Old Nov 17, 2010, 10:42 PM
R.C. Aviation Fanatic
Razors edge 29's Avatar
Canada
Joined Aug 2009
hey that looks pretty cool
best of luck on maiden
Originally Posted by I R Irv View Post
Finally finished it but yet to maiden. All 2mm Depron colored with Sharpies. 11'' span 12'' at the elevons tips and 12'' long. AP03-4000kv and a XP-7A esc using a 2-cell Hyperion 120's pushing a 5030 prop. Hope it flies better than the Elevon Sumo with the BL setup and can't wait for calm weather. I wish I went with 3mm Depron because it makes a much stiffer airframe.
TODD
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Nov 20, 2010, 07:46 PM
Biplanes and Helicopters
AtomicPunk's Avatar
USA, CA, Arroyo Grande
Joined Oct 2007
Vapor Moth
There are some NICE planes on this thread!
Here's my submission:
1 & 2mm Depron Tiger Moth, Vapor Motor and Brick, AUW 1-1/8oz (32g)
Wheels made from Renshape and Poron Cord
Wings molded in hot water over a balsa form
Fuse molded with steam over a balsa form
Epson Inkjet printed tissue covering, adhered with Elmers Spray Adhesive.
Molded Cowling
Video Here:
Vapor Moth (1 min 51 sec)
It could use a little more power, currently running a 130mAh LiPo, I may buy a Piper Cub Motor to perk the lil' guy up some.
Simon
AtomicPunk is offline Find More Posts by AtomicPunk
Old Nov 20, 2010, 08:38 PM
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Nice work on the Tiger Moth! The Molded Cowel is great. Did you make a plug and vaccume form it? Any idea on your final weight, wingspan, or othe data?
Fred
Freddie B is offline Find More Posts by Freddie B
Old Nov 20, 2010, 08:46 PM
Centreville,VA,USA
Joined Apr 2001
Awesome job! Great scheme too...
Pete
mtflyr is offline Find More Posts by mtflyr
Old Nov 20, 2010, 09:32 PM
Weni, wedi, Java...
Brent Slensker's Avatar
Casper, Wyoming
Joined Nov 2009
Wow!
Brent Slensker is offline Find More Posts by Brent Slensker
Old Nov 21, 2010, 09:27 AM
AtomicPunk's Avatar
Joined Oct 2007
Thanks!
Brent, Pete, Fred,
Thanks for the comments. The Moth was fun to build, that is when I wasn't fat-fingering some tiny little part
The wingspan is 18", weight 1-1/8oz. (32grams). Fuse is 1mm Depron, Wings are 1mm, tail is 2mm. 3M tape hinges, landing gear from 1/32" (~1mm) carbon rod and music wire, held together with heatshrink.
The bulkhead reinforcements are 1/32" balsa. I had to put them in because I buckled the foam bulkheads just holding onto the darned thing while working on it!
The cowl is vac-formed over a balsa and ply plug. Pics below.
Simon
Old Nov 21, 2010, 05:09 PM
Nothing flies like a Pitts
Meshuggah's Avatar
Stockholm, Sweden
Joined Aug 2006
Simon: The tiger looks Reeeeeaally good! And the cowl is just flawless! Nice flat pattern technique, i do it the same way but in the 3d ap.
Meshuggah is offline Find More Posts by Meshuggah
Old Nov 21, 2010, 05:16 PM
AtomicPunk's Avatar
Joined Oct 2007
Thanks Meshuggah,
I didn't have any large sheets of PET in .015" (.3mm) so I had to get creative on the pattern. Plus when you form parts end-to-end there is far less chance of webbing, with the added advantage of the aft edge of the part maintaining good material thickness.
I bought a crashed SU-26 and I'd like to do a 22"-24" Fieseler Storch using the same techniques as the Vapor Moth.
Simon
Old Nov 21, 2010, 05:19 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Simon,
Thanks for all the pictures of your details. Tiny planes are fragile when building, but surprising how strong once built.
Fred
Old Nov 21, 2010, 05:24 PM
slow climbing turn to the left
USA, CT, North Branford
Joined Sep 2009
Wow!
Beautiful colour scheme. How long did construction take?
dhdrover is offline Find More Posts by dhdrover
Old Nov 21, 2010, 05:54 PM
The new guy
Londonderry, NH
Joined Oct 2010
Wow, looks like that Moth flies beautifully. Or maybe it's just skilled hands on the controls.
Chris_F is offline Find More Posts by Chris_F
Old Nov 21, 2010, 06:20 PM
Canada
Joined Aug 2009
looks fantastic
i am surprised though, that the Vapor motor pulls that much weight around.
Molded Cowling
Video Here: http://www.youtube.com/watch?v=s5zqLnXOzFo
Simon
Old Nov 22, 2010, 07:06 AM
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Teeriffic Mig-29
I updated my Teeriffic Mig29. I have the larger one too and really missed the active rudder on the small one. So I took out the AR6300 and put in a 6400 with the rudder attached to the brick. The ailerons and tail surfaces are run as flaperons + I mixed elevator to flap on PMIX5 so the trims pass through.
Petefoss is offline Find More Posts by Petefoss
Old Nov 22, 2010, 09:16 AM
AtomicPunk's Avatar
Joined Oct 2007
Thanks for the Comments
Fred, you're right about how much stiffer they get once assembled. Now if I could only get some micro fingers to put 'em together!
DHD - Thanks, the color scheme is from one of the Moths from the Old Shuttleworth Collection, airliners.net has lots of pics. Construction took about three weeks. The molded wings really speed things up.
Chris, the Moth is quite easy to fly, like all RC moths. Lotsa dihedral plus sweep and generous tail moment with fairly large control surfaces. Thanks.
Razor - The model is marginally powered at best. I twisted more pitch into the Vapor prop and used a larger battery. You kinda have to plan your climbs and manage your airspeed. That's why I want to put the Cub motor in. The wing area is about 85" sq. so the wing loading is under 2oz/ft sq.
Pete - Outstanding job on the '29. Nice color scheme, looks fast!
Simon
Old Nov 22, 2010, 10:57 PM
Nooflyer's Avatar
United States, MO, KCMO
Joined Aug 2005
Here's my scratch built Yak 55M.
It has all the electronics from the Parkzone P-51( which was torn to shreds).
But I've just put it together a week ago and finally maiden this lil pup in a lit parking lot! I can only fly this thing at night because Kansas weather is very unpredictable!
AUW= 30.5 minus battery
i want to add some night led lights on it but don't want to add too much weight!
Flown 5 batteries with the yak and i say I'm in love now! Enjoy
Nooflyer is offline Find More Posts by Nooflyer
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 126 Mar 26, 2013 06:30 AM
Cool Show off your Parkzone Micro P-51!!! P-51C Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
Gallery Show off your planes texan Wimberley Valley Flyers 4 Apr 13, 2006 02:10 AM
