Old Dec 06, 2009, 03:39 PM
Bowerz is offline
Find More Posts by Bowerz
No, I dont work for HH ;)
Bowerz's Avatar
Southampton, Hampshire, UK
Joined Sep 2009
:O, i'm in love, i really have to order my Depron! I will be using an AP05 on a 2s, as long as the AUW is 70g or below, i will have a 3d model
Bowerz is offline Find More Posts by Bowerz
Old Dec 06, 2009, 04:23 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
The micro avion i had flew fairly well... the 15" wingspan @ 31g RTF weight w/ 49 sq.in of wing area, it was very snappy at low speeds (this eventually caused the demise of the first one). I think if the models wing chord was enlarged 1/4 to 1/2" at both the root and tip and extended 1 1/2" it would fly much better.
My bipe currently is sitting at 43g w/ everything but the 2 aileron servo's, lipo, esc and motor. I believe its final weight should be about 80-83grams.
its wing loading will be less than .4oz per sq. inch..
I've got micro Avion #2 on the board now, which will use an AR6400L and 2 AS2000L's with SFG's and 1 1/2" more wingspan. I'll let ya know how that one flies. The owner of this one, doesn't want to go brushless so i've got to get it as light as possible for the stock sukhoi power system.
invertmast is offline Find More Posts by invertmast
Old Dec 06, 2009, 04:30 PM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
Did you get the plans for the Avion off of me? I love how everybody can get my plane flying bar me! I think it would have gone if i used the right battery though. Or could have used my P-51 guts if i had 2/3mm foam.
Old Dec 06, 2009, 04:38 PM
Joined Mar 2004
yea i got em off here, didn't know you were the originator of them..im working on the 2nd one right now. They both use 3mm depron for everything, except the aft fuselage spline which is 2mm.
My bipe is all 2mm depron and w/ the carbon bracing, is very stiff. I believe the avion made from 1 or 2mm depron w/ some carbon rod of plate spars, it could come out under 30g RTF.
Old Dec 06, 2009, 04:53 PM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
Very nice, look forward to seeing it. And yes, i am the originator of the Micro Avion plans, there appears to be some larger sized ones floating around here as well.
Old Dec 08, 2009, 09:40 PM
tclaridge is offline
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
Micro Nite Stalker
Here is an odd one for you. AUW is 27g with the UM Su-26 motor and a 4.4x4 prop it almost hovers. I use a 150mah battery.
tclaridge is offline Find More Posts by tclaridge
Old Dec 08, 2009, 10:55 PM
dylantorquerol is offline
Find More Posts by dylantorquerol
Love the sport, not the plane
Hawaii
Joined Oct 2009
Can I have plans for the bipe invertmast? PLEASE! NOW!
dylantorquerol is offline Find More Posts by dylantorquerol
Old Dec 09, 2009, 07:29 AM
Joined Mar 2004
patience really isn't your strong suit is it? lol.
Its called the "6th version 4" The plans are already posted on RcG.
Old Dec 09, 2009, 02:52 PM
Meshuggah is offline
Find More Posts by Meshuggah
Nothing flies like a Pitts
Meshuggah's Avatar
Stockholm, Sweden
Joined Aug 2006
Its a tight fit but the 6400 is there
Meshuggah is offline Find More Posts by Meshuggah
Old Dec 09, 2009, 03:07 PM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
Meshuggah, every time i see this, i almost break down into a fit of unworthyness, often accompanied by a big feeling of I WANT THAT NOW AND ILL KILL TO GET IT
Old Dec 09, 2009, 03:27 PM
Joined Mar 2004
Got my batts, esc and motor in today.. all i'm lacking is 1 linear servo for the ailerons and my bipe will be done.. what i'm having a hard time deciding, is running 2 linear servos @ 3grams (85g RTF weight) or 1 6.6g servo (38g RTF weight)...
Old Dec 09, 2009, 03:33 PM
Meshuggah's Avatar
Stockholm, Sweden
Joined Aug 2006
Do you need the torque of the 6.6?
Old Dec 09, 2009, 03:36 PM
Joined Mar 2004
i've got 4 big ole ailerons and 2 "hover" flaps to go with it.. so the extra torque wouldn't hurt.
Old Dec 09, 2009, 07:07 PM
Hawaii
Joined Oct 2009
I would just go with the 6.6g servo. I had power problems with my 1.7g AS2000L with my ailerons. BTW, WHERE ARE THE PLANS FOR THE 6TH VER.4 BIPE? Can I have a link please? I can't find them.
Old Dec 10, 2009, 07:58 AM
Meshuggah's Avatar
Stockholm, Sweden
Joined Aug 2006
Yeah you need the torque there. Its no problem if you fly snail-slow but iy you have more speed you will fly the servo
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
