Old Dec 12, 2009, 03:31 PM
Bowerz is offline
Find More Posts by Bowerz
No, I dont work for HH ;)
Bowerz's Avatar
Southampton, Hampshire, UK
Joined Sep 2009
Originally Posted by dylantorquerol View Post
Thanks. I just added everything up, and AUW should be 41g. It will probably be awhile before I get electronics, but I could get them for Christmas. So no vids yet.
Don't forget about glue weight aswell!! that will be another 2g.
Bowerz is offline Find More Posts by Bowerz
Old Dec 12, 2009, 03:34 PM
dylantorquerol is offline
Find More Posts by dylantorquerol
Love the sport, not the plane
Hawaii
Joined Oct 2009
I know. I will try to get my wing area and wing loading soon.
dylantorquerol is offline Find More Posts by dylantorquerol
Old Dec 12, 2009, 04:27 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
mine came out at 95g which gives a .4g/sq. in wing loading. If you can keep your wing loading around that, you should be fine. Their is 210sq.in of wing area on my 20" ws version, and that isn't taking into account the fuselage cross spline that the hoverflaps are incorporated into.
invertmast is offline Find More Posts by invertmast
Old Dec 12, 2009, 10:00 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Here is my Cox/Gravity Warbirds Zero. Got my 5g motor from HK on Friday so I can get back to this since I stopped working on it a few weeks ago.
Left to do are the Ailerons (I'm going to do dual servo Easy Flaperons) and engineering the landing gear, but the Fuselage electronics are all in and the fuse is buttoned up.
AUW is going to be right around 4.2 Oz in 5 channel mode (A/E/R/T/F). The 5g motor seems to have a lot of power and it should fly like a Warbird. The 2S 360 Rhino gave me 7+ minutes at WOT throttle with a 5043 prop in bench testing so flight times should be Huge.
These models are great fun to build and modify for cheap so I ordered 3 more today.
UNGN is offline Find More Posts by UNGN
Old Dec 12, 2009, 11:30 PM
Hawaii
Joined Oct 2009
That wing area doesn't really help becauyse mine is 6" smaller. I can just get LxWx2 and get wing area. 4th grade math! Go me!
Old Dec 13, 2009, 12:27 AM
Veteran is offline
Find More Posts by Veteran
Mc-Fly
Veteran's Avatar
Melbourne-Australia
Joined Mar 2008
Looking great, so can the Ar6400 handle a 2s lipos without mods?
Veteran is offline Find More Posts by Veteran
Old Dec 13, 2009, 01:10 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Yes and No.
The AR6400 isn't modded in any way, but you run the Brick off the BEC of the ESC, with a Voltage dropping diode (about $0.25) in the Positive power wire of the Brick, then run the signal wire to Motor plug.
Old Dec 13, 2009, 03:59 AM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
That wing area doesn't really help because mine is 6" smaller. I can just get LxWx2 and get wing area. 4th grade math! Go me!
That won't give you the area. Because of compound curves or basically your wing isn't exactly square, and even if it was, that formula wouldn't give you it. Its just WxL, i don't know where the 2 came from. Give me you plans, and i'll grid it with one inch squares then work it out for you.
Old Dec 13, 2009, 06:50 AM
Veteran is offline
Mc-Fly
Veteran's Avatar
Melbourne-Australia
Joined Mar 2008
Yes and No.
Great, thanks mate.
Old Dec 13, 2009, 09:04 AM
Joined Mar 2004
for finding the wing area on mine, i averaged the root chord and tip chord (6" and 5" respectively) and multiplied this by the span. which comes out to 110 sq.in per wing. its not 100% accurate since the wing has a curved LE, but i have found its close enough, and quicker than counting squares
Old Dec 13, 2009, 09:48 AM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
Lol, I like my square counting method, i can get pretty close!
Old Dec 13, 2009, 08:30 PM
Hawaii
Joined Oct 2009
I did x 2 because there are 2 wings. Remember? I will just do the square counting method.
Old Dec 14, 2009, 02:16 AM
Andrew Lai is offline
Find More Posts by Andrew Lai
Joined Nov 2009
Finally find the foams!!! Here is my little AR6400 plane that took me a few hours!
Time to show off! Take a look! Hope you like it, and again thanks for telling me where to get the foam boards. =D
Andrew Lai is offline Find More Posts by Andrew Lai
Old Dec 14, 2009, 04:07 AM
arnaudmz is offline
Find More Posts by arnaudmz
arnaudmz's Avatar
France
Joined Nov 2007
Here's mine
I folks!
Mostly inspired by leadfeather's Yak 55 design (which just rocks BTW). I also stole the decoration scheme in his thread.
Description: Name: p1010097r.jpg
Description: Name: p1010098r.jpg
Description: Name: p1010099r.jpg
Description:
Description: Name: p1010102r.jpg
Description:
AUW: 27g
AR6400 + 2 AS2000
HC AP05 3000kv + GWS5030
HC XP 3A1S 0.7g ESC
HC 1S240 20C battery
all made of 3mm EPP
.5mm carbon for fuselage & wings bracing, hope it will be strong enough.
.8mm carbon for LG & pushrods
arnaudmz is offline Find More Posts by arnaudmz
Old Dec 14, 2009, 06:59 AM
somt1033 is offline
Find More Posts by somt1033
Hamburg, Germany
Joined Nov 2006
Very Nice! how much span?
somt1033 is offline Find More Posts by somt1033
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
