Old Dec 10, 2009, 11:12 AM
Hugequark is offline
Find More Posts by Hugequark
4 8 15 16 23 42
Hugequark's Avatar
Syracuse, NY
Joined May 2005
Originally Posted by dylantorquerol View Post
BTW, WHERE ARE THE PLANS FOR THE 6TH VER.4 BIPE? Can I have a link please? I can't find them.
It's in the F3P plans sticky.
http://www.rcgroups.com/forums/showt...=550372&page=9
Hugequark is offline Find More Posts by Hugequark
Old Dec 10, 2009, 05:32 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
well.. for some reason my motor/prop/esc combo wont go to full throttle.. so looks like i get to wait another 2 weeks for a a new part to come it.. if i can figure out whats wrong with the junk on it now..... grrrrrr
invertmast is offline Find More Posts by invertmast
Old Dec 10, 2009, 05:37 PM
Bowerz is offline
Find More Posts by Bowerz
No, I dont work for HH ;)
Bowerz's Avatar
Southampton, Hampshire, UK
Joined Sep 2009
Try a higher C rated battery or check the connections on the battery (including soldering). I had that problem and doing both of those things sorted it. Also check the programmed settings of the ESC (if it is programmable) and check if the high and low points on the throttle stick are set correctly.
Bowerz is offline Find More Posts by Bowerz
Old Dec 10, 2009, 07:42 PM
dylantorquerol is offline
Find More Posts by dylantorquerol
Love the sport, not the plane
Hawaii
Joined Oct 2009
That stinks. What is your current C rating?
dylantorquerol is offline Find More Posts by dylantorquerol
Old Dec 10, 2009, 08:06 PM
Joined Mar 2004
Bowerz,
Checked all the solder joints.. The ESC is programmable, but only if you have a programming card, but yet no programming card is mentioned being available or needed (until you get the esc).. and when i try and set the high and low throttle points, it doesn't act like the directions say it should.. And since i had to chop the servo cable, i doubt the place will take it back if its bad... Luckily the LHS has a CC phoenix 10 on the wall, so i may go pick that up tomorrow.
C rating on the battery is 16c.. which is good for 4A continous and 6a burst. With the prop i'm running, i should pull about 4.5a at full throttle and make about 190g of thrust.
If i go to a GWS 6030 i'll pull about 3.2a at full power, and make 150g of thrust
Old Dec 10, 2009, 08:57 PM
Hawaii
Joined Oct 2009
that stinks. Why did you chop the wire?
Old Dec 10, 2009, 09:11 PM
Joined Mar 2004
so i could put a connector on so it would fit the ar6400
Old Dec 10, 2009, 09:19 PM
Hawaii
Joined Oct 2009
I get it! I thought you meant only 1 wire, not all three! oooops!
Old Dec 11, 2009, 01:23 AM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
Try i higher rated C battery to test the setup, not all of them are true. And if you made the pack yourself, or connected any wires on the set up, your solder may have been "dirty". Go back and resolder connections aswell.
Old Dec 11, 2009, 04:23 AM
beastII is offline
Find More Posts by beastII
Joined Oct 2006
Here are a couple of mine. Cart is based off leadfeather design and witch is scaled down from a design in scratchbuild section from a few years back. both were built at end of summer. Both fly but am still twiking
beastII is offline Find More Posts by beastII
Old Dec 11, 2009, 04:36 AM
Andy2No is offline
Find More Posts by Andy2No
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
I like the cart, beastII. It would be good to see it from a few more angles.
I made a model based on my Citroen Saxo (small french hatchback) with a Vapor brick, which was meant to fly, only it didn't. It was a bit too heavy anyway, and the GB07 brushed power system just wasn't up to it. I might have another go at a flying car one day though. That one may as well remain as an ornament.
Andy2No is offline Find More Posts by Andy2No
Old Dec 11, 2009, 03:30 PM
Joined Mar 2004
Got the issue w/ my bipe fixed. I put a CC phx 10 esc on and it works great. Overall weight came out to 95g. 15g heavier than i wanted, but i could probable shave 3 to 5g of weight be getting rid of some excess wires. but i'm not to worried about it. it will hover at a little under 3/4 throttle right now w/ a apc 7x3.8w prop.
Old Dec 11, 2009, 04:11 PM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
Wow very nice!
Old Dec 11, 2009, 05:57 PM
Meshuggah is offline
Find More Posts by Meshuggah
Nothing flies like a Pitts
Meshuggah's Avatar
Stockholm, Sweden
Joined Aug 2006
Off topic: Does my sharp eyes se a F14 TomCat?
Meshuggah is offline Find More Posts by Meshuggah
Old Dec 11, 2009, 06:17 PM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
I knew I wasn't the only person.
boredom.is.me is offline Find More Posts by boredom.is.me
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
