Old Sep 02, 2010, 01:06 AM
turbinator is offline
Find More Posts by turbinator
France
Joined Nov 2003
An indoor video :
Micro short 360 indoor (1 min 26 sec)
turbinator is offline Find More Posts by turbinator
Old Sep 02, 2010, 06:12 AM
Bowerz is offline
Find More Posts by Bowerz
No, I dont work for HH ;)
Bowerz's Avatar
Southampton, Hampshire, UK
Joined Sep 2009
i still don't understand how you do it! they fly so smooth and slow yet they look so scale!
Bowerz is offline Find More Posts by Bowerz
Old Sep 02, 2010, 07:05 AM
France
Joined Nov 2003
Thank you Bowerz.
I just increase the chord of 5mm and the stab of 20% compared to the scale model. But seeing the chord (52mm)I was a bit worry about the flight. In fact, with this weight (34g) there is no problem. It fly as well as an indoor trainer.
Outdoor video :
Micro short 360 (0 min 50 sec)
Old Sep 02, 2010, 11:01 AM
Piper J3 is offline
Find More Posts by Piper J3
Full Scale Piper Cub Driver
Piper J3's Avatar
Hinckley, Ohio
Joined Nov 2008
turbinator -
I can't tell you how many times I have watched and shared your Dash 8 videos... Amazing flying qualities and such light AUW with your CNC hotwire technique. I admire your building and flying talent to make these multi-engine models fly so scale like in the air and also ground handling. My congratulations on job done extremely well.
Piper J3 is offline Find More Posts by Piper J3
Old Sep 02, 2010, 11:18 AM
starscream4002 is offline
Find More Posts by starscream4002
starscream4002's Avatar
Tabriz, Iran
Joined Sep 2008
very pretty plane turbinator(like always) but I am still wondering how a plane with so little wing area can fly...but again it's your plane and you are the pilot so "anything" is possible
starscream4002 is offline Find More Posts by starscream4002
Old Sep 06, 2010, 12:30 AM
hauntfreaks is offline
Find More Posts by hauntfreaks
hauntfreaks's Avatar
Cherry Hill, NJ
Joined May 2005
Just did an Ember aileron mod using an AR6400 and 2 UM servos...
Link to Tread
hauntfreaks is offline Find More Posts by hauntfreaks
Old Sep 06, 2010, 01:35 AM
helidude22 is offline
Find More Posts by helidude22
Joined Aug 2008
Speaking of ember 2 I thought I would try and make a plane for a club at my school. I put some dihedral in it, but I really have no idea how it affects the flight. What does a flat wing do that is different than a dihedral one? I only have cellfoam 88, but I am looking around for depron. Some pics are below. Also, when I fly, the wings bend up a little. Should I attach cf from the fuse to the wing in order to eliminate it? Will this make it fly better? Thanks.
helidude22 is offline Find More Posts by helidude22
Old Sep 06, 2010, 01:52 AM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
The dihedral healps keep the roll level so therefor is more stable and easy to learn to fly on.
Old Sep 06, 2010, 02:03 AM
cabman1969 is offline
Find More Posts by cabman1969
cabman1969's Avatar
Melbourne, Australia
Joined May 2008
(Please correct me if im wrong!)
Dihedral is generally used for models of RET Rudder- Elevator-Throttle. The dihedral aids in making the plane bank slightly during the turn and actually helps to bring the plane back to center after the turn. Aircraft with ailerons (ARET) overcome this for the most part. High wing aileron trainers usually have the best of both worlds to give all the help possible for the beginner.
Flat wings are for more aerobatic aircraft as the wing fallows the path it is commanded too, more easily allowing inverted flight, ect.
Im not sure how the amount of dihedral is determined (for me its trial and error) but I hope this helps. Good looking plane btw
cabman1969 is offline Find More Posts by cabman1969
Old Sep 06, 2010, 02:14 AM
Baratacus is offline
Find More Posts by Baratacus
Post Digger
Baratacus's Avatar
San Diego, CA
Joined Oct 2005
and yes, flexing is bad. Stiffen it with some thin CF rod to hold the wing in place.
Baratacus is offline Find More Posts by Baratacus
Old Sep 06, 2010, 09:02 AM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
Completely correct, i just couldn't be bothered to type all of that
Old Sep 06, 2010, 11:43 AM
Joined Aug 2008
Thanks for the help. I will go add some cf to see if that helps with the flexing. I'll try to get a video up too.
Old Sep 06, 2010, 03:49 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Everyone here is correct. Dihedral does help stability for the aircraft. Dihedral also works with the rudder to cause the turning and correction after the turn. Still related to adding that stability.
10 degrees of dihedral perfect for top wing rudder/elevator planes. More and the turns enter and exit quite choppy. Less it take longer for the turn to start and stop when giving control input.
Dihedral not needed on ailerons, if you are a good pilot. Dihedral helps tame an aileron wing too, only you need way less, say 1-3 degrees on a top wing. Too much dihedral on an aileron wing and you have to use rudder and aileron at the same time to make the plane turn correctly.
Carbon fiber spars, or struts would help. Even some thin strips of fiber reinforced strapping tape, or packing tape applied right helps.
Cell Foam 88 is very similar to depron, just slightly less ridgid. However foam sheet has a grain, in other words it will flex less in one direction than the other, so make sure the stiff side is going across the span direction. If you massage an undercamber airfoil shape into your foam sheet, it will also feel at least twice as strong/stiff when done!
Fred
Freddie B is offline Find More Posts by Freddie B
Old Sep 06, 2010, 06:26 PM
Joined Aug 2008
So I finally got a video. Hope you like it
Micro Scrember (0 min 55 sec)
Old Sep 06, 2010, 06:28 PM
Andy2No is offline
Find More Posts by Andy2No
NaN
Andy2No's Avatar
Manchester, UK
Joined Nov 2005
Ah! I was too late. You fixed it already
Andy2No is offline Find More Posts by Andy2No
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
