Old Aug 31, 2011, 02:31 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Thank you sir!
[/B]
Originally Posted by MIT KID View Post
Now that I have it all together, I'll add all the servo/wire cutouts to my drawings and repost the plans.
-A
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Aug 31, 2011, 02:53 PM
profilefan is offline
Find More Posts by profilefan
profilefan's Avatar
United States, NY, New Hyde Park
Joined Jun 2008
Put together a 50% scale version of the Su-27 from rc.tomhe.net, for the innards of a crunched Beast.
I had to clip the prop by around 0.5in to fit into the slot, but it still has a bit over 1:1 thrust at 48g. Flies great with the tailerons and rudder.
-Adam
Great job Adam, any chance you have a video? Let me know if you plan to sell it
profilefan is offline Find More Posts by profilefan
Old Aug 31, 2011, 04:04 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
Originally Posted by buratino View Post
Very nice plane, I wanted to build a similar plane with 1S setup but till now still can not find a good 1s brushless which can provide 40-50g of thrush.
How about these?
TODD
http://www.microbrushless.com/productsG1.htm
http://www.micronradiocontrol.co.uk/gp_motor.html
I R Irv is offline Find More Posts by I R Irv
Old Aug 31, 2011, 08:00 PM
buratino is offline
Find More Posts by buratino
Singapore
Joined Nov 2007
Hi Todd, I saw these motors but the price bit too high for my budget. Now I am thinking of AP05 motor to run on 1s, not sure if any one tested this setup before.
buratino is offline Find More Posts by buratino
Old Sep 03, 2011, 11:12 AM
Cheese5 is offline
Find More Posts by Cheese5
Cheese5's Avatar
United States, CA
Joined Jul 2010
Here's my micro stryker(First build that flies!!). Haven't flown it at the park yet, but it did fly into the trees in my backyard.
Cheese5 is offline Find More Posts by Cheese5
Old Sep 03, 2011, 07:51 PM
Faethor is offline
Find More Posts by Faethor
Minneapolis, Minnesota
Joined Jul 2007
It appears you're using the ELE servo on the brick for one control and an external servo for the other..? Why the extra servo, you should be able to use the two servos on the brick.. Unless you haven't got a TX that'll do elevons? Nice looking plane, btw!
Jay
Faethor is offline Find More Posts by Faethor
Old Sep 03, 2011, 09:15 PM
Cheese5 is offline
Cheese5's Avatar
United States, CA
Joined Jul 2010
Jay
Oh I see your point. Didn't think of that before. I'm using a DX5e, going to get a DX6i soon so I could remove that servo and save some weight.
How do you trim a flying wing? The one I built does not fly well at all. It will suddenly pitch downwards for no apparent reason. I have the battery all the way in front and the balance is around 1/3 of the length of the wing. If I pull inverted it will pitch up and spiral. When I glide tested it level it will tuck under and pitch downwards. What's wrong with the wing?
Old Sep 03, 2011, 09:28 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
I'm suprised it works this way with a DX5. I had to swap sides (brick on right, servo on left the get elevons to work with a DX5)
To get a wing to fly stable, you need reflex (washout) at the tips. The trailing edges of the elevons should visibly go up as you go out towards the tip from the root.
UNGN is offline Find More Posts by UNGN
Old Sep 03, 2011, 09:46 PM
Andy2No is offline
Find More Posts by Andy2No
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
How do you trim a flying wing? ... the balance is around 1/3 of the length of the wing
The 1/3 rule is about area, not length, so you need the CG further back. I don't think the rule applies to flying wings though.
There used to be a flying wing CG calculator on geocities. I saved it a while ago so here it is. If you have Microsoft Excel, you can plug the numbers in and get an answer, If not, just refer to the diagram and use a calculator.
Incidentally, your fins look a bit big. It is possible to have too much fin. Maybe the drag on them is contributing to the problem.
Andy2No is offline Find More Posts by Andy2No
Old Sep 03, 2011, 10:01 PM
Cheese5 is offline
Cheese5's Avatar
United States, CA
Joined Jul 2010
Ok I plugged in the numbers (17cm for R, 4.3cm for T and 25 degrees for S) and got 12.99cm as the Cg. Is that from the back to front or from the front to back?
I removed the fins and tried smaller wingtip SFGs. Had the same problem How do you add washout(what is washout? first build for me that flies still new to all this).
Old Sep 03, 2011, 10:02 PM
Cheese5 is offline
Cheese5's Avatar
United States, CA
Joined Jul 2010
I had to reverse the aileron mechanically and then reverse the aileron on the DX5e to get it to work, weird. How do you add reflex?
Old Sep 03, 2011, 10:54 PM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Ok I plugged in the numbers (17cm for R, 4.3cm for T and 25 degrees for S) and got 12.99cm as the Cg. Is that from the back to front or from the front to back?... How do you add washout(what is washout? first build for me that flies still new to all this).
S is a distance marked on the diagram, rather than the angle.
I guess that makes S = 17 - 4.3 so 12.7cm, which makes the CG 8.066cm. I see your point; it's not marked on the diagram where you measure from. I believe it's from the front. Fortunately, the calculated CG is almost half way from the nose (slightly forward) so it won't matter too much if I'm wrong
Washout is a warp that makes the wingtips a little higher at the trailing edge than at the leading edge. Usually, only a small outer section of the wings gets the warp.
Reflex just means a bit of up elevator trim. A well balanced flying wing flies level with a couple of degrees or so of reflex.
Last edited by Andy2No; Sep 03, 2011 at 11:27 PM. Reason: mistyped value for S. CG is right though.
Old Sep 03, 2011, 10:58 PM
Cheese5 is offline
Cheese5's Avatar
United States, CA
Joined Jul 2010
I guess that makes S = 17 - 4.3 so 12.3cm, which makes the CG 8.066cm. I see your point; it's not marked on the diagram where you measure from. I believe it's from the front. Fortunately, the calculated CG is almost half way from the nose (slightly forward) so it won't matter too much if I'm wrong
Washout is a warp that makes the wingtips a little higher.
Oh didn't see that. So 8cm, that would mean the last few flights I've had were extremely nose heavy... I'll add some washout, already have reflex on the wing.
Old Sep 03, 2011, 11:16 PM
Andy2No is offline
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Cheese5,
I edited that shortly after, while you were typing. The wing tips are twisted up at the back, is what I meant.
Here's a diagram. I borrowed it from here:
http://www.laboratoridenvol.com/para...ign/voute.html
Old Sep 03, 2011, 11:34 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Here is a picture of the ME163 Komet from the Deutches Museum in Munich to show reflex on an actual flying wing.
The Ange of Incedence of the wing is positive to longitudinal axis of the plane (shown as the centerline in my diagram) at the root and negative at the tip.
This is the proper way to set up a stable flying wing so that it creates maximum lift, without being prone to tip stalling.
If it's good enough for the fastest plane in WWII, it should be good enough for a micro wing.
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
