Old Nov 29, 2009, 02:18 PM
GermanTigger is online now
Find More Posts by GermanTigger
GermanTigger's Avatar
Germany
I have no problem answering your questions! The Grob and the Jodel are both from plans drawn by a friend! His name is Hilmar and he also sells the plans! You can get them from the publisher VTH.de
There you can also get the material for the planes!
Art.-Nr. 6211140 (for the Jodel+material) Art.-Nr.: 3201383 (for the Grob) and Art.-Nr.: 6211206 (for the canopy and material for the build)
The other method is to build a depron splitting device which is also described by Hilmar and the German magazin FMT!
http://www.vth.de/fmt-0709-096.html
Sorry, all in German!
Toby
GermanTigger is online now Find More Posts by GermanTigger
Old Nov 30, 2009, 09:55 PM
Andrew Lai is offline
Find More Posts by Andrew Lai
Joined Nov 2009
Thanks for the help, you are awesome!!!
Andrew Lai is offline Find More Posts by Andrew Lai
Old Nov 30, 2009, 10:29 PM
Karl Miller is offline
Find More Posts by Karl Miller
See you at the field
Joined Oct 2006
Flying Disc
Built this a month ago when the weather started getting colder here in Chicago. It is 3MM depron foam with Ember parts. The first version didn't really fly beacause I made it with elevons on the back and no rudder control. So I re-engineered and made it just elvetor and rudder. Also CG is critical to success. Control is now good and is actually quite stable. Seems a little underpowered. Weight is about 1 ounce. Is there a better prop I could use? It is a blast to fly anyway.
Karl
Karl Miller is offline Find More Posts by Karl Miller
Old Dec 01, 2009, 05:11 AM
Meshuggah is offline
Find More Posts by Meshuggah
Nothing flies like a Pitts
Meshuggah's Avatar
Stockholm, Sweden
Joined Aug 2006
Originally Posted by Andrew Lai View Post
Wow, the stuff you build is just amazing. I'm a micro plane builder as well but compare to your skill I'm more like nothing!!!
Just few little questions for your advise. First, where can I purchase the material that you use for building the fuselage. Second, how did you get the fuselage become 3D dimensional? Are there any techniques for building great planes like yours? (mine is always "squireish" looking)
Hope you don't mind to answer my questions
Thanks =D
I build micro stuf with durobatics 0.25 and 0.5 (for bigger stuff over 30cm Ws) Just do a search on google. there are about 4-5 online-shops that got it.
To make the 3d look´n feel.
I ursualy make the cad on the computer and unfold/unwrap the model to get the pattern, then i print it on the depron with my printer andjust cut the parts,glue,bend and fold (observe the "just" word) Its biach to get it right, but you will get rewarded in the end. PM me for more info.
Meshuggah is offline Find More Posts by Meshuggah
Old Dec 04, 2009, 05:38 PM
Richard Cox is offline
Find More Posts by Richard Cox
Richard Cox
Thousand Oaks, CA
Joined Dec 2003
Dumas PT-19 conversion
Uses AR6400, AP-05 BL, HC 5A ESC, HC 240 mAH cell.
AUW is 55 grams.
Richard Cox is offline Find More Posts by Richard Cox
Old Dec 05, 2009, 12:11 AM
0011000011001 is offline
Find More Posts by 0011000011001
byte me!
0011000011001's Avatar
Joined Aug 2008
wow that plane is cool!
im trying to get my hands on a guillows kit and put my 6400 gear in.....
0011000011001 is offline Find More Posts by 0011000011001
Old Dec 05, 2009, 09:25 AM
Richard Cox
Thousand Oaks, CA
Joined Dec 2003
Dumas kits have much better wood than Guillows.
See their web site for the selection.
The last Guillows kit I built, I had to replace most of the wood.
I compared the weight to some good balsa I had and it was 3X the weight.
Light planes fly better!
Old Dec 05, 2009, 10:21 AM
byte me!
Joined Aug 2008
ill have a look at the dumbass kit then LOL
just for the record,i know how its pronounced
Old Dec 05, 2009, 07:19 PM
dylantorquerol is offline
Find More Posts by dylantorquerol
Love the sport, not the plane
Hawaii
Joined Oct 2009
Very funny. Have you guys ever thought of instead of using balsa or ply as a frame, you could use 3-5mm depron? I have seen it done, and that thickness is very strong. Saves a lot of weight.
dylantorquerol is offline Find More Posts by dylantorquerol
Old Dec 05, 2009, 07:41 PM
Richard Cox
Thousand Oaks, CA
Joined Dec 2003
Balsa flies best.
Old Dec 05, 2009, 08:14 PM
dhable is offline
Find More Posts by dhable
Let it Be
USA, WI, Oshkosh
Joined Jul 2004
Richard Cox-
Nice PT-19. What's the wingspan?
dhable is offline Find More Posts by dhable
Old Dec 05, 2009, 11:00 PM
btgreen is offline
Find More Posts by btgreen
Micro-Flyer
btgreen's Avatar
Newport Beach, CA
Joined Apr 2004
Originally Posted by Ryan Archer View Post
hey guys,
these both use the ar6400, but neither is 4 channel...
only one is brushless also, i just had an extra laying around for the horten type wing, anyways the canard weighs 20 grams rtf, and has 40 grams of thrust from the brushless motor, and a 5 by 3 carbon propellor, controls are thrust vectoring, for the rudder, and the canard moves for the elevator, the horten is powered by two aero ace motors/propellors, both fly at just about walking speed, and very well, i am extremely happy with both, but a lesson learnt here is, when flying a thrust vectored plane, that relys on only the rudder and elevator, do NOT throttle down when your going to hit something and try to turn hahahaha
ryan
making me spend my money too! Gotta build a canard now, too cool! Could you describe the power setup?
btgreen is offline Find More Posts by btgreen
Old Dec 06, 2009, 09:43 AM
Meshuggah's Avatar
Stockholm, Sweden
Joined Aug 2006
3mm depron = ~ 1mm balsa in weight...
Balsa is more rigid, but takes more time/love.
I use depron on the parts where i can aford the "flexynes".
Old Dec 06, 2009, 10:10 AM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
Here's micro #2 Its a reduced in size "6th Ver. 4" w/ some carbon for bracing instead of foam... Its a bit bigger due to staples not listening to what i wanted, so it ended up being 20" wingspan instead of 16 1/2". Still waiting on the brushless setup i ordered to show up and another spektrum linear servo. Weight as it is right now is 36grams. Paint,glue and carbon rod bracing added 3 grams (paint was only 1 gram). I'm expecting all up flying weight to be around 80grams w/ a 140g of pull w/ the brushless setup i chose.
invertmast is offline Find More Posts by invertmast
Old Dec 06, 2009, 11:02 AM
Richard Cox
Thousand Oaks, CA
Joined Dec 2003
DHABLE
It is a Dumas Walnut scale, 17-1/2" wingspan.
AUW is 55 grams. Flies nicely on the AP05.
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 172 Dec 10, 2014 04:31 PM
Cool Show off your Parkzone Micro P-51!!! P-51C Scratchbuilt Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
