42 AM
Bad luck or bad charger? JamesD Parkflyers 7 Mar 04, 2002 04:40 AM
Bad luck with I'net purchases Larry Dudeck Electric Plane Talk 7 Jan 13, 2002 08:25 AM
