Old Nov 05, 2010, 07:47 PM
BigGuyJT is online now
Find More Posts by BigGuyJT
BigGuyJT's Avatar
Fresno, California
Joined Mar 2007
Originally Posted by mrfliboy View Post
It was given to me by a club member, he had won it at our annual Xmas Party. Decided I would have the most fun withit.
Originally MSRP was $49 and our club picked it up from the LHS for $30.
I was impressed with how everything kinda fell into place. Basically all that was added was a flat cf pc under the bellcrank assembly. Oughta be hoot during pylon racing.
Hope you get video!!! Is it the hobby lobby one? http://www.hobby-lobby.com/nemesis.htm
BigGuyJT is online now Find More Posts by BigGuyJT
Old Nov 05, 2010, 08:48 PM
buratino is offline
Find More Posts by buratino
Singapore
Joined Nov 2007
I can fly my J-3 very well with rudder and elevator, but when I started to use the aileron, its start to nose up and then dive. Anyone know what could be the cause of this?
buratino is offline Find More Posts by buratino
Old Nov 05, 2010, 08:56 PM
mrfliboy is offline
Find More Posts by mrfliboy
Don't leave it Stock
mrfliboy's Avatar
USA, IL, Round Lake
Joined Feb 2004
Yupper
mrfliboy is offline Find More Posts by mrfliboy
Old Nov 05, 2010, 08:58 PM
maukabud is offline
Find More Posts by maukabud
HELP I AM BEING SET UP!!
maukabud's Avatar
United States, OR, Deschutes
Joined Jul 2009
Nosing up and then diving (over and over) is called "porpoising"...like a porpoise/dolphin does.
Most common cause is a CG that is too far back.
maukabud is offline Find More Posts by maukabud
Old Nov 05, 2010, 09:19 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Cubs have adverse yaw with ailerons. Right Aileron up makes it roll right, but the drag from the left aileron down yaws it left.
The pitch up could be the down aileron wing generating more lift, but then the wing stalls causing the nose to drop.
UNGN is offline Find More Posts by UNGN
Old Nov 05, 2010, 10:26 PM
buratino is offline
Singapore
Joined Nov 2007
Hi UNGN, yes it react just like you described, but on this case how can I counter it? more speed? this J-3 can fly and claim with half throttle but quickly stall with aileron
Old Nov 05, 2010, 10:36 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
For my cub, more nose weight and setting the ailerons so that Neutral was slightly Trailing edge up helped. I still needed to learn how to mix in the right amount of rudder and aileron to get it to turn smoothly.
Once you get it, it feels natural and the plane flies fine... but not fly the plane for a while and its very hard to to just pick up the TX and fly it... which is why I fly my champ instead. That plane flies itself.
Old Nov 06, 2010, 03:48 AM
Baratacus is offline
Find More Posts by Baratacus
Post Digger
Baratacus's Avatar
San Diego, CA
Joined Oct 2005
can you set up your aileron to just deflect upwards? It would require a slight modification of the bell crank, a couple tensioning springs and a couple stops for the aileron arms so they can't travel to down deflection. That way you just have the up deflection on one wing or the other to bank right or left, but you don't have the down deflection on the opposing wing that seems to be causing the nose in/stalling situation.
Baratacus is offline Find More Posts by Baratacus
Old Nov 07, 2010, 02:28 PM
Meshuggah is offline
Find More Posts by Meshuggah
Nothing flies like a Pitts
Meshuggah's Avatar
Stockholm, Sweden
Joined Aug 2006
risky business, you loose allot of lift that way.
Meshuggah is offline Find More Posts by Meshuggah
Old Nov 07, 2010, 02:38 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The Cub's wing is trying to generate too much lift, anyway and stalls easily. Flattening the wing out makes it balloon less under power and the inside wing stalls less in turns.
The plane may not slow down as much when traveling straight ahead, into the wind, but you can turn downwind without a wing dropping and the plane falling out of the sky.
Old Nov 13, 2010, 05:16 AM
nadine is offline
Find More Posts by nadine
vtol fan
nadine's Avatar
Joined Jul 2009
mariposa with ar 6400
hi!
this is mariposa by reto,but i put in AR6400 ....i plan to put 2 ,6mm from aero ace....weigt with no electronic is 12gr...maiden soon!
nadine is offline Find More Posts by nadine
Old Nov 13, 2010, 05:24 AM
nadine is offline
vtol fan
nadine's Avatar
Joined Jul 2009
Here is my J-3 version 2, I manage to reduce AUW to 39g with aileron servo. Just maiden yesterday and it flew great with rudder/elevator. Once get used to it I will connect the aileron to try
hi buratino!
it's a kit or you use a plan to make it!?
if is a plan you could kindley post it !?
verry nice!
Old Nov 13, 2010, 07:15 AM
indoor_fr is offline
Find More Posts by indoor_fr
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
How does this jewel fly?
indoor_fr is offline Find More Posts by indoor_fr
Old Nov 14, 2010, 03:46 AM
realglow is offline
Find More Posts by realglow
Eat, Sleep, Fly!
realglow's Avatar
Joined Mar 2001
Tethered RC (tRC) Planes for AR6400
These micro planes fly very aerobatically on 10 foot lines thethered to the top of a 12 foot pole. Planes are typically 10 inch span and weigh about 1 ounce:
realglow is offline Find More Posts by realglow
Old Nov 14, 2010, 09:17 AM
ckreef is offline
Find More Posts by ckreef
ckreef's Avatar
Danville, GA
Joined Aug 2010
I guess I don't understand. They are RC controlled with ar6400 Rx's so why use a pole ??? Doesn't a pole sort of defeat the purpose of having them Remote Controlled.
ckreef is offline Find More Posts by ckreef
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
