Old Nov 27, 2010, 11:26 AM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
My Elf's
My Elf's 18, 20 and 22"ws: top left and center: 20" ; right:22"; bottom: left: 22"; center and right: 18""
the 18" has 80 sq in and 40 gr auw; the 20" 100 sq in and 42 gr; the 22" 120 sq in and 48 gr auw.
6400 brick, clear end bell motor from champ; 160/70 prop; cirrus esc with brake; 110 t0 160 mah cell. 1 and 2 mm depron.indoor or no wind outdoor. more details in my blog or at the indoor and micros.
simplest thing to build, and the closest to a paper plane i ever had. trainer and sport backyard flyer.
i fly it at my backyard whenever there is no wind at dawn-just walk a few steps and there i am, practicing take-offs and landings from a walkway, very much as aircraft carrier style-or catching it.
never had so much fun-and for pennies!
phil alvirez is offline Find More Posts by phil alvirez
Old Nov 27, 2010, 01:23 PM
samson55 is offline
Find More Posts by samson55
samson55's Avatar
United States, IL, Rockford
Originally Posted by UNGN View Post
Here is my Cox/Gravity Warbirds Zero. Got my 5g motor from HK on Friday so I can get back to this since I stopped working on it a few weeks ago.
Left to do are the Ailerons (I'm going to do dual servo Easy Flaperons) and engineering the landing gear, but the Fuselage electronics are all in and the fuse is buttoned up.
AUW is going to be right around 4.2 Oz in 5 channel mode (A/E/R/T/F). The 5g motor seems to have a lot of power and it should fly like a Warbird. The 2S 360 Rhino gave me 7+ minutes at WOT throttle with a 5043 prop in bench testing so flight times should be Huge.
These models are great fun to build and modify for cheap so I ordered 3 more today.
how did this zero fly? I know they are 2x times the weight of a UM P51 - but with that brushless it should have flown well?
samson55 is offline Find More Posts by samson55
Old Nov 27, 2010, 04:53 PM
XtremeWingRC is online now
Find More Posts by XtremeWingRC
Scobee Field & HTOWN FPV
XtremeWingRC's Avatar
United States, TX, Houston
Joined Oct 2007
UMX beast power train now on a wing
20" wing using AR6400BL from UMX beast (2 min 18 sec)
casey
XtremeWingRC is online now Find More Posts by XtremeWingRC
Old Nov 27, 2010, 09:59 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
It flies great. The AR6400 is the best set up for the cox/gravity micro warbirds to keep the weight down to 115g or less.
UNGN is offline Find More Posts by UNGN
Old Nov 28, 2010, 05:32 PM
miatamama is offline
Find More Posts by miatamama
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
Here is my favorite windy day flyer. I saw the post on the dyke delta and had to make my own version. This is to date the best flying wing I have piloted. I will not hesitate to fly on windy days with this plane. Will fly it in the Gym in a couple of weeks.
5 gram brushless, orange 4channel dsm2 and pentium 6 ESC.
JCS
miatamama is offline Find More Posts by miatamama
Old Nov 29, 2010, 09:53 AM
ducatirdr is offline
Find More Posts by ducatirdr
ducatirdr's Avatar
United States, MA, Sutton
Joined Aug 2006
Dumas Curtiss P-6E
Here is the build log
Dumas Curtiss P-6E conversion
Tom
ducatirdr is offline Find More Posts by ducatirdr
Old Nov 29, 2010, 10:26 AM
Brent Slensker is offline
Find More Posts by Brent Slensker
Weni, wedi, Java...
Brent Slensker's Avatar
Casper, Wyoming
Joined Nov 2009
Great!
Brent Slensker is offline Find More Posts by Brent Slensker
Old Nov 29, 2010, 10:43 AM
starscream4002 is offline
Find More Posts by starscream4002
starscream4002's Avatar
Tabriz, Iran
Joined Sep 2008
beautiful!
starscream4002 is offline Find More Posts by starscream4002
Old Nov 29, 2010, 10:12 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Gee BEE
With the GeeBEE plans from another thread which uses the plantraco gear; I have made a larger version suited to the AR6400 with an AP05 BL motor set up.
This is a 3 ch, with under-cambered wings with dihedral. She is a little and would be better suited to a 2S set up. The build was going great until I had some issues with the paint eating the foam in certain areas - so its not as attractive as it should've been. I'll probably built a lighter, cleaner version after I test this one out this week at indoor session.
Here are some pics - and yes; I like bright colors lol
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Nov 30, 2010, 07:08 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Not to be negative, but it's pretty apparent that won't fly very well.
The Wings need to match for camber, especially if you don't have ailerons to balance them.
It should make nice, banked right turns.
Old Nov 30, 2010, 08:03 AM
mtflyr is offline
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
Ducatirdr, Nice job on the P-6E
Pete
mtflyr is offline Find More Posts by mtflyr
Old Nov 30, 2010, 09:22 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
you mean cause the one wing looks more curved towards the fuse? (wing on screen left?) its because it broke on a maiden flight and has been glued back together and fixed since that pic.
Old Nov 30, 2010, 10:03 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
oh, the right wing is broken. That makes more sense.
Old Nov 30, 2010, 10:11 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
yes lol - I have since repaired.
due to painting damage - this has just become a tester of sorts - I am to build another version, that is lighter ect but will essentially look the same
Want to use this as a tester
Old Nov 30, 2010, 05:43 PM
racie34 is offline
Find More Posts by racie34
road wart
racie34's Avatar
United States, IN, Terre Haute
Joined Aug 2003
I say.if you dont tell the geebee it will fly the same
racie34 is offline Find More Posts by racie34
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
