Old Sep 07, 2010, 12:55 AM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Looks like it flys well enough, pretty fast too!
Fred
Freddie B is offline Find More Posts by Freddie B
Old Sep 07, 2010, 07:39 PM
helidude22 is offline
Find More Posts by helidude22
Joined Aug 2008
Thanks! How would I go around slowing it down? I want it teach some of my friends to fly using it in our gym, but it is too fast for that. Do I need to put on a different prop or add some airfoil? Thanks.
helidude22 is offline Find More Posts by helidude22
Old Sep 07, 2010, 08:08 PM
signflyer is offline
Find More Posts by signflyer
2^p - 1
signflyer's Avatar
United States, MO, Springfield
Joined Feb 2003
Nice looking build! To get slower speeds, some undercamber will help (to the detriment of flying in a breeze). Other than that, more wing area and / or less weight would also slow it down.
signflyer is offline Find More Posts by signflyer
Old Sep 08, 2010, 03:32 AM
Bowerz is offline
Find More Posts by Bowerz
No, I dont work for HH ;)
Bowerz's Avatar
Southampton, Hampshire, UK
Joined Sep 2009
throttle control?
Bowerz is offline Find More Posts by Bowerz
Old Sep 08, 2010, 05:43 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Agree with signflyer, undercamber will help a lot. By the looks of the video, I think it could handle larger surface areas as well, no problem climbing now!
Good luck
Fred
Old Sep 09, 2010, 11:30 AM
Joined Aug 2008
So the under-camber is the airfoil? Sorry for being a newb.
Old Sep 09, 2010, 11:38 AM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Yes. Search for something like the GWS Slow Stick, or some early WWI Biplanes, or somethig prior to the war, and look at the wings. It creates much drag, but tons of lift. Limits high speed too, but it has everything you are looking for on this design. It also makes the wing much stiffer, and stronger.
An undercamber wing needs a little more incidence, which means about 2-3 degrees more up on the leading edge. On this size plane, maybe that would equate to another 1/8" raised at the leading edge.
Fred
Old Sep 09, 2010, 11:44 AM
hauntfreaks is offline
Find More Posts by hauntfreaks
hauntfreaks's Avatar
Cherry Hill, NJ
Joined May 2005
this is a wing I built for one of mine Embers... 3mm depron and to create the under camber I used a 1" dowel and rolled it out...
hauntfreaks is offline Find More Posts by hauntfreaks
Old Sep 09, 2010, 06:45 PM
wrcsti is offline
Find More Posts by wrcsti
wrcsti's Avatar
double kf huh?
wrcsti is offline Find More Posts by wrcsti
Old Sep 09, 2010, 07:27 PM
Cherry Hill, NJ
Joined May 2005
Originally Posted by wrcsti View Post
double kf huh?
yep... and seems to work really well....
here is the Link to more photos
Old Sep 09, 2010, 08:42 PM
ckreef is offline
Find More Posts by ckreef
ckreef's Avatar
Danville, GA
Joined Aug 2010
Here is a ember style wing (with ailerons added). I rolled the foam over a round surface to get the airfoil and then used 4 ribs so it maintains the shape over the long run. I scored the bottom of the wing in the middle and then bent it for a little dihedral.
The rolled foam makes a fairly rigid wing without having to add any carbon fiber.
ckreef is offline Find More Posts by ckreef
Old Sep 14, 2010, 02:55 PM
aeroesteban is offline
Find More Posts by aeroesteban
Joined Jul 2008
Pitts Special - 35 cm
Im working on it.
aeroesteban is offline Find More Posts by aeroesteban
Old Sep 14, 2010, 04:42 PM
Meshuggah is offline
Find More Posts by Meshuggah
Nothing flies like a Pitts
Meshuggah's Avatar
Stockholm, Sweden
Joined Aug 2006
Nice Pitts! What is the WS and weight?
Meshuggah is offline Find More Posts by Meshuggah
Old Sep 15, 2010, 01:07 AM
kylewoody is offline
Find More Posts by kylewoody
kylewoody's Avatar
United States, FL, Crestview
Joined Oct 2008
Scratchbuilt F4F Wildcat from 3MM Depron. Very light, flies awesome, neutral stability. All the guts (brick, motor, etc.) are from a Parkzone Sukhoi.
Kyle
kylewoody is offline Find More Posts by kylewoody
Old Sep 15, 2010, 08:08 AM
DarrylB is offline
Find More Posts by DarrylB
ACT, Australia
Joined Jul 2008
Dumas 17" Tiger Moth - RET
Ready for maiden flight on Saturday evening - Tuggeranong, Canberra. Once we see how that goes, I may add the stickers/roundels on for a bit more colour.
17" Dumas kit built "stock" (no wood substitutions), covered in Esaki tissue. Wheels from the PZ UM-P51. A true tail-dragger (no tail wheel or skid), but can turn "on a wingtip" once there is a bit of air moving over the rudder.
Vapor green dot brick, rudder-elevator-throttle. BSDMicro 7mm blue motor with 4:1 gearbox. plenty of thrust on a GWS 5x3.
Flying weight 30-32 grams (haven't gotten my good scales out yet)
Whilst admiring the wonderfully light and flexible control horns on the UM P51 and T28 and wondering if you could buy them separately, I stumbled across a sheet of cyano hinge material. light, flexible, easy to cut. Used on the rudder and is much better than the 1/64" ply horn on the elevator.
DarrylB is offline Find More Posts by DarrylB
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
