Old Nov 28, 2009, 10:38 AM
Joined Jan 2009
Originally Posted by Meshuggah View Post
MikeW9: Your plane is adorable! You can go more easy on the balsa next time you build a micro, you coul use half amount of ribs. Pm me if you want help with the chanel switch (you use mixing to get it right)
Meshuggah;
I wanted to build the model per plans, but wound up with a heavy tail and not enough nose to counter balance it :-)
If you know how to SWAP ail and rud, I'm interested. I can copy one to another with mixes, but can figure out how to swap them..
MikeW9 is offline Find More Posts by MikeW9
Old Nov 28, 2009, 10:46 AM
Joined Jan 2009
Originally Posted by Ryan Archer View Post
Hi Mike,
i do all of my own plans, as i get more enjoyment out the planes this way,
i dont' really plan on giving them out after what has happened with some of my planes being sold by hobbycity.
anyways, they're both my designs, but sorry, don't want to give out plans,
ryan
Hi Ryan;
I understand. Thanks for the reply.
If you don't mind though, there's enough detail in the picture for me to cut one up. Where's the CG?
Old Nov 28, 2009, 11:00 AM
Flutter-Bys are fun
Conehead's Avatar
United States, MI, Honor
Joined Dec 2005
Ryan,
Your canard is baised on the Japanese Shinlin is it not? If not it looks really close to that plane. Looks like you got the canard just right so that it will fly fine.
Can't blame you about plans. No one wants their plans taken and used by someone else with out money being paid for them. Just not right.
Conehead
Orrin Eldred
Honor, MI.
Conehead is offline Find More Posts by Conehead
Latest blog entry: Pictures of Toledo
Old Nov 28, 2009, 11:57 AM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Originally Posted by MikeW9 View Post
Meshuggah;
To swap two channels you need to copy the other channel (one mix for each channel)
Then to kill the original input, you mix the channel to itself -100%/-100%
It takes 4 mixes to fully swap a channel.
UNGN is offline Find More Posts by UNGN
Latest blog entry: AR6400 guillows Space Shuttle
Old Nov 28, 2009, 12:19 PM
Nothing flies like a Pitts
Meshuggah's Avatar
Stockholm, Sweden
Joined Aug 2006
Yupp You need the mix and just blank the first
Meshuggah is offline Find More Posts by Meshuggah
Old Nov 28, 2009, 04:26 PM
Joined Jan 2009
You two are dead on! I just tried it.
I know I took several shots at this more than a year ago on a Vapor brick and just couldn't get it. I could mix one to the other, but when I tried to zero out a channel, I killed that channel.
With this and mixing the THRO over to the GEAR channel for an external ESC, it makes the Vapor bricks as useful as the AR6400 to me for my BL/4ch/Aileron planes and 10 bucks cheaper..
Anyway, thanks a bunch!
Old Nov 28, 2009, 04:39 PM
GermanTigger's Avatar
Germany
My Jodel with wingspan of 60cm and a take of mass of 33g!
(Yes, with a 240mAh Lipocell)
a AR6400 for rudder and elevator! 2 g Brushless!
After a plan from the german magazin FMT! The plan is available from vth.de!
The designers name is Hilmar Lange!
Toby
GermanTigger is offline Find More Posts by GermanTigger
Old Nov 28, 2009, 04:56 PM
Germany
My Grob G109! wingspan of 110cm!!! And a take off mass of 76g!
AR 6400 for rudder and elevator!
2 SPMAS2000: for the ailerons!
the 5g silverwind motor from Jamara!
2cells 240mAh lipo!
and i added a brick for the positionlights, anticollisonlight! and landing light!
(switched by the transmitter)
I hope you like it
Toby
Old Nov 28, 2009, 05:06 PM
stop me i'll hurt myself
lancaster county pa
Joined Dec 2008
you guys are crazier than me!
the riot is offline Find More Posts by the riot
Old Nov 28, 2009, 05:30 PM
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
15" Super Chipmunk
Here's my 15" wing span Super Chipmunk. 3 mm Depron and the gear from a Sukhoi including motor and prop. Color by Sharpie. I printed the plans on banner paper (8.5" by 22").
Petefoss is offline Find More Posts by Petefoss
Old Nov 28, 2009, 05:48 PM
Joined Jan 2009
2cells 240mAh lipo!
I hope you like it
Toby
GermanTigger;
what are you guys using for 2S BL ESC?
My favorite, YGE-4: 1S-3S 4A, is not available in the US anymore.
Old Nov 28, 2009, 06:55 PM
Parkzone connectors here!!
olmstead25's Avatar
Joined Oct 2008
hey meshuggah! beautiful plane! what prop and battery are you useing to get 30g? Also do you know what current your pulling when your getting that? how about a flight vid!
olmstead25 is offline Find More Posts by olmstead25
Old Nov 29, 2009, 01:31 AM
Love the sport, not the plane
Hawaii
Joined Oct 2009
Here is a micro 3D/F3P plane I built. AR6400L, AS2000L, Sukhoi motor, soon GWS 5043, 110mah, AUW 31g. It flies mich slower than the sukhoi even though it weighs the same, it just has more wing area. It is my fist, so thats why it is a little heavy. 3mm depron.
dylantorquerol is offline Find More Posts by dylantorquerol
Old Nov 29, 2009, 03:26 AM
Germany
GermanTigger;
http://www.jamara-modelltechnik.de/F...er-Xetronic-6A
I was not so happy with the YGE regulators thats why I tried something different! So i used the Xetronix regulator! To NOT burn the AR6400 i use a diode to reduce the volltage!
Toby
Old Nov 29, 2009, 01:50 PM
Joined Nov 2009
Hi there!!
Wow, the stuff you build is just amazing. I'm a micro plane builder as well but compare to your skill I'm more like nothing!!!
Just few little questions for your advise. First, where can I purchase the material that you use for building the fuselage. Second, how did you get the fuselage become 3D dimensional? Are there any techniques for building great planes like yours? (mine is always "squireish" looking)
Hope you don't mind to answer my questions
Thanks =D
Andrew Lai is offline Find More Posts by Andrew Lai
Pictures: When planes were able to show off, at air shows Patrick Plawner Life, The Universe, and Politics 126 Mar 26, 2013 06:30 AM
Cool Show off your Parkzone Micro P-51!!! P-51C Indoor and Micro Models 938 Nov 20, 2012 06:49 PM
Discussion Show us those planes you really need to replace! JimTMich Parkflyers 8 Apr 26, 2012 11:05 AM
Discussion Show off those home made camera gimbals! ben1101 Aerial Photography 2 Jul 22, 2009 07:11 PM
Gallery Show off your planes texan Wimberley Valley Flyers 4 Apr 13, 2006 02:10 AM
